I tried to use the same #37595 7 blade to 7 pin adapter, also purchased from Northern, and found it is not compatible with the wiring scheme on a 1994
Scamp 5er. If I recall correctly the tow vehicle aux power was connected to a
Scamp tail
light, and one of the turn signals was connected to the
Scamp running
lights. I'm not sure what would have happened if I would have pressed the brakes!
Rather than trying to figure out which wires were crossed, I just cut off the 7 pin plug that was on the Scamp and installed a standard 7 blade plug. The adapter went back to Northern.
Pat
Wow! My first MFROG post!
