Scamp 19 hitch modification - Fiberglass RV
Old 05-22-2015, 07:37 AM   #1
Dennis mn's Avatar
I have the base rails installed. The design is in mind and next week, my weldor son and I will complete the modification and the install of the hitch in the Nissan. Then it's on to this summer's trailer maintenance and modifications.
2019 Airstream 19 Foot, pulled by a 2014 Nissan Frontier Pro4-X Crew Cab.
Dennis mn is offline   Reply With Quote
Old 05-22-2015, 12:24 PM   #2
Name: John + Linda
Trailer: Scamp 19
2012 Frontier Gooseneck setup
This was my solution to this problem - do a search on
frog49 is offline   Reply With Quote
Old 05-22-2015, 01:13 PM   #3
Dennis mn's Avatar
Thanks John,
That topic devolved a bit, but I Like your solution. Your hitch is much more elegant than what I am planning. (Well, for now anyway). I am going to adapt my bolt in Scamp hitch to fit the base rails using some 1/2 x 1 1/2 bar stock.
Old 06-01-2015, 11:52 AM   #4
Dennis mn's Avatar
This is the completed hitch. Next step is to get the Scamp out of the shed and get it rewired.
Old 04-19-2017, 09:00 PM   #5
Trailer: scamp 19
Quebec
did you try it? can you post picture of the scamp hook on your Nissan
Zummie is offline   Reply With Quote
Old 04-20-2017, 06:14 AM   #6
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
Don't know anything about a scamp 5th wheel but your hitch looks real close to the cab of the truck. A friend of mine took out his rear window because his hitch was too close and on a tight turn corner of camper hit the window and smashed it.
Will yours clear and/or did you have to modifie the goose neck on trailer?
Others may want to know.
Old 04-20-2017, 02:50 PM   #7
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
Hi Gerry, I'll show you my Tacoma - 5th wheel set up in a few weeks, a the Spring Fling. I don't know anything about the Frontiers. My setup worked out so that the tightest truck turn will still have about 8 inches between the cab and the Scamp loft. Backing up is a different story, jackknifing can result in a disaster.
Old 04-20-2017, 05:42 PM   #8
Maine
I looked at a scamp 5th wheel years ago and it wasn't a ball couple but a regular pin and plate like I have for my 31ft holiday rambler 5th wheel.
Trouble was my 3/4 ton Silverado's bed was too high to get under the camper so I didn't buy it.
John is your a goose neck or pin & plate?
Just looking at Dennis's pictures the hitch assembly is over the axle, which is where it should be, but it looks real close to the cab of the truck.
Old 04-21-2017, 07:38 AM   #9
Paul O.'s Avatar
That king pin and plate had to be a DIY add on, I think Scamp always had the 2" ball, about 15" up from the bed. Yes, for a Silverado you would need the 3" lift. Mine has it and it is about right, even for the Tacoma.
Fifth wheel hitch modification gihuff Modifications, Alterations and Updates 9 08-11-2017 01:14 AM
Scamp front bunk modification to support adults John Carter Modifications, Alterations and Updates 17 06-23-2017 01:31 PM
Closet Modification: Shelving and Lower Hatch Entry - 13' Scamp Shannon Thompson Modifications, Alterations and Updates 12 01-05-2013 07:44 AM
Scamp 5th wheel modification Ed Doe Care and Feeding of Molded Fiberglass Trailers 8 09-06-2006 06:32 AM
Scamp 19' fifth wheel hitch modification Roger H Modifications, Alterations and Updates 0 05-15-2006 04:57 AM
