Question on Bigfoot ground clearance - Fiberglass RV
Old 06-06-2013, 12:23 PM   #1
Trailer: bigfoot
Saskatchewan
We recently bought our first camper, a 1981 17' Bigfoot. It is great, other than the fact that it seems to sit very low to the ground. I can't even back it into my driveway because the back bumper hits bottoms out. My current hitch is a bit high, so the camper does not tow level. I went to my welder who made the hitch and asked him to make a new one with a further 2-3/4' drop to level it out, and he suggested flipping the axle leaf springs instead.
I am totally new to towing and campers in general, so I am asking: does this make sense?
His logic is that even with the camper level, it will be very low. He can flip the springs for $300-400, and it will raise the whole camper about 4". Welding a new hitch would cost about $50.
He seems to know what he is talking about ( his business is primarily welding hitches and prepping tow vehicles), but I would like to hear any other opinions.
spartacus is offline   Reply With Quote
Old 06-06-2013, 12:35 PM   #2
Trailer: bigfoot
Saskatchewan
Hopefully this picture works. It's a link to Dropbox...
Old 06-06-2013, 12:42 PM   #3
No photo. To add a photo go to advanced settings and click on the Paper clip icon and upload it that way.
If the Bigfoot is riding that low it is most probable due to the axle being shoot which based on the age of your trailer is a good bet. Although flipping the axle will give you more clearance I would not bother with flipping an axle of that age and would consider just putting a new axle on the trailer which should result in as much of a lift if not more as he is suggesting you will get by flipping the old axle. You should if you call around be able to get a new Dexter axle installed for only a couple of hundred more than what he is quoting you to flip the old one.
Old 06-06-2013, 01:14 PM   #4
Trailer: bigfoot
Saskatchewan
Aha, I installed the android app on, my phone, this is much easier to navigate and attach pix.
Old 06-06-2013, 02:30 PM   #5
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
If you go with another axle, upgrade to a 5500 lb with 15" tires.
And yes you need a axle.
Old 06-06-2013, 02:39 PM   #6
Trailer: bigfoot
Saskatchewan
Thanks! I'll call around and see what I can find.
Old 06-06-2013, 03:00 PM   #7
Sounds like you need a different drawbar or need to flip the one you have over. That would be cheaper than getting a new hitch.
This will explain what I mean: http://www.easternmarine.com/Trailer...unts-Drawbars/
Old 06-06-2013, 03:12 PM   #8
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Your trailer's ride height looks just like my 1980. If I measure the distance from the top edge of the steel wheel to the lower edge of the fender flair, it's 3". I don't think the steel springs have fatigued and sagged on mine. I think that is how Bigfoot made it. Of course, you can raise the trailer with stiffer springs or a straight axle. Only you can determine if it's worth the cost.
NW New Mexico Photo by tomNjo | Photobucket
Old 06-06-2013, 03:25 PM   #9
Trailer: bigfoot
Saskatchewan
I would if I could, but I'm working with a vertical hitch, and limited retail options.
Old 06-06-2013, 06:41 PM   #10
Trailer: bigfoot
Saskatchewan
I measured 2-1/8" clearance from steel to flair, and there is about 7" clearance from the bottom of the spare tire to the ground.
Old 06-06-2013, 07:16 PM   #11
Trailer: none
Thats a unusual way to make a drawbar, never seen on like that
Hambone is offline   Reply With Quote
Old 06-06-2013, 08:03 PM   #12
Trailer: Bigfoot 17' DLX
Alaska
This discussion on axles might help you. I'm going to lift my 1989 BF 17-footer this summer with a straight axle. Seems to be the way to go.
Axle replacement on Bigfoot 15B17CB
trainjunkie is offline   Reply With Quote
Old 06-06-2013, 08:06 PM   #13
Trailer: Fiber Stream
Originally Posted by Hambone View Post
Thats a unusual way to make a drawbar, never seen one like that
Draw-Tite Invisi-Hitch Vertical Trailer Hitch Receiver
Chrysler products have them, I saw one once on a Dodge Magnum.
Old 06-06-2013, 08:23 PM   #14
Alaska
If that's what it is, I wouldn't tow a Bigfoot with it. That's a class 1 hitch, only good for 2,000 gross and 200 lb. tongue. An older 17-ft BF comes in at almost 3,000 lbs. dry, more for the newer ones.
bigfoot
Ground clearance??? jime444 General Chat 16 05-04-2011 06:21 AM
ground question Randy Dewey Problem Solving | Owners Helping Owners 6 07-30-2007 11:46 AM
Tire clearance question AndyW Towing, Hitching, Axles and Running Gear 3 07-08-2007 07:42 PM
Raising Bigfoot for more clearance?? Tom Myers Problem Solving | Owners Helping Owners 35 07-06-2007 11:29 PM
Ground Clearance for Eggs Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 10-30-2002 10:16 PM
