Scamp Bolt Pattern - Fiberglass RV
Old 01-14-2020, 12:03 PM   #1
Scamp Bolt Pattern
Picking up a 2020 Scamp in April (hurrah!) and am considering bringing up higher quality tires (which I learned about in a different thread) already mounted as the folks in Backus said they would switch them out if I had them ready to go.
I asked them about the rims because I need to know the bolt pattern but did not get a clear answer. Would anyone be able to tell me the bolt pattern? Thanks in advance for your help.
MSFrancis is offline   Reply With Quote
Old 01-14-2020, 01:03 PM   #2
AC0GV's Avatar
Wisconsin
Scamp wheels
I just replaced mine and they were 5 bolt on 4½" (2017 16'). How ever, you should have no problems getting it home with the Scamp tires, the only limit is the 60 MPH speed rating. You will also have trouble finding a 13" USA made tire. (I also have a fear of any tires rated for boat trailers.)
Old 01-14-2020, 01:29 PM   #3
They are 5 on 4-1/2" with ZERO offset. 175/80-13s
When we bought our 13D frontbath, it came with Marathon "B" rated tires which were barely adequate. They no longer even make "B" rated tire, so the factory tires will be fine if properly maintained.
I ran my B tires for 27000 miles at 40PSI (five over sidewall).
I now run Carlisle HDs which are clearly better.
They hold air better, handle better,and wear better.
If you are buying custom wheels go ahead and get tires as well.
Old 01-14-2020, 01:53 PM   #4
Here is the thread that talks about better tires - http://www.fiberglassrv.com/forums/f...m_medium=email
I am planning on buying Carlisle ST17580R13 tires as mentioned by "Lockman".
Old 01-14-2020, 02:59 PM   #5
AC0GV's Avatar
Wisconsin
Tires
P.S.
No matter what tires you use, get them balanced.
Old 01-14-2020, 04:00 PM   #6
Just stop on the way and buy a set of the tires you want.
Old 01-14-2020, 11:20 PM   #7
AC0GV's Avatar
Wisconsin
GOOD ST tires are hard to find
Easier said than done. We are talking the north woods here. My rims came from one state and the tires from another. Even then the tires were one year old, the newest the warehouse had in stock. Unlike the Scamp tires, the new set was ROUND!
Rim bolt pattern? gihuff Problem Solving | Owners Helping Owners 18 07-15-2013 09:50 PM
Bolt pattern for U-Haul CT 13 body to frame. R_ROTTON Problem Solving | Owners Helping Owners 9 10-10-2012 07:47 AM
Bigfoot 17 bolt pattern Dale Mitchell Problem Solving | Owners Helping Owners 7 08-27-2012 09:35 PM
Scamp wheel bolt pattern Brian Bran Towing, Hitching, Axles and Running Gear 6 05-08-2011 05:39 PM
What is the bolt pattern on a Casita? BAMA & Pachyderm Posse Care and Feeding of Molded Fiberglass Trailers 1 01-11-2010 05:15 AM
