Raising the axle on my Egg camper??? - Fiberglass RV
Old 07-06-2015, 05:26 PM   #1
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
I am considering ordering a lift kit from Dexter (#9 Torflex Lift Kit K71-723-01) to raise my Eggcamper up 2 5/8" so it has better ground clearance (for the frame and the black drain) and to make it easier to get to the black and gray drain.
Has any one done something similar?
Pros verses cons?
HELP!
Thanks!
Jason
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 07-06-2015, 05:36 PM   #2
widgetwizard's Avatar
Pros verses cons?
HELP!
Thanks!
Jason
Jason,
There is a list of pros/cons on our FAQs page. http://www.perfectcasita.com/faqs.html
--Jim
Retired from Orbital Machine Works.
Where is Jim now? Here.
widgetwizard is offline   Reply With Quote
Old 07-06-2015, 05:36 PM   #3
Trailer: Bigfoot B-17 CB
I raised my Bigfoot 5 inches by changing the axle and tires and love it. Some things to consider are a much higher step to get in and out of the trailer and also by lifting with spacers you will still have the same clearance from the ground to the axle. The trailer will be higher so drain pipes and tanks are going to be further from harms way but axle to pavement distance will be exactly the same.
Jack L is online now   Reply With Quote
Old 07-06-2015, 05:52 PM   #4
kirkman's Avatar
Jack.....I'm not to worried about the axle to pavement thing just the frame and the pipes.
Did you notice and difference in the way it towed or gas mileage?
Jim.....Thanks
Jason
Old 07-06-2015, 07:28 PM   #5
Jim.....Thanks
The larger wheels and tires seemed to make it more stable. I went from 205-75-14 to 225-75 -15 so the wider tires made a big difference. As far as fuel use I really cant answer that question. Fuel consumption was always poor because of the large square frontal area on the Bigfoot. I'm sure the change hurt, but I cant say how much. I tow with a Toyota Tacoma 4X4 and without the trailer I get about 17 -18 MPG. With the trailer it drops to 13 or 14. One trip, when driving home from Utah in extreme headwind I got 7.5 MPG. As I drove down the interstate highway I could actually see the needle on the gas gauge drop.
For sure, raising the trailer will increase fuel consumption but can not say how much. Some sources actually say raising the trailer, you will get less wind resistance under the trailer. I look at it this way. If raising the tanks and plumbing prevents them from damage I'll gladly use a little more fuel to avoid repairs to the trailer.
Old 07-06-2015, 08:42 PM   #6
DJO
DJO's Avatar
Trailer: Parkliner #40 something
The tires were rubbing the wells of our Parkliner. Instead of cutting away some fiberglass, our smart bodyshop man cut off the ends of the factory axle, and put a new, stronger axle under the factory one. He used U joints to secure it.
We bought a little step to get in and out with. It pulls just fine and I can relax more since I don't worry about hitting the plumbing or frame anymore. It looks a lot better as a bonus.
DJO is offline   Reply With Quote
Old 07-07-2015, 06:25 AM   #7
Trailer: 21' Escape - former owner of 17' "other brand."
Jason,
That sounds like an interesting project and one that might definitely be worth while. The low drain tanks was one thing I didn't appreciate about our old EggCamper; several times I had difficulty draining our tanks because the sewer input was higher than the drain on the camper. I had to let the hoses fill and then manually lift them to drain them - not impossible, but not a pleasant job, either. Good luck with this!
Old 07-07-2015, 06:32 AM   #8
John Linck's Avatar
Madison, Wisconsin
I raised my 13 foot Scamp using a $100.00, 3 inch lift kit from Perfect Casita. Very nice folks and great product. Don't know about mileage. My rig is still lower in height than the 16 footers. Tows the same as before.
John
John Linck is offline   Reply With Quote
Old 07-07-2015, 08:47 AM   #9
Thinking of raising my Burro 2"
Jim Thor is offline   Reply With Quote
Old 07-11-2015, 03:11 PM   #10
Trailer: Perris pacer
I raised my 13 ft Perri's pacer ! Flipped the axel ! I get between 14-16 mpg towing with my Toyota Four runner 01 v6 3.4 4x4
mexbob5150 is offline   Reply With Quote
Old 07-11-2015, 04:02 PM   #11
Timber Wolf's Avatar
North Florida
Sounds like your PP had a straight axle with springs instead of the torsion axle on say a Scamp or Casita. Which brings up an interesting, thought provoking concept. At some point when raising an egg it may be possible to utilize a cheaper and locally available standard axle rather that a torsion. For example, our Tractor Supply has 3500 pound axles and springs on the shelf. Both types have their pros and cons but I usually tend toward cheap and simple given a choice.
Old 07-12-2015, 12:55 AM   #12
Following
Old 07-12-2015, 05:37 AM   #13
kirkman's Avatar
Well I ordered the lift kit. I will post pics of before and after when I get around to doing it.
Jason
Old 07-15-2015, 03:13 PM   #14
kirkman's Avatar
I raised my Eggcamper today. Here are some before and after pics.
Name:	ImageUploadedByFiberglass RV1436994697.665743.jpg
Name:	ImageUploadedByFiberglass RV1436994729.277160.jpg
After
Name:	ImageUploadedByFiberglass RV1436994761.502670.jpg
Name:	ImageUploadedByFiberglass RV1436994784.969845.jpg
Jason
Raising 17' Boler sarah j Problem Solving | Owners Helping Owners 0 06-10-2009 03:17 PM
SOLD-2006 EGG CAMPER EGG CAMPER Pat B Ohio Classified Archives 9 01-18-2009 07:43 PM
Raising a Bigfoot Peter DBK Modifications, Alterations and Updates 16 09-09-2008 05:06 PM
Raising Bigfoot for more clearance?? Tom Myers Problem Solving | Owners Helping Owners 35 07-06-2007 11:29 PM
Raising a Casita SD16 Steve Rosenberg Modifications, Alterations and Updates 8 11-26-2005 10:54 AM
