Originally Posted by Keith2000
I hadn't thought about the possibility of rattling if the front legs are totally unloaded. That would be tragic. I think the pictured mod should work well.
The hitch bracket rattling on the rails drove me nuts while driving with the
Scamp unhooked. I replaced the pins with 7" 1/2" bolts, then bent some oversize washers (3/4", I think) to an acute angle (>90 deg.), two per bolt, plus two normal 1/2" washers per. When the bolts are tightened the play in the system is eliminated by loading the bolts to bent them slightly, ends down toward the rail. I hope the description makes sense. No rattle!
