Scamp wiring connector pin-out? - Fiberglass RV
Old 05-12-2015, 04:12 PM   #1
Trailer: 2012 Scamp 13', "Eggcentric"
Wisconsin
What is the correct pin-out on a 2012 13’ Scamp? The connector on the Scamp is a standard 7-conductor blade type, but Scamp’s online manual illustrates wiring for a J560 7-conductor pin-type connector. My new tug (a 2015 Toyota Tacoma) came with a tow package that includes a 7-conductor blade type receptacle which would accept the plug on the Scamp. Blade-type and pin-type connectors are similar but they’re not compatible - they look like this:
Blade type 7-Way
/ \ Tail / Power
| O | Left / Backup /Right
\ / GND / Brakes
J560 Pin type 7-Way
O GND
o o Tail / Backup
o Brakes
o o Right / Left
o Power
I suppose that I could just plug the Scamp into my truck and see what works, but it’s cold and raining and it’s much more comfortable to sit indoors and ask the experts.
Thanks in advance!
Hobo
hobofoto is offline   Reply With Quote
Old 05-12-2015, 04:18 PM   #2
If Scamp shows a pin configuration and there is a blade type installed, it sounds like a P.O. may have changed the connector, in which case what "the experts" think has little if any value and can only be a guess.
I think all will be known when you plug it in. I have very seldom found a mis-wire in blade to blade connections, but there can always be a first time.
And, if you have been following recent posts about Scamp, hard telling when they changed to blade connectors, much less when the manual will match what's sold.
Old 05-12-2015, 04:34 PM   #3
Wisconsin
Thanks Bob! That was pretty much what I was expecting. I doubt that the previous owner changed anything - in fact, I doubt that they ever took it out of their driveway. I was surprised that the Scamp manual illustrated the wrong connector, but I'll figure things out after it stops raining. Or snowing. Yuck.
Old 05-12-2015, 05:02 PM   #4
IllAnnoy
Your 2012 Scamp came with a standard 7 blade RV connector.
They used the pin type a couple of decades ago, the old manual was placed online without correcting it. My 2004 has the same error in the printed owners manual.
Old 05-12-2015, 06:34 PM   #5
Dennis mn's Avatar
I have attached a copy of the page Scamp provides when you buy a new 5er. They e-mailed it to me when I had an electrical fire last winter.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 05-12-2015, 06:37 PM   #6
Dennis mn's Avatar
The photo did not attach.
Old 05-12-2015, 07:15 PM   #7
Wisconsin
Thanks Floyd - I wish Scamp would keep the manual a bit more current.
Old 05-12-2015, 07:17 PM   #8
Wisconsin
Thank you Dennis! Exactly what I wanted!
I hope the weather is better in Minnesota than it is in Wisconsin.
Old 05-12-2015, 08:03 PM   #9
Dennis mn's Avatar
You're getting the weather we had yesterday. I didn't complain because we needed the rain.
I also bought a new tow vehicle this spring that also had the tow package. Next week the fifth wheel rails should arrive and be installed, and I can modify the Scamp hitch to fit the Reese Rails. Then I'm rewiring the trailer including a new cable from the the truck.
Old 05-12-2015, 08:32 PM   #10
Note that the color codes and pins in the two examples shown do not agree with each other. I have always use the color code and pins that Floyd posted and that always matches with a 7 pin light checker that I can plug into the TV's outlet.
Old 05-12-2015, 09:06 PM   #11
Dennis mn's Avatar
The pin usage appears to be the same between the two diagrams, therefore, your pin light checker should work with either. I don't know why Scamp uses a non standard color code, but I'm pretty sure that Scamp's diagram matches my trailer.
I just checked the pin/color code of the trailer side preassembled cable. It matches the Scamp arrangement and color code!
Old 05-13-2015, 10:15 AM   #12
Trailer: 1999 Casita 17' SD
Ohio
Both Casita and Scamp at one time used the "Heavy duty Truck" plug and color coding that used round pins.
But at least as far back as our 1999 Casita has been using the newer "Standard RV" color coding where "GREEN" has been tail and running lights and has flat pins.
One of the manuals on the Casita Forum had until recently the older incorrect color coding shown also. (there are two and they now both are correct)
What Floyd shows is the "heavy duty truck" color coding and not the current RV STANDARD color coding that is what
What Dennis shows is the RV STANDARD color coding used as least as far back as 1999 on Casita trailers and is shown in the Casita manual correctly.
I can't say what scamp uses now or then
Old 05-13-2015, 10:33 AM   #13
FYI The pin out is "industry standard". Meaning that you can find the colors and pin location in many many places. It takes a quick google search to find it. I don't know when it introduced as industry standard. But it's been in use at least since 2005, my 2005 truck was factory wired with this standard. If you were wiring a connector today this standard should be used. STANDARD is the key word.
Old 05-13-2015, 10:36 AM   #14
RE: Color Code
Just yesterday I finished wiring up tail and running lights on a trailer and, using all new wire and lights, here is what I found:
The left tail light had a brown and a yellow wire (Tail + Left Stop/Turn)
The right tail light had a brown and a green wire (Tail + Right Stop/Turn)
The 4-Flat wire I used was pre-stamped the entire length of the wire as follows:
White = Ground
Brown = Tail
Yellow = Left Stop/Turn
Green = Right Stop/Turn
This ran to a j-box to meet up with the pre-wired 7 pin cable & connector from the TV, and matching color to color there everything worked perfectly.
The fact that two different color codes exist is confusing, but I will stick with the code that Floyd posted.
This is not to say which one is OLD or NEW, but this is the color code that wire and lighting manufacturers appear to be using.
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Towing, Hitching, Axles and Running Gear 5 04-20-2008 02:11 PM
Yellow wire on 7 pin connector ? Mikeny Towing, Hitching, Axles and Running Gear 2 04-13-2008 01:22 PM
Wiring 04 Highlander to 7 pin Bargman connector Gary Little Towing, Hitching, Axles and Running Gear 18 06-02-2006 07:46 PM
Yellow wire on 7 pin connector ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
Blue wire on 7 pin connector shows 12v all the time ? Mikeny Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
