removable hitch ball - Fiberglass RV
Old 04-14-2009, 05:33 PM   #1
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
We recently bought a 2003 Odyssey. This is the first time we have towed with a vehicle with a removable hitch ball. We towed the Scamp for the first time last weekend & were suprised at the loud "clunk" sound when the ball mount shifts up & down or from side to side within the receiver. Is this normal? Can the amount of "play" be reduced?
Sandra
Sandra Lair is offline   Reply With Quote
Old 04-14-2009, 05:38 PM   #2
Pete Dumbleton's Avatar
There are several anti-rattle devices on the market:
http://www.etrailer.com/c-BMAIII.htm
Or you can just jam some thin wooden wedges in between the ball mount and the receiver hole.
Old 04-14-2009, 05:39 PM   #3
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Our class 2 hitch with Reese removable hitch does it too but for us we get it on hard starts and stops. There is minimal play in the receiver but it's enough to make the noise. It would be nice if there was an answer on this .. hint!
Old 04-14-2009, 06:00 PM   #4
Sandra:
Same problem, but I isolated it to up-and-down slop only. Found a thin piece of aluminum, cut a shim, put an angle on the end as a handle. I push the bar in with the shim on top and the problem has disappeared.
Old 04-14-2009, 06:40 PM   #5
Great information! We will definitely look for something to fill in the space & reduce the rattle. Thanks everyone!
Sandra
Old 04-14-2009, 06:47 PM   #6
pjanits's Avatar
Trailer: 17 ft 1986 Burro
You obviously need to turn up the radio.
Mine has some slop too but I never hear it.
Old 04-14-2009, 07:28 PM   #7
I can see how that would solve the problem too!
Old 04-14-2009, 08:56 PM   #8
Trailer: 2012 Escape 19 / 2013 F-350 Crew Cab 4x4 Diesel!!!
I have a 2" class 3 I picked up at Princess Auto that has an elastomer built into it. The "clunking" has disappeared, it was under $20 and made in the USA!!! It has 'Robin' stamped into it as well as 6000lbs gross and 600lbs tongue.
I am thinking of buying a WD hitch and was wondering if the 'clunking' would disappear???
(Don't mean to hijack the thread!!!)
BC Paul is offline   Reply With Quote
Old 04-14-2009, 10:49 PM   #9
Bryan L.'s Avatar
Trailer: 1991 Scamp 16 ft
Ha, I remember the first time I pulled out trailer with our van and heard this noise. I immediately pulled over and checked everythig out. I really need to get one of those anti-ratle things for peace of mind.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
Bryan L. is offline   Reply With Quote
Old 04-14-2009, 11:23 PM   #10
JenPB's Avatar
Trailer: 1972 Compact Jr
I'm really glad you asked this. I'm not new to towing, so the sound wasn't scary for me, but I've wondered about the "clunk" for a lifetime! (Seriously.) It never bothered Dad, so it must be ok. Still...would be nice to eliminate it. I'll work on a wedge/shim of my own. I'd sure like to see yours, Per.
My problem will be finding scrap shim material since I don't do much metal fabricating....yet.
Jen
The Blog - travels and more
The Book - what we do around these parts
JenPB is offline   Reply With Quote
Old 04-15-2009, 04:39 AM   #11
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
I make plastic shims from the flat sides of juice bottles.
Tom Trostel is online now   Reply With Quote
Old 04-15-2009, 08:21 AM   #12
Trailer: Casita 17 ft Spirit Deluxe / Infiniti SUV
Had same problem when we first pulled out of the Casita factory. (Draw-Tite hitch, Infiniti-dealer installed). I called the great service guy at Casita. He said "call Draw-Tite, they'll take care of you."
Draw-Tite came through and free of charge sent me one of these:
http://www.etrailer.com/pc-BMAIII~63201.htm
Note that the hitch receiver must be a compatible two-hole J-pin type like the Draw-Tite shown (scroll down) in the link. I don't know whether other hitch brands have the two-hole config.
No more clunking. Thank you Draw-Tite!
George Cathcart is offline   Reply With Quote
Old 04-15-2009, 09:26 PM   #13
That's the one I would get if I were getting one -- The second hole should be a drill size found in a regular drill bit set -- The larger hole is not.
Old 04-15-2009, 09:48 PM   #14
Looks like a great product. I'll have to see if it can be used on ours. Thanks again, everyone!
Sandra
Help! My hitch and ball are grinding and gouging Ron Stewart Towing, Hitching, Axles and Running Gear 16 10-09-2009 12:45 PM
Wrong size hitch ball Kevin K General Chat 10 06-23-2009 04:09 AM
Burro hitch ball Lee Senn Towing, Hitching, Axles and Running Gear 6 04-19-2009 01:39 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
Check Your Hitch Ball ! Brian T Towing, Hitching, Axles and Running Gear 38 10-03-2007 11:31 AM
