Replacement brakes for 1983 scamp 13? - Page 2 - Fiberglass RV
Old 09-01-2015, 10:57 AM   #15
New dexter hubs can be had for about $50 each - perhaps even a little less on line. Not bad considered having old ones spun/buffed up locally to remove heavy rust was about 3/4 the costs of new ones as I recall at the time I had to deal with refurbishing my Scamps brakes.
I purchased a complete new dexter brake assemble complete with pads for just under $50 per side.
I think $200 for new hubs and brake assembles is an investment well worth making it if it saves messing around and worrying about old obsolete parts - especially for a future owner of the trailer.
Old 09-01-2015, 11:09 AM   #16
Trailer: Scamp 13 & TDI tugboat
Ohio
QC & reinstallation
Repeat mirror image assembly with parts for other side.
First QC test: are there any leftover parts? No? Good enough.
Next QC test: check the wiring/magnets for conductivity. Should be the same on both sides. This is close enough, 4.4/4.3 ohms. 3% variance seems acceptable. From this we can calculate the amp load the brakes draw at full power.
4.3/2=2.15ohms total resistance.
14V/2.15= 6.5A max current, or 3.25A per brake.
I thought the OEM 16ga wire to the brakes was small, but 3.25 is well below the 11A capacity of 16ga.
We've checked out the drums and know they are 7.256" on a 7-1/4" nominal size. How will we know if the drums are worn out if there is no service literature anymore? How about reading the face of the drum I've been looking at for a month. doh!
Max Diameter is 7.310 and they are currently 7.255/7.256. Plenty of wear left in the drums.
Also, if I had looked at the drums more closely I would have noticed they are marked HD 7.25 right on front.
Nothing left to do now but reinstall. Hang the backing plates on the trailer axle & tighten the 4 nuts & lockwashers. Reconnect wires, adding some convo tubing where wire passes through the axle bracket. Be sure to use the Ox-gard grease for these crimps that will be very exposed to road splash.
Slide the drum in place, grease the outer bearing, shove it in w/ the D-washer & install nut & cotter key. Whack the new Bearing Buddies in place. (they are replacing the chi-comm dust caps from Vatozone that keep falling off.) Finally, install the freshly blasted & painted wheel with the blasted & painted lug bolts. Tork to 90 ft/lbs, according to stamping right on bolt heads.
One last step, adjust up the adjusters until it is hard to spin the wheel, then back off until they are just barely dragging.
Alright, let's go Scamping! In the mountains! With no fear of steep downgrades!
Cheers,
Jim C
FJ40Jim is offline   Reply With Quote
brakes, scamp
U-haul CT13 axle replacement with brakes, price in N. CA Lindl Towing, Hitching, Axles and Running Gear 16 10-16-2012 01:23 PM
Floor replacement in a 1983 Beachcomer Michael Murphy Care and Feeding of Molded Fiberglass Trailers 1 08-30-2009 10:01 AM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
SOLD - 1983 19' 5th Wheel Scamp Tara Classified Archives 1 01-31-2007 03:27 PM
1983 Scamp towing hook up.. jimtesla Modifications, Alterations and Updates 3 07-31-2006 07:33 AM
