I added 2 in. to the
axle bracket to gain extra clearance between the tire and wheel well. The mounting bracket was 2 in. wide so I added a 2 in. square tubing between the
axle mounting bracket and frame. I put half in. grade 8 bolts.to hold tube to mounting bracket of
axle. I used bolts to mount tube to frame. I then welded all joints good . One tire had made contac with wheel well just a little. The hardest part was getting old axle out without damage. I had put new
brakes on earlier, if not I would have put new off road axle. Bearings and seals were good on old axle and torshion bar was still working. It took about 7 hours and 2o dollars to do job Mack Smith
