Repairing a trailer hitch - Fiberglass RV
Old 04-21-2015, 12:37 AM   #1
One of the holes in the car hitch that the pin goes thru to hold the shank and ball in place has elongated, possibly from using a small diameter pin.
Any Ideas on how to repair it?
Thanks
Frank F
frankcfx is offline   Reply With Quote
Old 04-21-2015, 02:23 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
I have no idea why only one side is being elongated. Hitch pins are a standard size. You could clean it up and run a weld bead around it then redrill the hole. I weld but am not a welder and have always heard that a good weld is stronger than the metal but.........might just be better off in the long run to just replace the hitch. How are the holes in the stinger, still round? Metal fatigue comes into play at some point also. In all reality it may not be a safety problem at all. If you think about it all our hitches get worn as we use them. When new the pin was tricky to get through, years later it goes in real easy from use.
Borrego Dave is online now   Reply With Quote
Old 04-21-2015, 04:20 AM   #3
MC1
MC1's Avatar
Dave has some good thoughts. Might want to have a good hitch shop have a look at it too.
Old 04-21-2015, 05:18 AM   #4
Trailer: Bigfoot B-17 CB
Could the holes be drilled out and an oversize pin be used ?
Old 04-21-2015, 06:44 AM   #5
One could have a heavy washer of the correct size welded on either side.
I have no idea why one side wallowed out and the other did not.
If a new hitch were not too expensive it might be as cheap to replace it as getting a good welder to repair the old one.
It all depends on the cost of the welding and how good they are.
If it wallowed out and the proper hitch pin were used it might bring into question the quality of the original hitch.
Old 04-21-2015, 07:09 AM   #6
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I would replace the hitch.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 04-21-2015, 07:32 AM   #7
Drill the hole oversize, have a bushing made which is simple lathe job, weld it in. Wouldn't matter if it stuck out a little
Old 04-21-2015, 07:43 AM   #8
Dennis mn's Avatar
There is no reason to have to replace the hitch. Either Dave's or Mary and Bob's fix should work just fine. I would probably just weld and re drill the trick will cleaning up the inside of the tubing so the stinger still fits. I would think a Dremel Tool with a grinding wheel should fit in side and do the job.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 04-21-2015, 08:34 AM   #9
I agree having a reputable hitch shop look at it would be a good idea.
Cause of it would be of concern to me. I know I in the past owned a new to me vehicle that this had happened prior to my having purchased it.
Local hitch shop suggest that the most common cause of it is the trailer it had pulled either had no brakes or the brakes were set incorrectly resulting in excessive push and pull on the hitch. A poorly fitted hitch pin would have added to the problem.
Old 04-21-2015, 10:15 AM   #10
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Thanks
When one metal is softer than the other - the pin is probably hardened, the receiver not, wear will occur. If both metals are the same hardness, they will polish each other. A loose pin could cause adverse wear. How old is the hitch?
What size is it? Class I, Class II, Class III? How much does the shank and ball wiggle in the socket? After you make repairs .... I like the idea of drilling to an oversize pin ... Try to take up any looseness with shims, or a snubber kit. Your Hitch Shop should be able to help there.
Old 04-21-2015, 10:48 AM   #11
Welding in and redrilling the hole would be OK using the right rod, but it would be hard to get the new hole perfectly centered, the weld may push the drill bit off center. If the hole is resized or repaired, then use an "anti rattler" or tightener device. One of my hitches I have to use a shim on the side too
Old 04-21-2015, 03:29 PM   #12
I am guessing that the stinger has over size hole in it. The pin should be forced square through the 2 inches of the stinger. If one side of the receiver has wear the stinger has to allow it. The stinger has to be loose in the receiver to allow this to happen or the holes were out of square and are now self correcting. Take it to a hitch specialist. a good shop has all the equipment to fix this.
Old 04-21-2015, 08:32 PM   #13
Elongated Hitch hole
Thanks to everyone for the suggestions. I have been thinking of taking it to a weld shop and having a 1/4 inch rectangular plate welded to the hitch over the hole and then inserting the shank and drilling through from the other side.
Frank F
Old 04-21-2015, 08:40 PM   #14
sokhapkin's Avatar
SW Florida
How much a weld shop will charge you just to look at your hitch? Compare with the price of the new hitch ($150-200).
Sergey
www.callwithus.com
Need a few tips on repairing my trailer. Derrick719 Problem Solving | Owners Helping Owners 5 12-05-2011 06:04 PM
Repairing a Battery Jump-Starter peterh Electrical | Charging, Systems, Solar and Generators 10 07-25-2009 10:29 PM
repairing Surfside windows Eileen S. Problem Solving | Owners Helping Owners 7 04-13-2009 09:15 PM
Repairing from the wind storm Lainey General Chat 7 10-26-2008 12:30 PM
About repairing or replacing the floor or frame . . . peterh Problem Solving | Owners Helping Owners 8 03-24-2008 07:54 PM
