Scamp Axle Replacement - Fiberglass RV
Old 06-29-2016, 12:32 PM   #1
Trailer: 13 ft Scamp 1977
New Mexico
I have a 1977 13" Scamp. Needs a new axle. Not sure what weight rating to use. The Scamp Owner's Manual says the 13 footer uses a 2200 pound axle. My trailer has no heater, frig, or toilet and is practically empty when I tow it. Has anyone else replaced a torsion bar axle? What weight rated axle did you use? Any other advice on replacing the axle?
Eileen Banashek is offline   Reply With Quote
Old 06-29-2016, 01:40 PM   #2
None
I replaced the axle on my '99 Scamp 13 earlier this year. I bought the axle from Scamp so that I was sure to get the correct one, plus, they had it in stock and shipped it out within 2 days, I had it within 4 or 5 days. The wait to buy it direct from the axle manufacturer was about 6 weeks.
I had a local metal fabricating company install the axle. I gave them Scamp's customer service number to call if they had any questions. They did, indeed, call Scamp and received all the measurements and suggestions from the Scamp folks to install the axle as a bolt on, instead of welded on. Will make any future servicing much easier. They said the folks at Scamp were extremely helpful. Not certain they would be so helpful if you bypass them for purchasing the axle - just a thought.
Plus, now is the time to add brakes, if you want them and don't have them. Some states require them on ALL travel trailers that use their highways.
Here is the label from the new axle, as you can see, it is a 2200 lb axle.
LyleB is offline   Reply With Quote
Old 06-30-2016, 01:39 PM   #3
New Mexico
Thanks for the advice. Will call Scamp and get the details.
Old 06-30-2016, 03:41 PM   #4
If your axel is welded on, now is the time to have the welder that removes it to raise and bolt on the new one.
Old 06-30-2016, 03:47 PM   #5
Lyle B by any chance do you live in FL. Or better question has anyone replaced their axle in Titusville, FL area and can recommend someone?
Karen Havink is offline   Reply With Quote
Old 06-30-2016, 05:03 PM   #6
Look for the oldest welding shop around.
Old 06-30-2016, 07:10 PM   #7
None
Nope, sorry, Michigan here.
Old 06-30-2016, 07:38 PM   #8
IllAnnoy
Your trailer's original axle was a 1200 pound leading arm axle, but you could upgrade to the 2200 pound axle with no real negative consequences.
Going from a leading arm to a trailing arm would require a little more attention than a direct replacement but that too could be done eventhough they do make a leading arm 2200 pound axle as well.
Old 07-01-2016, 12:30 PM   #9
You can also have an axle made and you can specify the load rating you want.
I had mine made by Flexiride and specified 3000 lb rating instead of 3300.
If the axle is rated too high the ride will be rougher.
In retrospect I should have asked for a 2800 lb axle.
The actual strength of the assembly is the same, but the deflection is less with the higher rating so less movement of the suspension results.
You may prefer the stiffer ride though.
Sent from my SCH-I605 using Fiberglass RV mobile app
redbarron55 is online now   Reply With Quote
Old 09-09-2016, 12:15 PM   #10
New Mexico
Can't read the name of the manufacturer that made the axle. Do you know what state they are in?
Old 09-09-2016, 02:46 PM   #11
Lippert Component Inc.
574/312-6425
Variant # V000213737
S/N 045-0353566
P/N LCI DTB-63-49.75-OD-22U-HPIB-SM-L-545/7 GAWR 2200#
3501 County Road 6 East, Elkhart
Indiana 46514
574-535-1125
customerservice@lci1.com
Old 09-09-2016, 05:05 PM   #12
New Mexico
Thanks so much! I am taking the trailer to a trailer repair place next week to get an estimate.
Old 09-10-2016, 02:02 PM   #13
Trailer: 1977 Scamp 13
I have the same exact model as you. The guy I bought it from replaced the axle with a straight axle and leaf springs. It raised the scamp about 8". It pulls great but it's just too high. I'm replacing the axle with this 4" drop axle—It's only $109.. Trailer Axle 2-3/8" Round Drop 65.25 Hf- 49937 | Round Trailer Axles 2.38 3500lb Drop | Tie Down Eng | TrailerPartsDepot.com
I'm getting it put on tomorrow
michaelcly is offline   Reply With Quote
Old 09-12-2016, 12:53 PM   #14
New Mexico
Let me know if it works for you.
axle, scamp
1984 Scamp 13 Axle Replacement JD Eben Towing, Hitching, Axles and Running Gear 9 08-05-2015 01:18 PM
Best (easiest?) way to lift a Scamp 5er - New axle vs Axle-Less Trailer Suspension dreschool Towing, Hitching, Axles and Running Gear 7 06-26-2015 04:28 PM
Leaf Spring/Axle replacement for a Scamp 13 DanMurphy Towing, Hitching, Axles and Running Gear 8 02-16-2008 01:56 PM
Axle replacement in S. Ontario Roy in TO Care and Feeding of Molded Fiberglass Trailers 4 05-27-2006 06:33 AM
$2000-2500 Axle Replacement? Chris Seddon Towing, Hitching, Axles and Running Gear 16 03-28-2006 01:26 PM
