Raising the axle on my Egg camper??? - Page 2 - Fiberglass RV
Old 07-17-2015, 02:47 PM   #15
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Ok after test towing the extra lift has made it a bit loose. I am going to add a anti sway bar. It's not bad, but I want it to be as safe as possible incase I have to do some abrupt maneuvering.
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 07-17-2015, 07:11 PM   #16
widgetwizard's Avatar
I dont get it. Why would adding a lift (that is actually stiffer than the original axle bracket) make anything Looser? What do you mean?
--Jim.
Retired from Orbital Machine Works.
Where is Jim now? Here.
widgetwizard is offline   Reply With Quote
Old 07-17-2015, 07:56 PM   #17
kirkman's Avatar
What I meant was I think by raising the center of gravity it has made it unstable. It does not track behind the TV as well as it did before. It's like it does not have enough tongue weight.
Jason
Old 07-17-2015, 08:44 PM   #18
Borrego Dave's Avatar
Trailer: Casita SD17 2006
A few questions, did you adjust your ball height to get the right angle? When you say tracking, do you mean dog trotting?
What makes you say it's unstable?
Make sure the TW is heavy enough.
I raised my SD 17 3" with no change to the tracking or handling. Even in high crosswinds it was fine.
Old 07-17-2015, 09:17 PM   #19
kirkman's Avatar
Yes I adjusted the ball height.
Yes the TW is heavy enough.
By dog trotting do you mean waging back and forth. Then yes not bad but more than before.
Jason
Old 07-17-2015, 09:47 PM   #20
Dog trotting is caused by the axle not being at a 90* angle to the ball. Some times a good hit on a curb or hole can knock it out of square. But in these cases it would come from an axle that is held to the frame with u bolts. My axle was bolted on and the lift kit from LHC was all machined to keep it all square. Tail wag is caused by an uneven load, front to back or side to side, not the height. Sounds like you have had a bit of this already going on before the lift so I really have say your loading is causing it. Have you weighed the tongue?
Old 07-17-2015, 10:01 PM   #21
Dog wagging
You are right on target. This is more evident when loaded to heavy to the rear. Have a Trailer shop, are alignment shop Square the axle to the frame.
Jim Thor is offline   Reply With Quote
Old 07-18-2015, 05:57 AM   #22
kirkman's Avatar
The tongue weight is 300 Lbs and she is square. I double checked that. I don't have hardly any thing in the camper right now so it cant be I have it loaded wrong. it's got me baffled
It's not bad, it only gets squirmy after 60mph.
Jason
Old 07-18-2015, 08:13 AM   #23
Raising axle
Did you change your tires/wheels?
Old 07-18-2015, 11:19 AM   #24
kirkman's Avatar
No I did not change my tiers.
Jason
Old 07-18-2015, 11:33 AM   #25
Raising axle
Well that eliminates that idea. Sometimes if you put radials on a trailer, it will feel squirley
Old 07-18-2015, 12:11 PM   #26
kirkman's Avatar
Yep I'm baffled ! When I leave for NJ I will try loading it heavy up front and see how it tows.
Jason
Old 07-19-2015, 02:49 AM   #27
Trailer: Big Foot
I had my axel flipped as well as struts put on. it has almost 2 feet clearance now. I take it to back road camping and have no troubles getting anywhere is need to go. Costly but worth every penny
Jesse Sutherland is offline   Reply With Quote
Old 07-25-2015, 06:55 AM   #28
kirkman's Avatar
Well I solved my problem. I lowered my ball height another 2 " and it towed like a dream.
Jason
Raising 17' Boler sarah j Problem Solving | Owners Helping Owners 0 06-10-2009 03:17 PM
SOLD-2006 EGG CAMPER EGG CAMPER Pat B Ohio Classified Archives 9 01-18-2009 07:43 PM
Raising a Bigfoot Peter DBK Modifications, Alterations and Updates 16 09-09-2008 05:06 PM
Raising Bigfoot for more clearance?? Tom Myers Problem Solving | Owners Helping Owners 35 07-06-2007 11:29 PM
Raising a Casita SD16 Steve Rosenberg Modifications, Alterations and Updates 8 11-26-2005 10:54 AM
