RAV4 people: why is my hitch only 4 inches off the ground? - Page 10 - Fiberglass RV
Old 04-25-2013, 09:02 AM   #127
The 2008 RAV4 manual says to tow in 4, not Drive. It also says to tow up hills in 4, not to shift to 3 for any extended period ( doesn't say what that means ).
As for towing over the specified tongue weight, are you going to change your mind when you detect damage?
baglo
Old 04-25-2013, 09:25 AM   #128
lpk49's Avatar
Trailer: 2007 casita freedom deluxe-2013 tacoma
New Hampshire
i mostly drive on the flat on highway or a little back road. so it sounds like if i leave it in drive it will change on its own when it needs to?
i need to deal with the wdh today and tomorrow. they want me leave the car and camper and wdh with them. i want to hang out long enough to see if all the parts are there and if they are damaged. the box was such a mess when it arrived.
i'm trying to make a list of all the specs and tow height , tire pressure etc. george helped me with a list and i will do the best i can with that today.
my biggest concern is these guys keep saying TW doesnt matter and the wdh will solve the problem.
i wish i could just trust them to do it right...again...it was so much easier with the truck...i dont like all this fussin around. i just want to get on the road!
well-i'm going to prepare as best i can and go to the shop early tomorrow.
i am so greatful ro all of you for sharing what you know.
lpk49 is offline   Reply With Quote
Old 04-25-2013, 09:28 AM   #129
Don't tow in Drive. Tow in 4 as it says to do in the RAV4 manual.
Old 04-25-2013, 09:38 AM   #130
lpk49's Avatar
New Hampshire
ok-i did plan to reread the manual...mine is a 2009.
thx. for everything. all of you.
glenn: As for towing over the specified tongue weight, are you going to change your mind when you detect damage?"
my whole point here is to get the tow weight down. it is 365 from the factory. my car can take 350. there isnt that much difference. i am taking off both propane tanks. i took out captains chairs and table. i travel very light and will carry most of what i have in the front and back seat of the car...not the way back near the tongue.
i know i might be able to lighten the TW by putting water in the fresh water tank in the back of camper or putting some weight in the back of camper inside.
but i am really trying to lighten the TW of the camper so i am not pulling more than i should.
as far as "detecting" damage i probably wont know how to do that. i read about one story of these cars with hiches attached to the "uni" instead of the frame just ripping off ...thats probably how i will find out i am in trouble...and i dont what that-obviously.
i'm gonna work on the list...i can take pics now...but like i said...they don't want me hanging around at the shop.
ps-i found a cat scale 15 miles away...but i have to be hooked up to go there...so all this will be done before i go to the scale...i plan to bring a batroom scale to the shop and try to get a weight after the propane is off...but i'm pretty sure the guys there will think i am crazy...i dont know if i can lift it on the scale once the propane is off. i cant budge it now.
Old 04-25-2013, 09:45 AM   #131
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
The factory "tongue weight", just like "dry weight" is meaningless. Actual tongue weight is what you must use to determine whether you are within the tow vehicle's specifications. Your actual tongue weight could be less; is likely to be more.
Old 04-25-2013, 09:51 AM   #132
lpk49's Avatar
New Hampshire
but jon there is no way to know without towing to a scale...correct?
i'll try to do the bathroom scale thing..but dont know if i will be able to
that spead sheet with TWs has it in the 400s, 500s, 600s - if thats the case im pretty sure i will have to sell the casita
Old 04-25-2013, 10:17 AM   #133
lpk49's Avatar
New Hampshire
from joons earlier post:
TW of up to 300 lbs. can be measured on a household scale by resting the trailer coupler on the scale and placing the scale on a box so that the coupler is at its normal towing height. The trailer must be fully loaded and level.
so i dont have to lift it then...right?
i crank it up all the way...set a box under with scale on top...use lumber to make it the right height -as if i was towing..then crank it down til weight is on scale...if its over 300 i guess the scale will break...then i'll at least know that
Old 04-25-2013, 10:36 AM   #134
deryk's Avatar
New Jersey
Depends too what your bathroom scale is rated to. My parents bathroom scale from their engagement party 56 years ago was only good for 250lbs. When I was at my heaviest I bought a scale that went to 330lbs (the 300 mark was at zero, 310 ligned up with the 10lb mark, 320 with the 20lb mark, 330 with the 30lb mark) Ive seen at walmart scales going to 400lbs (go figure lol) So check what your bathroom scale goes up to and if not high enough go grab one from walmart that would be high enough.
deryk
Old 04-25-2013, 10:39 AM   #135
Trailer: 1992 Casita 16 ft Spirit Deluxe
Here is another way to measure approximate TW with a bathroom scale.
Weigh, tongue at home 101 - a set on Flickr
There is also a video on youtube but I don't have that bookmarked.
Martha Effinger is offline   Reply With Quote
Old 04-25-2013, 10:43 AM   #136
MCDenny's Avatar
Trailer: Lil Snoozy
Your bathroom scale probably wont go high enough. Heres a way to do it. http://m.wikihow.com/Measure-Tongue-Weight. The method for a large trailer is what you want. Measurements need to be precise, I'd say within 1/4 inch anyway.
Your RV shop might have a TW scale.
A even easier way is to use two scales supporting the ends of of a beefy beam, like a piece of 4x4 3 or 4 feet long. Put the scales under the ends and the trailer tongue approximately in the middle. Add the two scale reading. No measuring with a ruler involved.
MCDenny is offline   Reply With Quote
Old 04-25-2013, 10:45 AM   #137
deryk's Avatar
New Jersey
Very cool martha!
thanks
deryk
Old 04-25-2013, 10:50 AM   #138
MCDenny's Avatar
Trailer: Lil Snoozy
These flicker pictures say it all. Same method as wiki article but much clearer description.
Old 04-25-2013, 11:12 AM   #139
Trailer: FunFinder
Using a bathroom scale is certainly possible, but you are likely going to have to jump thru the hoops of doing the balance beam/lever thing, etc.
Forget being able to "pick up" the tongue by hand....that's not gonna happen.
Going to a scale....CAT or otherwise is the simplest, safest way of doing all this.
gmw photos is offline   Reply With Quote
Old 04-25-2013, 07:41 PM   #140
lpk49's Avatar
New Hampshire
oh george...you havent seen my biceps...
Towing with a rav4 Jimmy jones Towing, Hitching, Axles and Running Gear 5 08-13-2012 10:52 PM
Rav4 vs. Forester Bobbie Mayer Towing, Hitching, Axles and Running Gear 25 03-15-2012 01:19 PM
What's the number of inches? Kevin K Problem Solving | Owners Helping Owners 9 02-07-2012 08:46 PM
RAV4 and equalizer hitch - any problem? Glenn Baglo Towing, Hitching, Axles and Running Gear 6 10-31-2008 02:49 PM
doing the math... squeezing inches Michael M Problem Solving | Owners Helping Owners 5 11-16-2007 07:41 AM
