Scamp 13 hitch height 16-18" means... - Fiberglass RV
Old 06-13-2015, 01:17 PM   #1
CampyTime's Avatar
Trailer: Scamp 13' Standard
Hooked my scamp up myself today to my new to me 2007 chevy express wheelchair van (my bro is brain injured and paralyzed). Sold the truck in march.
When scamp says 16-18" hitch height, do they mean when hooked up, top of ball, tonge/a frame itself?
I'm hooked up right now in my driveway, and here's my measurements:
Ball under coupler, tippy top of coupler: 16-3/4 max
A frame middle of coupler: 17-1/4" max approx.
Is that ok? Here's some pics.
Name:   ImageUploadedByFiberglass RV1434223030.914882.jpg
Name:   ImageUploadedByFiberglass RV1434223047.486339.jpg
Name:   ImageUploadedByFiberglass RV1434223067.161297.jpg
Old 06-13-2015, 01:56 PM   #2
IllAnnoy
late model= 18" Top of the Ball for a Scamp13.
Old 06-13-2015, 02:13 PM   #3
Trailer: Bigfoot B-17 CB
I can't really tell from the photos. I like to park the tug and tow on level ground and look at the trailer. If the trailer is level or the tongue is slightly lower you should be OK. It's best to not totally count on book specifications here. An axle or wheel change or suspension change can make published numbers useless.
Old 06-13-2015, 02:17 PM   #4
Wendy what Scamp says is a guide line - what the measurement ends up actually being to make the trailer level on the ball may differ from trailer to trailer - due to axle drop etc.
Cant really tell from such close up pictures as to the state of the trailer as far as level goes - although one looks like the tongue *may* be *slightly* up.
The key is just get it level or with the tongue slightly down.
Old 06-13-2015, 02:57 PM   #5
CampyTime's Avatar
It is slightly higher than level, you're right. I have a 1" rise on that receiver.
That's why I asked the question about what scamp says, didn't know what that meant. Having a hard time finding anything lower. Maybe I need a 1/2" drop instead?
Floyd, late model means like mine, a 2012? I had heard it should be level or slightly lower, but didn't know if what I had was ok as I didn't understand scamps specs.
Back to the receiver drawing board I guess. No idea what to get so maybe I'll try a1/2" or straight bar?
Old 06-13-2015, 03:11 PM   #6
CampyTime's Avatar
At top of ball I had 16-3/4 max
Old 06-13-2015, 04:01 PM   #7
CampyTime's Avatar
If late model means newer then I'm assuming trailer is level at 18"? I probably don t understand clearly, but if I'm off at all by being a bit too high, I don't think it's a lot.
I called ETrailer. The ball mount I have is the least rise they sell. I just checked it again and I was mistaken earlier. I have 2" drop, 3/4" rise, not 1".
Old 06-13-2015, 04:22 PM   #8
CampyTime's Avatar
Oh and hitch height (top of 2" square hole) is 14-1/4".
Old 06-13-2015, 05:10 PM   #9
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Wendy, I can't really get a good look at the stinger....even with zooming in. It kind of looks like you've got the ball in the rise position, at least from the pic. If so, turn the stinger over 180* and remount the ball for the drop.
Show us another pic up close, 3/4 angle please.
Old 06-13-2015, 07:04 PM   #10
Wendy what Dave has suggest would be what I would try first to get the tongue to drop a bit more if the receiver you have on there now has a bit of rise - flip it for the drop. If its still not level or slightly down you might need to find yourself a 2" drop receiver.
Old 06-13-2015, 09:11 PM   #11
IllAnnoy
purrfect!
Old 06-14-2015, 02:17 PM   #12
CampyTime's Avatar
I just turned the stinger around to the 2 inch drop side. Level says a little low. Top of coupler is now 14". Here's some pics. So basically it appears a little nose down now. Before on 3/4" rise side it was a little nose up. Don't know what to do!
Name:   ImageUploadedByFiberglass RV1434312889.211779.jpg
Name:   ImageUploadedByFiberglass RV1434312916.322266.jpg
Name:   ImageUploadedByFiberglass RV1434312966.956070.jpg
Old 06-14-2015, 02:42 PM   #13
Leave it ....the level indicates its not nose down by much - you will be way happier than with it nose up!
Old 06-14-2015, 02:55 PM   #14
A little bit nose down as shown in your photo is perfect. Go camping !
Scamp 16' Hitch Ball Height semievolved Problem Solving | Owners Helping Owners 28 02-26-2016 11:03 AM
Scamp 13 Hitch Height arashaw Towing, Hitching, Axles and Running Gear 20 05-14-2013 07:09 PM
Some "before" and "after" shots..... Don & Viv Modifications, Alterations and Updates 13 07-29-2010 04:52 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
» Trailer Showcase
Egbert
MapleBoler
TED
Spanke
