Scamp Not Level Towing - Fiberglass RV
Old 05-09-2019, 05:12 PM   #1
barryra's Avatar
Trailer: 1993 13 ft Scamp
I bought a 98 Chevy Silverado & notice tilts up a little at the hitch. Will this be a issue or should I find a ball that's lower? Thanks
barryra is offline   Reply With Quote
Old 05-09-2019, 05:27 PM   #2
Trailer: 1999 Casita 17' SD
Ohio
Get a lower "stinger" so your trailer rides level when yout Silverado and trailer are loaded.
Old 05-09-2019, 05:34 PM   #3
I use a 4 inch drop on my F150 when pulling my Trillium, while I use a zero drop when pulling my Escape 19. If the trailer is tipping up, your tongue weight is likely to be way low, which will lead to serious problems.
thrifty bill is online now   Reply With Quote
Old 05-10-2019, 10:32 AM   #4
Trailer: BigFoot
Load your truck with the stuff you will be taking camping. It may be enough to level the tongue.
Or put larger diameter wheels and tires the trailer plus the above. I can't get enough trailer height.
Rzrbrn is offline   Reply With Quote
Old 05-10-2019, 11:15 AM   #5
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
There is a limit! I know a guy here in town who jokes that he needs to lift his truck to get his trailer level. The previous owner put a huge lift on it. He pulls with a full size 4x4 Chevy and it's not nearly tall enough.
This is all beside the point but as someone who takes my camper down some pretty crazy roads, I've found that any road requiring more clearance than my camper has after swapping out the drop axle for a straight one is not a road I should be hauling a camper down. If I really want to camp down those roads, I'll leave the trailer at home and bring my tent and cot, like I did this spring in the desert.
Old 05-10-2019, 11:25 AM   #6
Trailer: BigFoot
I suggested lifting the trailer, not the truck.
I have gone into more than a couple of gas stations that caused my lifted Casita to drag it's tail. These were in a towns out west. One entry was so bad I had to take it at an angle, and even then it was close.
The other times were mostly in CA. They have some of the most rugged roads in the primitive campsites I have encountered. Both State and Federal. It is like they are almost forcing people to go to private campgrounds.
Old 05-10-2019, 01:37 PM   #7
Trailer: Casita 17 ft SD
Scamp hitch level
When I traded tow vehicles, my replacement vehicles hitch was two inches higher than the old one. The result was going down the road everything was fine until I went above 58 MPH. At that point the Casita started to sway. It swayed slowly at 59 MPH and as the speed increased above 59 the sway speed accelerated.
So I raised the Casita four inches because I like dry camping on BLM land. That is the expensive way of fixing the problem. I'm very happy with the extra clearance I got by raising it. I then installed 225R75 15 inch tires with load range D which solved the tire blowout issue. Haven't had a tire problem since.
ehoepner is offline   Reply With Quote
Old 05-10-2019, 01:51 PM   #8
ZachO's Avatar
Montana
Exactly what I'm saying: There's a limit to how high you want the trailer. You go too high with the camper and you'll need to lift the truck, too. My post might be confusing the way I wrote it. My point was that the trailer has a huge lift, so he jokes that his truck needs a lift to match. He's nowhere near level. And yeah, I get it. My Bigfoot easily clears any kind of pavement conditions with the 4" lift the new axle gave it, but some of the dirt roads I drive still scrape it a little. With where it's currently at, though, it's plenty high. Any road pushing my clearance limits is a road I should avoid.
If you're still scraping going in & out of parking lots I agree, you could use a 2-4" lift. Most of these trailers come way too low. A small lift takes care of it. Too much lift and you're creating a whole new list of problems.
Old 05-11-2019, 06:52 PM   #9
Name: Daryl and Wendy
Trailer: 1973 Trillium 1300
adjustable ball mount
We purchased a $30 adjustable ball mount. With some 16 possible settings; one is likely just right, and it is quickly adjustable to add or remove clearance at the rear bumper.
the Trill is gone
Daryl and Wendy is offline   Reply With Quote
Old 05-15-2019, 02:35 PM   #10
Doctor Harold's Avatar
Trailer: 1975 Scamp, 13-foot
Redding, California
I took my Scamp to a local trailer specialist that mostly works on semi trailers, but they are also Dexter Axle dealers. I was concerned I needed a new axle on my 1975 Scamp.
The guy jacked up the trailer on each side and said since there was no movement I didn't need an axle. I'm not confident that he was being truthful -- maybe he just didn't want to work on my trailer, or maybe I'm paranoid.
Anyway, I had a generic, no drop stinger, and the Scamp was fairly nose up. I said to the guy: "I guess I just need to get another stinger so it rides more level." He said pulling it that way wasn't a big deal, so why bother?
Okayyyyyy.... I think a trailer should ride fairly level, so maybe that's why I'm questioning his advice on not needing a new axle.
Of course I know if I ask enough vendors, eventually someone will sell me an axle whether I need it or not.
Harold
You cannot have a proud and chivalrous spirit if your conduct is mean and paltry; for whatever a man's actions are, such must be his spirit. --Demosthenes
Doctor Harold is offline   Reply With Quote
Old 05-15-2019, 03:09 PM   #11
My thinking is just the opposite. If there is no movement when you jack it up then your axle is dead. It’s supposed to be a suspension. So handling the entire weight of the trailer should compress it. When you jack up the trailer you are taking the load off the axle.I’ll let the experts weigh in.
Check my Trillium Project Page: https://www.facebook.com/Bills-1977-...dmin_todo_tour
Old 05-15-2019, 03:33 PM   #12
Trailer: BigFoot
You should have level or somewhat nose down, and don't forget 10% to 15% of the weigh of the trailer should be on the nose.
Also when you load your truck try to keep most of the heavy stuff over and forward of the rear axle.
I am not sure what you guys mean when you say there is no movement when you jack it up. Are you are talking about a Dexter torsion axle or a Dexter axle with leaf springs? What is not moving?
Thanks for posting, interesting thread.
Old 05-15-2019, 05:05 PM   #13
Redding, California
Originally Posted by thrifty bill View Post
My thinking is just the opposite. If there is no movement when you jack it up then your axle is dead. Itís supposed to be a suspension. So handling the entire weight of the trailer should compress it. When you jack up the trailer you are taking the load off the axle.Iíll let the experts weigh in.
That's exactly what I thought. No movement means a dead axle, and one that flops up and down is no good either. It should act like a spring. My Scamp has the torsion axle, and I think it might actually be original.
Harold
Old 05-15-2019, 05:44 PM   #14
I am ass-you-me'ing that it means the gap between the top of the tire and the bottom of the top of the fiberglass body is not changing. But hey, that's a guess on my part.
Unloading the wheel (jacking up on the frame), the wheel should not go up as fast as the jack as it goes from supporting 750 pounds to supporting just itself. Even on my 42 year old axle, I get some movement in this regard.
Level Commander II 1985 bigfoot tank level indicator evenweight Electrical | Charging, Systems, Solar and Generators 0 04-14-2017 09:27 PM
Why not just level with a jack? Timber Wolf Care and Feeding of Molded Fiberglass Trailers 81 06-16-2015 08:57 PM
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
Tongue-weight and level when towing Bobbie Mayer Problem Solving | Owners Helping Owners 7 09-08-2007 12:27 PM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
