Replace 12 Year Old Tires Or Not? - Fiberglass RV
Old 03-29-2015, 09:57 AM   #1
Mikell's Avatar
Name: Mike & Ellen
Trailer: 1988 Liberty Van Companion 17'
Our tow vehicle has 12 year old BFG T-A radial tires with only 30,000 miles on them. Our tow vehicle is not used in the winter, and stored in a garage. The tires still look to be in excellent condition, no sidewall cracks and plenty of tread life. The question is: Would you replace the tires due to their age?
Mikell is offline   Reply With Quote
Old 03-29-2015, 10:20 AM   #2
papa-t's Avatar
Glade Valley, North Carolina
Unless only driving local and not towing. Otherwise I would replace them.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 03-29-2015, 10:44 AM   #3
Mikell's Avatar
Name: Mike & Ellen
Yes, we would be using to tow!
Thx Papa-T
Old 03-29-2015, 10:58 AM   #4
Trailer: 1984 Dolphin
Wisconsin
Rubber starts to brake down around 7 years so I would replace them.
Ace57 is offline   Reply With Quote
Old 03-29-2015, 11:10 AM   #5
Tire compounds break down with age and affect grip on both dry & wet roads. I replaced my 7 year old tires two years ago on the van first thing I noticed was taking off from a hill the back tires were no longer wanting to spin same goes for braking much more grip to the road.
Your car will feel like a new ride.
Old 03-29-2015, 11:22 AM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
Yes, yes, yes! Go directly to the tire store; do not pass GO, do not collect $200. The rule of thumb is that tire rubber compounds break down too much to be reliable after 5 to 7 years.
How much time do we have left? 2 Chr. 7:14
Old 03-29-2015, 06:13 PM   #7
If a tire is not used then the oils in the rubber compounds are not "stirred" and the tire rubber compounds "dry" out.
The rolling of the tire keeps the rubber alive.
Yes those tires are too old and while they look good they are a time bomb waiting to blow when you least expect it.
Sitting for a long time they are probably flat spotted as well.
Old 03-30-2015, 08:19 AM   #8
Trailer: 2008 Casita 17 SD
The rubber compounds of tires degrade internally more so than they do on the outside. They can show no outward visible signs of deterioration but can be literally falling apart inside. They could present an extreme hazard, such as a blow out, without any warning, (and most probably under conditions where it will be the most inconvenient or dangerous.) Best to replace them, (any tires,) at 5~7 years, whether they appear worn or not.
Old 03-30-2015, 10:11 AM   #9
IllAnnoy
A question for the OP... What did your tire store rep say last time you got your tires rotated?
For whatever reasons, tire stores generally will not mount or service a tire over 10 years old.
Still....
"Logan's Run" maintenance is no substitute for tire inspection, inflation, and rotation on your TV.
Old 03-30-2015, 10:17 AM   #10
Trailer: None
None
Rotation
[QUOTE=floyd;512884
"Logan's Run" maintenance is no substitute for tire inspection, inflation, and rotation on your TV.[/QUOTE]
I was always under the impression that the only reason for rotating the tires was to get even tire wear. WAS I WRONG. .Living in a state that loves to apply road salt ,my mechanic suggested rotating the tires. The salt had rusted the rims on so hard that I could not believe the effort it took to remove and rotate the tires.
If I had had a flat tire there was no way I could get that tire off the vehicle and install the spare. I get the tires rotated every other oil change . As usual Floyd offers some good advice.
Old 03-30-2015, 10:34 AM   #11
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
A question for the OP... What did your tire store rep say, last time you got your tires rotated?
I talked to the manager at the tire store I use about changing tires based on their life, as my trailer tires are 6 years old now. He told me 'off the record', that he personally would, and has, run his own trailer tires for close to 10 years, while monitoring their condition. His take was that the tire companies are just covering their butts, and want to sell more tires.
He said they have the same issue with struts, in that the recommended replacement of them is way shorter than what they have experienced in real life, and that they just have to be monitored. As soon as the sway begins to show, then change them.
2017 Escape 5.0 TA (January 26)
2009 Escape 19 (previous)
Old 03-30-2015, 10:53 AM   #12
[QUOTE=steve dunham;512891] The salt had rusted the rims on so hard that I could not believe the effort it took to remove and rotate the tires.
I've had to beat rims off with a sledge hammer. Any of my vehicles where the center hole of the rim fits tight on the hub I'll put never seize or grease around the hub. No I don't put it on the studs, that topic has been discussed already. We had problems with big trucks using hub piloted wheels on aluminum hubs where they would seize onto the hub. Some tool company came out with a puller to help get them off.
Old 03-30-2015, 01:13 PM   #13
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
I'm sure if we wait a little longer the government will come out with a new regulation prohibiting the use of tires over a certain age!
Old 03-30-2015, 01:26 PM   #14
IllAnnoy
Likely true! And that would prevent, once and for all, the further improvement or development of tire longevity and technology....
A great victory for the Luddite Hoi-Polloi!
tires
Oh the joys of a 28 year old trailer... Garth M Problem Solving | Owners Helping Owners 15 07-05-2013 12:47 AM
To Replace Or To Not Replace??? Susan Landis Modifications, Alterations and Updates 11 07-29-2011 10:19 AM
Old, New, Really Old, not so New! But I am back! Robin G Hi, I am.... 10 01-01-2011 04:56 PM
Do I Replace converter or Not? Chris and Ame Care and Feeding of Molded Fiberglass Trailers 14 07-27-2007 09:13 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 07:17 PM
» Virginia Campgrounds
