Replacing Ball Receiver on Trailer - Fiberglass RV
Old 02-26-2015, 09:35 AM   #1
trilliumdon's Avatar
Trailer: 1975 BIOD Extase
Hi, I looked around and couldn't find a thread dealing with this, forgive me if I over looked it...
I have a Trillium and the ball receiver part of the trailer, where the 17/8" hitch ball locks is old, rusty and barely functions. I'm thinking I'd like to get it removed and replace with a 2" receiver there, then replace the ball on my truck.
Is this something others have done? I'd take it to a welder, but are there any pitfalls to doing this? Will it weaken the connection to the Tow Vehicle? Any insights would be welcome.
Don
trilliumdon is offline   Reply With Quote
Old 02-26-2015, 10:02 AM   #2
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Don, lots of people have done just this, and in fact I am contemplating doing it on the '76 Trillium I am working on. A good welder will have it mounted more than strong enough.
This is the one I am thinking of getting from Princess Auto.
Class III 2 in. A-Frame Trailer Coupler | Princess Auto
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 02-26-2015, 10:15 AM   #3
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
Thumbs up this will be bitter
[QUOTE=trilliumdon;506746]Hi, I looked around and couldn't find a thread dealing with this, forgive me if I over looked it...
most people do this going to 2" ball
it will be fine
MRClaus is offline   Reply With Quote
Old 02-26-2015, 12:31 PM   #4
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Just did mine this year on our Boler
Bottom of the page is a pic of the install.
I changed the style of coupler used in order to make the hitch a little longer. Plus I wanted the coupler to be bolted to the trailer. I wanted it bolted so it would be easy to replace in case I twisted or otherwise hurt it.
Fred
There's a hole in my Boler my Boler my Boler
FRED SMAILES is offline   Reply With Quote
Old 02-26-2015, 05:46 PM   #5
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Don, that's a pretty standard change out. I have 2" couplers on everything, even a little 4 x 8 foldup. Got tired of changing the balls out.
One other thought, don't know what you tow with but if you have a problem with clearance with the jack while connected, this would be a great time to have a longer coupler done.
Old 02-26-2015, 07:52 PM   #6
Depends on whether you want to deal with welding. On the forums (all over the net) the hitch portion has often been described as the spoon and fork. The spoon portion is where the ball lands, the forks are the portion that hooks around the ball. If the spoon is good (not elongated, cracked, etc) but the forks are worn... you can purchase a new hitch assembly and take it apart. Put the new forks and hitching mechanism into the spoon.
Does this make sense?
Old 02-27-2015, 05:49 AM   #7
Trailer: 2015 Oliver Legacy Elite II - Hull #69
South Carolina
Often times rust makes metal parts appear far worse than it really is. Have you sprayed it down with WD-40 and a wire brush?
Unless a lot of the metal is gone, it's probably OK with a bit of cleanup and a shot of rustoleum.
Follow my blog - http://www.wincrasher.blogspot.com
Ron Merritt is offline   Reply With Quote
Old 02-27-2015, 09:09 AM   #8
Timber Wolf's Avatar
North Florida
I made it my life's mission to change every 1 7/8" hitch trailer that came into my possession to a 2” hitch. And I was doing it to until I bought my old Scamp with a perfectly good 1 7/8” hitch and just can’t bring myself to change it. But someday I will find a reason and will not only change it to 2” but will raise it up and also elongate the hitch a little for jack and tailgate clearance. All that said, I would think about what other things I might want or need while I was taking it to a Welder. I know I had to reinforce the frame of my Scamp where it had rusted through on the bottom for example.
Old 02-27-2015, 12:32 PM   #9
Borden's Avatar
Name: Borden and Carole
Lucky the boler we have was built with a 2" but do have a frame repair to do at the door step
1978 Ontario made Boler
Have a receiver on your trailer? Any regrets? dylanear Modifications, Alterations and Updates 11 08-03-2012 11:46 PM
HELP! At trailer hitch place, what size ball do I need? joy mccalla Towing, Hitching, Axles and Running Gear 5 01-18-2010 08:48 PM
Trailer Jack Receiver Plate is Worn Out Buck62 Problem Solving | Owners Helping Owners 6 02-02-2007 07:31 PM
TRAILER BALL SIZE ??? Dan Quinn Problem Solving | Owners Helping Owners 2 06-07-2006 01:50 PM
Cushioned trailer ball mounts??? Legacy Posts Towing, Hitching, Axles and Running Gear 14 02-09-2003 12:34 PM
» Trailer Showcase
Boler
ddwills
Burro
minnie r.
