Scamp wiring harness - Fiberglass RV
Old 07-24-2014, 12:48 PM   #1
AKscamper's Avatar
Trailer: 1987 Scamp 13'
Alaska
Anyone know the wiring diagram for a Scamp trailer? It's a 1987 13' and has a 6-wire harness: yellow, red, green, black, white & brown. White is the ground, I'm pretty sure red is the left turn signal, after that I got confused...
I was trying to wire trailer to my flat four on my car. Are Scamps wired to allow my car to charge the 12V battery? If so, do I need to convert my car from the flat 4 to something else?
Name:	ImageUploadedByFiberglass RV1406227560.626882.jpg
ID:	74044Click image for larger version
Name:	ImageUploadedByFiberglass RV1406227575.082937.jpg
AKscamper is offline   Reply With Quote
Old 07-24-2014, 12:53 PM   #2
AKscamper's Avatar
Alaska
I don't have trailer brakes, can I just use a flat four to six pin adapter?
Old 07-24-2014, 01:26 PM   #3
Usually white is ground (10 gauge wire), black is to charge the battery (+) and is 10 gauge wire- tho it looks like your red wire is the 10 gauge, yellow is left turn and stop lights(14 gauge wire), green is rt turn and stop lights (14g), brown is tail and running lights (14g). Blue is the only 12 gauge wire and would be for trailer brakes. If you want to ditch the charging, then yes you can wire to a 4 pole.
Lightrain is offline   Reply With Quote
Old 07-24-2014, 01:58 PM   #4
Roy in TO's Avatar
Fiberglass RV - Document Center - WiringDiagram_Scamp
Old 07-24-2014, 02:05 PM   #5
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
Old 07-24-2014, 02:35 PM   #6
AKscamper's Avatar
Alaska
Thanks, got it figured out. Not charging battery when I drive yet but all trailer lights work. Only thing that doesn't happen is the lower light bulb in the tail lights never come on. The upper ones do and light up brighter when I brake. I know the bulbs work.
Old 07-24-2014, 02:40 PM   #7
Byron Kinnaman's Avatar
Attachment 74044Attachment 74045
Go to the Document Center on this site and you'll find a full and complete wiring diagram for Scamp and wiring diagram for the 7 pin connector.
Old 08-03-2014, 07:02 AM   #8
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
IMHO, car + scamp = trailer brakes, period. I lost brakes on my empty 2,000# car trailer behind my pickup and it was obvious it was back there. Not dangerous under normal conditions, but obvious. I was glad to get home without somebody doing something stupid in front of me.
I had a guy try to cross the road I was on, but he couldn't make it across due to traffic going the other direction, so he just stopped and blocked both lanes on my side. It was a miracle I missed him, I stopped inches from his drivers door. The guy next to me just crushed the side of his pickup bed in. I was damn happy I had good brakes on the scamp. Going full manual on the brake controller while driving down the road will put your head in the windshield.
scamp
Time to wire up a new harness aznative Problem Solving | Owners Helping Owners 9 04-16-2014 02:13 PM
Which harness Andre D Towing, Hitching, Axles and Running Gear 6 10-19-2008 02:51 PM
wiring harness blues ted saxton Care and Feeding of Molded Fiberglass Trailers 7 01-18-2008 11:27 AM
Tow Hitch & Relay, Harness Questions V'sGlassSleeper Problem Solving | Owners Helping Owners 4 07-07-2007 08:32 PM
wiring harness plug in Legacy Posts Problem Solving | Owners Helping Owners 3 12-16-2002 01:04 PM
