Removable 5th Wheel Hitch - Fiberglass RV
Old 05-29-2013, 09:21 AM   #1
Trailer: Scamp 19ft 5th wheel
We have a 2008 19ft Scamp. The hitch that came with it causes problems when we try to haul our quad runner. Have you seen the new removable Scamp 5th hitch? What does it cost? Can it be removed easily?
Thank you for your help: Jerry
Jerry in Colorado is offline   Reply With Quote
Old 05-29-2013, 02:16 PM   #2
Brian B-P's Avatar
Scamp is now offering a customization of a commonly available hitch, which attaches to mounting rails in the truck bed. It is as easily removable as any typical bed-mounted removable hitch... or even easier, because with just a ball instead of the usual fifth-wheel head, it will be significantly lighter.
You can custom-build (or have custom-built) a similar hitch using a different bed-mounting system if you prefer. A few Scamp owners have done this, and presumably served as the inspiration for Scamp's new product.
New redneck 5th wheel hitch cpaharley2008 Towing, Hitching, Axles and Running Gear 28 03-09-2012 11:20 PM
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
removable hitch ball Sandra Lair Towing, Hitching, Axles and Running Gear 22 04-18-2009 08:57 PM
Innovative 5th-Wheel Hitch Patrick M. General Chat 12 07-05-2007 04:08 PM
