Scamp Axle repair - Fiberglass RV
Old 06-03-2011, 12:10 PM   #1
Trailer: 13 ft Scamp 1977
Scamp Axle repair
I have a '77 Scamp that is a great tent on wheels, no working frig or heat though I did install a nice new fan on top. It is showing signs of needing a new axle (everything ends up on the floor that is not bungeed down when I travel with it, and the last time I took it to get the bearings greased, they had a very hard time trying to get the wheels off and on).
So, I'm concerned about the axle, but don't want to pay $1,000 (at least) to replace it. Is there any way to improve the performance of the axle without replacing it with a new one? I'm in Santa Fe. Anyone really savvy on axles out there?
Eileen Banashek is offline   Reply With Quote
Old 06-04-2011, 06:37 PM   #2
Administrator
Mary F's Avatar
I'm moving this topic to the Towing forum, in hopes somebody can help Eileen with her question.
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 06-04-2011, 06:52 PM   #3
South Carolina
When they greased the bearings,did they jack it up by the frame or axle?Even if the axle is worn out,if they jacked it up by the frame like they are supposed to the axle should drop down so the tires would come off pretty easily.
Brian Bran is offline   Reply With Quote
Old 06-04-2011, 07:29 PM   #4
There's not much you can repair if it's worn out. I was going to suggest Red Neck Trailer, but I don't see a location in your area. Check to see if you can find a utility trailer builder in your area. Replacing the axle on your trailer (with brakes!) will (should) be $500-$600. I'm sure it's time... your trailer is 34 years old.
Old 06-07-2011, 09:44 PM   #5
Thanks, Brian
I don't remember how they jacked it up, except that it was still hitched to my truck and it looked like it was jacked up at a weird angle.
Old 06-07-2011, 09:46 PM   #6
Donna,
What a great idea! I bet I can find someone in Albuquerque.
Old 06-07-2011, 10:15 PM   #7
LukeP's Avatar
Eileen, you could also call Redneck Trailer's main office (877-9Redneck) and find out the closest independent/distributor to you. The welder who ordered my Dexter axle uses Redneck Trailer to order his trailer parts, and we're a couple hours from the closest actual Redneck Trailer location. So, proximity may not matter - if you can find a local person who uses them. Also, my entire quote was $550 which included welding a couple other items too - so Donna was spot on!
LukeP is offline   Reply With Quote
axle, scamp
Scamp Door Repair and Mods Robert Johans Modifications, Alterations and Updates 20 07-13-2022 03:25 PM
Scamp window repair Brian Bran Problem Solving | Owners Helping Owners 13 06-10-2011 08:49 PM
Scamp Repair on U-tube MyronL Modifications, Alterations and Updates 7 02-12-2011 01:12 AM
Repair on Scamp outside shell re-do? barryra Care and Feeding of Molded Fiberglass Trailers 4 09-24-2010 02:40 PM
Floor repair on '83 Scamp DennisM Problem Solving | Owners Helping Owners 6 05-30-2010 06:35 AM
