Scamp tire wear - Fiberglass RV
Old 06-04-2013, 05:57 PM   #1
MyronL's Avatar
Trailer: Escape
New Mexico
Scamp tire wear
After 2 thousand plus miles of pulling the Scamp I parked it out back and forgot about it. Now, six months later, the trailer is back on my “to do” list. Cleaning out, tightening up, etc.
The tires! Couldn’t believe what I saw. But, before I go buy new tires I got to know what causes this kind of awful wear.
Could it be a worn out 3000 pound Scamp axle? Old axles make me nervous. Besides being rusty the torsion bar suspension doesn't look worn and crooked to me. But is it? Could it be wheel bearings, unbalanced rims? First instinct was to panic and replace everything under there. This is an ’86 and everything is screaming old, old, old. Yet, that formidable old Scamp axle is welded to the frame. Have not detected any cracks, twists, or whatever else might contribute to the issue. What did this? Tires are Carlisle ST 175/80D13 Sport Trail. About 6-7K miles on them I think.
My forum search was inconclusive. Do not want to fix what ain’t broke. Opinions anyone?
MyronL is offline   Reply With Quote
Old 06-04-2013, 06:26 PM   #2
That is really bad. I would guess unbalanced and out of alignment but if it were me I would email the pictures to Dexter Axles and ask them. Get the answer straight from an axle company and take the guesswork out of it. Good luck and please post what U find out.
Old 06-04-2013, 06:30 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Looks like balance issue to me. You may need an axle if there is no suspension travel left. A welded on axle can easily be removed and replaced.
Old 06-04-2013, 06:39 PM   #4
The arm on our camper is angled down and yours are level. Look inside your wheel wells to see if the tires have rubbed up top side. It could be that the flex axle is worn out.
Old 06-04-2013, 07:20 PM   #5
Humm, the tire is cupping. Cupping can be caused by an unbalanced tire condition, faulty wheel bearings, loose parts, or bad axle.
So, are the tires balanced? When was the last time the bearings had maintenance? Is this an original or replacement axle? (I see what you've written about the original axle).
I replaced a 20 year old axle in my 88 Scamp five years ago because it started eating tires. YMMV
Old 06-04-2013, 07:22 PM   #6
The wear is on the outside of the tread, no wear in center. I would say under inflation is a probable cause.
Old 06-04-2013, 11:22 PM   #7
Brian B-P's Avatar
The arm angle means nothing about the state of the axle unless you know what it should be, which requires knowing the start angle. I would jack up one side and remove the wheel, then look at the arm where the square bar comes through - then I would see if the bar is permanently rotated and what the start angle is. Dexter Axle charts show the arm angle under full load, to be compared with the observed level attitude.
I described this several years ago in post #8 of When do drooping axles need a lift?, but since then it seems that most people seem more interested in wild guesses than actually seeing their axle configuration and condition. I don't know why.
As for the tires... sure, out of balance seems like a reasonable guess. Now that they are worn this way they presumably will be out of balance, even if they were not to start, making diagnosis less certain.
Old 06-04-2013, 11:42 PM   #8
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
That is EXACTLY the look of our brand new & balanced tires about half way into our 2 month trip last summer. I placed the new spare to finish the trip, but it ate the tire the same way (bearings were fine and adjusted properly). My 1990 Scamp had the old style leading arm set-up, and I had the axle changed out to the current scamp style trailing arm set-up, but used a Flexi-ride axle. New tires again, and no unusual wear.
Good luck
Dave & Paula
Old 06-04-2013, 11:52 PM   #9
Good luck
Dave & Paula
Dave, I'm curious. Did you tire wear on outsides of the tread and leave the center alone. It looks that what happened the center seems to be normal wear or lack thereof. but the edges seem worn pretty bad.
Old 06-05-2013, 12:16 AM   #10
Myron as others have said lots of things can cause that type of wear. Did you have the wheel bearings checked and repacked prior to your trip? How old are the tires? Hard to tell on your small profile photo but the trailer looks to be riding a little low, which could indicate the axle is done. How much clearance do you have at the top of the tire to the wheel well?
Old 06-05-2013, 12:29 AM   #11
David B.'s Avatar
Trailer: Lil Snoozy
Byron, I wish my memory would kick in as to exactly what the wear pattern was, but when I saw Myron's picture, my stomach reacted as it did when I discovered our ruined tire on our trip. From what I remember it looked exactly like Myron's picture. I believe that the worn leading axle design would allow the spindle/wheel to spread either out or inward, causing the scrubbing of the tire. Have you ever tried to push an oxygen tank caddy or a carry-on suitcase instead of pulling one? The forces of trying to keep a nice straight tac are tiring.
You can quickly see the advantage of a trailing arm system.
Old 06-05-2013, 12:49 AM   #12
There's lots of unwanted forces in leading arm systems. Braking wants to lift the trailer, which I suppose could cause bouncing. The wear looks like under inflated and bouncing to me.
Old 06-05-2013, 12:16 PM   #13
MyronL's Avatar
Trailer: Escape
New Mexico
This is interesting: I dug up the original Scamp owners guide. It provides general information on the trailer.
Under the sub-title "Running Gear- Axle":
"...the 16 foot and 5th wheel use a 3000 pound axle with 10 inch electric brakes. This type of configuration allows each spindle to operate independently of the other. Each spindle is set at 1/4 degree toe in, and 1/4 degree camber. Toe in and camber can eventually go out of adjustment, especially on curb side of vehicle...if unusual tire wear is noticed on one side of the tire this is usually the problem. Have axle checked at an alignment shop and corrected if necessary."
  • Carol I thought it was riding a little low too, but picture indicates no clear evidence of issues in the wheel well. Was no play in the hub, suggesting the bearings are good. They were well packed.
  • Brian with wheel removed everything with the axle is looking normal to me. But of course I have no idea what is normal here.
  • Byron, Donna, Darwin, Thomas, David: along with Scamp's suggestion on axle allignment, wheel balance and underinflation is also looking to me like a prime perpetrator.
Guys, your input is very muchly appreciated. The wheels are off, I'm ordering new tires, and (damn!) seriously considering replacing the hubs and wheels, since they may not be involved in the problem but for some reason they are 4 bolt instead of 5 bolt.
I need a money tree.
Old 06-05-2013, 12:30 PM   #14
Myron, the bottom photo of your wheel well sure looks to me as if the tire has been rubbing on it. No idea if true or not but I was told when I got my old trailer to keep an eye on the tire clearance and make sure there was at least a full hand width of clearance at the top of the tire to the top of the wheel well as once that clearance is gone its time for a new axle.
Tire wear Darrel Smith Towing, Hitching, Axles and Running Gear 6 07-04-2011 12:59 PM
Tire Wear Alan P. Towing, Hitching, Axles and Running Gear 5 08-23-2008 10:14 PM
tire wear gregshannon Towing, Hitching, Axles and Running Gear 15 08-13-2007 01:29 PM
tire wear Chris Z Towing, Hitching, Axles and Running Gear 6 06-27-2006 02:21 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 27 04-16-2003 10:02 PM
