Scamp Axle - Leading vs Trailing - Page 4 - Fiberglass RV
Old 08-22-2013, 06:26 PM   #43
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by Brian B-P View Post
Tom, I assume that you mean basic in features, rather than in core functionality. A timer-based control isn't just basic, it's bad.
Right, I wouldn't consider a timed controller. By basic, I meant in the Tekonsha hierarchy
I think Tom's Primus provides all of the characteristics that I listed, although I am not familiar with the controls and displays. At a glance, it looks like an original Prodigy in this respect.
I think that you are right.
Old 08-22-2013, 08:19 PM   #44
Brian B-P's Avatar
Originally Posted by Thomas G. View Post
Right, I wouldn't consider a timed controller. By basic, I meant in the Tekonsha hierarchy.
A few years ago, Tekonsha offered a range of timer-based controls. I think it's interesting that they have completely abandoned them... but they are still offered under the same company's Reese brand, where there are no proportional controls!
Old 08-22-2013, 10:57 PM   #45
Trailer: 77 Scamp 13
Only "good" thing I can see about timed is they can be mounted in any position. And maybe if the trailer is a very heavy dual axle where you always want the trailer to take more of the braking load than the TV rather than spread it evenly between the two. But from my reading the boost settings on proportional handle that need.
Even Draw Tite web site says that proportional have come down so much in price that the price difference is pretty slim.
On eTrailer for about $30 more than the cheapest timed you can get a primus. The price difference for name brand timed is more like $15. The P2 looks like it comes with the plug kit, connectors and a bit of mounting hardware for $30 more.
This thread someone put forth a little bit of literary effort to explain why it would be foolish to go with timed. Especially since emergency stopping situation is the biggest reason I have for brakes on a 13 ft. I can slow down, brake early, drive according to terrain and conditions, what I can't do is control everything else on the road.
FAQ: Timer Vs. Proportional Brake Controllers - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Thanks for the feed back, I asked my phone and it just kept prompting me to give it an update.
Old 08-27-2013, 05:37 PM   #46
I actually heard a reasoned argument against proportional brake controllers today. Bear in mind I'm just the person digging up information. Don't shoot the messenger.
The argument is as follows, if TV is skidding how much inertia is the proportional controller getting? None. So when you really need the trailer brakes to kick in while you try and manage the skid it's not going to happen.
Angle and adjustment. If bumped with a leg or knee they don't auto recalibrate so it is possible to have the controller detecting it's "new" position as a small amount of decelaration causing lite but non-stop braking.
Many TV's have a dash very close to the max angle a proportional controller can compensate for, if one does not take this into account inferior performance may be the results. Mounted with only a few degrees of pendulum movement possible they don't work as well.
Not sure if I agree with all that but figured it was worth sharing.
The other suggestion which did make sense is keep my old 4 bolt idler hubs to use as a spare in the event one of mine goes out on the road, not common enough to count on getting a replacement quickly. With bearings greased and ready to go I would lose brakes but would be able to get back on the road.
Old 08-27-2013, 06:40 PM   #47
Brian B-P's Avatar
Originally Posted by RogerDat View Post
... if TV is skidding how much inertia is the proportional controller getting? None. So when you really need the trailer brakes to kick in while you try and manage the skid it's not going to happen.
If a vehicle is skidding, that does not mean it is not decelerating. Does this argument mean the brakes are locked up and tires are sliding because the driver is trying to brake beyond the available traction? If, so the proportional controller is doing exactly the right thing by applying enough power to brake the trailer to match the deceleration achieved, not applying too much power for the available traction and locking up the trailer's tires as well.
So mount the controller properly! This is like saying a poorly positioned gearshift could get bumped and bump the vehicle out of gear, so we should skip the transmission and have only one gear.
Again, just mount it properly.
Modern proportional controllers don't have a pendulum; they use two-axis accelerometers (like the bits inside a modern video game controller, such as the ones introduced with the Nintendo Wii).
Old 08-27-2013, 06:58 PM   #48
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
If the tow vehicle is skidding with full brakes and zero deceleration, then it doesn't matter if the controller is braking the trailer or not. At that point, I would really consider my odds for bailing out.
My prodigy is at a steep angle and applies plenty of braking.
As for being bumped to a different angle, it senses force. Feel free to take mine from an easy 45* and lay it flat, nothing will change.
Old 08-27-2013, 07:02 PM   #49
Regarding skiding trailer: It would depend on whether the skid was sliding sideways or skidding forwards due to too much braking. If you were trying to stop in a straight line and the trailer tires were skidding due to the controller applying too much brake, the lessened traction would cause the controller to see the inertia go down and apply more braking, which would just make the wheels skid more. That is assuming that the controller tries to cause the most inertia by applying more braking force. They may not work that way, I don't know. I adjust my controller so it won't lock up the trailer tires during panic stops with slightly dirty or wet conditions, and it seems to handle just fine.
In the second scenario where you overcooked a corner and the trailer was hung out sliding sideways, I doubt the inertia device would know what was happening unless your forward deceleration was enough to come into play.
braking may not be desired in that case anyway, as it could actually cause more lateral forces or break loose the tires more. I would probably try not to decelerate during a skid like that just from personal experience.
Russ
Old 08-27-2013, 07:04 PM   #50
Jared J's Avatar
Kansas
He said tow vehicle skidding, not trailer. If the tow vehicle is skidding and the controller can't sense it, that means you aren't slowing down. If you aren't slowing down, there is zero grip, and if there's zero grip, who cares if the trailer brakes apply or not? Completely irrelevant.
Old 08-27-2013, 07:15 PM   #51
Brian B-P's Avatar
No, they don't work that way. They respond only to deceleration, so less deceleration (not less "inertia") means less power applied to the trailer brakes.
Right, deceleration along the front-to-rear axis of the tow vehicle (the way the controller is mounted) is all that determines deceleration... regardless of any wild thing the trailer might be doing.
I agree that excessive braking is never desirable in combination with turning. Tires have only a limited amount of traction, and whatever you use up braking is not available for turning, and for keeping the trailer on track. Anyone really interested in this aspect of vehicle dynamics might want to search the ever-helpful internet for a description of the "friction circle"... but this wouldn't be the place to get into much more detail on that!
Old 08-28-2013, 03:10 PM   #52
I think the idea is one might get some braking from the trailer even if TV was not slowing down enough to be detected by brake controller as need for much braking action. Sort of the opposite of problem of timed controller not able to tell that you just hit the brakes hard for a panic stop. It just does it's "set" thing.
Seems to me that ABS brakes might change the decelaration profile during a skid. At least when I tested them on snow they stayed short of a full on zero traction skid for the most part, providing some pulsing deceleration.
Even on snow there is some traction, water over ice might get down to zero. Or hydroplane situation. But even in a skid there is generally some traction to be had.
Mounting properly to get proper function should be a given, I think point was some folks do, some folks don't, folks that don't are better off with a lesser system but one they have less chance to screw up.
If TV hits ice on bridge first the trailer pushing probably would not be a good thing but... I'm more inclined to think typical driving and panic stop use case the proportional would be better, much better. Just the ability to detect I'm stopped and cut power way down while I continue to hold the brake at a light seems "smart".
So the controllers no longer use the pendulum as a detector? Instead using something like smart phone or game controller to detect deceleration.
Old 08-28-2013, 04:15 PM   #53
Jared J's Avatar
Kansas
If the vehicle is slowing down at all, a good controller will know it. I guarantee if you hotwired the brake switch to my prodigy and just let off the gas, it would apply trailer brakes.
Also, it applies slight trailer brakes even if you barely touch the pedal and just activate the switch.
Again, if it isn't sensing deceleration from the tow vehicle, it doesn't matter if it applies trailer brakes or not, nothing is going to help you. A dumb controller would be worse, as it would just stab the brakes on, on the ice.
Old 09-25-2013, 01:45 PM   #54
Axle has arrived! Going to drop trailer in shop next week for installation.
Al-Ko had to create a part number for this bracket configuration, if it installs correctly without modification there will be a source here in Mich for "stock bracket" leading arm replacement axles.
Old 09-25-2013, 05:46 PM   #55
Brian B-P's Avatar
Al-Ko had to create a part number for this bracket configuration...
Excellent. Since the brackets are unique, it would be nice to see a photo of just the axle (especially the bracket area) before it is complicated and obscured by installation
Old 09-26-2013, 06:16 AM   #56
Good Idea! I'll have to make sure I take a camera with me. Hmmm wonder if I will have the time to spray a dusting of light colored paint around the existing bracket and frame to provide for contrast with the new bracket on the frame for an after picture.
axle, scamp
Replacing an Axle - leading arm to trailing arm Roy in TO Modifications, Alterations and Updates 38 11-21-2010 01:00 AM
Replacing leading arm axles Andrew Gibbens Towing, Hitching, Axles and Running Gear 19 07-19-2008 06:48 PM
New Axle -- Leading or Trailing Arm? CliveAlive Towing, Hitching, Axles and Running Gear 3 01-26-2008 12:12 AM
The End of Trailer Trailing? Patrick M. General Chat 40 12-19-2007 10:13 AM
New Axle -- Leading or Trailing Arm? CliveAlive General Chat 0 12-31-1969 07:00 PM
