05-29-2007, 09:17 PM
Trailer: Compact II 1974
Replacing my tires & rims... do they have to be trailer tires?
Well, my '74 Compact II got a flat today just outside of my destination and, since my 3-month old was screaming her lungs out, I decided to drive super slow the final 1/2 mile. Anyways, I went to Pep Boys to see about getting 185/80 13Rs but they said they don't sell them anymore and that regular tires will pop. They suggested U-haul for the tires in my size. But the rims are also ready for changing (quite rusty) so I am thinking of just getting some standard rims (still 13") and decent non-trailer (read: automotive) tires...
Is this a terrible idea? Do I have to stay with the exact same setup or can I switch over like this?
I'm gonna go shopping tomorrow so any help is much appreciated...
David
05-29-2007, 09:36 PM
Trailer: 1975 13 ft Trillium
Just last week, I conversed with my tire 'Dood' about trailer tires or 6 ply truck tires. He informed me that trailer tires are butter designed for the bounce that is inheritant in most all trailers and that trailer tires are NOT as expensive as truck tires.
Going up or down (in tire/wheel size) really shouldn't hurt the trailer UNLESS you go too far in either direction or you are interested in keeping your Egg more like original. Wheel/tire width can affecet wear on wheel bearings as well. There could also be a small wheel alignment issue as well.
SO....if in doubt, keep things as they were intended (IMHO!).
05-29-2007, 09:41 PM
Trailer: (I am embarrassed
Hello David!
Flint here.
Go online and buy from tiresunlimited.com, or something like that. I have a set of Duro Trailer rated Radial ST's size 175/80 R13 on my Havasu fiberglass unit. They are great tires at a good price with fast shipping. I think if you buy the wheels from them they will mount for free. Bolt pattern may be an issue, you should ping their email or call them and ask about the 4 on 4 bolt pattern availabilty.
My Los Osos webcam picked up a light green Compact II in tow behind a Toyota Corolla yesterday evening, near the strawberry stand at the corner. I was home, where's the love? Just kidding, I can only assume that you still had a lot of road to put behind you on your way to your next stop.
Happy to see/hear you are using it!
-Flint
05-29-2007, 10:57 PM
I don't have the time at the moment to seriously respond to this, but I can suggest some searching right here in FiberglassRV... this a common (and somewhat controversial) subject. If you look for "special trailer", "passenger" and perhaps "light truck" I'll bet you find most of the relevant topics, because those are the tire types usually involved in the discussion. There are also commercial tires, but they are not common in the relevant size range.
05-30-2007, 03:27 AM
Trailer: Boler 13 ft
David
Any 13 inch rim will work if the bolt patern is the same.
The best thing would be to take a wheel with you to the store.
As far as the tire I just had some put on my Boler 13ft. and the tire co. told me "P" or passenger tire was well over the weight limit for my unit but I do recall reading on this site one needs to be concerned with side wall construction.
Maybe for my small trailer it doesn't matter that much.???
Gerry the canoebuilder
05-30-2007, 05:31 AM
As Brian suggests, search the forum. As a tire engineer, I suggest you stick with ST or LT prefixed tires.
Without adult supervision...
Also,
05-30-2007, 05:42 AM
David,
In addition to the suggestions above, you must look carefully at the load rating of the tires. Divide the weight of your Compact (fully loaded for travel) by the number of tires (4 or 2?) to get the load rating required. Use the GVWR if you know it. ST (special trailer) tires are recommended, but you could use passenger car tires, as long as you bump the required rating by at least 10%. LT (light truck) tires are also acceptable. Most tire shops don't stock ST tires, but can get them in a day or so. Goodyear and Carlisle are prominant brands and sometimes you don't get a wide range of choices without a lot of hunting. Quality and constuction of tires are difficult to judge, but consider ply rating and the reputation of the tire maker. Go to someone with experience in equipping trailers, especially travel trailers. The Bay Area should have someone who can give you satisfaction. Good Luck!
05-30-2007, 02:39 PM
There are more factors to wheel fit in addition to the bolt pattern (which is 5 bolts on a 4.5" circle - 5x4.5" - for my Boler and most small trailers). The offset also needs to be close (many modern cars have 5x4.5 bolt pattern but radically wrong offset); the centre hole needs to be large enough to clear the hub (much bigger than modern passenger cars); and the load capacity needs to be high enough (maybe higher than a 13" car wheel can handle). Fortunately, most trailer wheels are very similar, so it should be easy to find a match if you look at wheel intended for trailer use.
05-30-2007, 03:38 PM
i changed out my wheels and tires a month ago. i decided to change my wheels to 14" from 13" from discount tire. they have the proper tire and rim combo that worked wonderfully without any issues of tire rubbing. the tire size i went with are 205/75/14 and is made specifically for trailers. for the price difference, i did not want to take a chance on anything going wrong. good luck!
05-30-2007, 05:33 PM
joey- you have pm... hoping for some advice on your choice. discount tires and americas tires are both having a hell of a time finding my size rims and tires. I forgot my spare at home in S.F. (I'm in L.A. right now) so I can't bring my trailer down to have new rims sized. I basically need to find something that I can be certain will work. I also don't want to increase the height of my trailer since it barely fits into my garage at home. if 14" rims will do it, then I'm fine with that since I'm getting new rims anyways.
05-30-2007, 06:37 PM
http://www.tirerack.com/tires/tires.jsp?ti...yes&place=0
David,
You are needing tires for a 1400 pound trailer that has a hitch weight of 160 lbs. So each tire is loaded with 620 pounds. Any 13" ST tire will work. Your 13" wheels have 4 lug nuts on a 4" center. If the rust on the wheels is only surface rust, I would sand them, then spray paint with a can of Krylon. I'd call the TireRack and order 3 Goodyear Marathons. UPS will deliver them in about 3 days. Have them mounted and balanced by your local tire shop, and go camping.
05-31-2007, 01:31 PM
When I fixed up some rusty steel wheels for a car (many years ago) I had a local shop sandblast them. It was only a few dollars a wheel, and a much more thorough job than I would have been able to do with sandpaper, due to the awkward shape of the surfaces. It is easy to get carried away and excessively blast, so this is better done by a body shop than an industrial fabricator like I used.
06-06-2007, 11:32 AM
David
IMHO, there are two things wrong above.
One person on this list has had good luck with P-rated tires, but many others in the RV world have had bad luck with them, including myself. They just don't have the sidewall stiffness, so they have more of a tendency to sway and to bounce than ST tires. ST's have stiffer sidewall, different (more) steel and polyester belts inside and have more chemicals in the rubber to prevent UV decay.
Bolt patterns alone don't define a wheel/rim -- Besides the offset mentioned above, automotive wheels are usually hub-centric and trailer wheels are usually lug-centric (with the hub hole stamped with less precision) -- Examine a set of trailer wheels and you can see that the hub hole edges don't contact the hub as they do on automotive wheels. It is also important to get the contact angle of the lug nuts/bolts correct for the wheel being used; they come in several angles, including flat.
YMMV!
06-07-2007, 11:31 AM
Good spotting Pete... we've done the wheel-spec thing enough times that it's easy to miss a feature, such a hub centering or seat angle.
06-07-2007, 11:40 AM
I agree that all of Pete's points about the differences in tire construction are valid (although the UV thing doesn't matter if you're going to replace them every 6 years as currently recommended anyway), but (other than the UV) they basically amount to a pressure rating.
A load range B tire of ST type may be inadequate for load capacity, and won't be much stiffer than a 35-psi P tire. A load range C tire of ST type will be stiffer (which is likely a good thing), but primarily because it is a 50-psi design... extra-load (XL) P-tires and both LT commercial tires in load range C will be similarly constructed, for the same reason (and the same pressure).
My van has two sets of tires of the same size: a P-type summer set with 35-psi rating, typical capacity for their size, and one body ply; and a winter set with 50-psi rating, higher load capacity, and two body plies.
Yes, stiffer tires seem like a good idea, and that's the way I'm going with my next set for the Boler. ST? Maybe, and it's the easiest type to find, but it's not the only option - even worse, an ST of the wrong (too low) load range won't have the desired construction. If you want stiffer, look for that higher load range (C or better).
06-07-2007, 10:44 PM
Trailer: 13 ft Boler
Hi All, I've been running around on a set of used 195/60R14 tires on 6 in. wide rims for 4 years with 0 problems. Check air pressure grease bearing GONE!
10-14-2012, 09:38 AM
Trailer: Currently Shopping
I'm looking for my first FG trailer. I think I like the Compact/Campster/Havasu layout. There is one about 200 miles from me, needing complete restoration, and it has no spare.
Do you, or anyone know the wheel size and bolt pattern (4 on 4, 5 on 4.5, etc.) for a 1971 Havasu? I would want to buy a spare tire and wheel before towing it, if I buy it. Thanks, from a newbie.
10-14-2012, 10:00 AM
Looking at pictures in the gallery of a Havasu, it has 5 lugs. So, most likely it takes a 13" wheel with a 5 lug x 4 1/2" bolt circle.
Maybe a Havasu owner can step up with better information.
Tire with Wheel 13 Inch 5 on 4-1/2 Inch Tires and Wheels | etrailer.com
10-14-2012, 10:58 AM
We are about to replace the (light import truck tires) 8 ply tires we have had (and used) for FORTY years. They've been on 4 different 'down sized' trucks and most recently saw service on our Trillium for the last 8 or so years. They have stood up real well to wear, in fact the only reason to change them is we found cracking on their sidewalls. There seemed to still be adequate tread left for another couple of seasons or so....
Now the problem is, our tire shop says that NO ONE is making these tires (in this size) anymore and recommends going to a more dedicated trailer tire. This purchase does not have to be done untill our first campout in March of next year, so we have time to look around and see what might be on the market!
10-15-2012, 03:14 PM
NOT 8 ply tires....
Upon fielding a private message from a fellow Egg Owner, I double checked the remaining two tires on our stored Trillium. It seems I goofed at the ply rating of our tires. They are NOT 8 ply, but are 6 ply LT Tires.
Thanks for making me do some double checking Brian, LoL!!!!!
