Single axle tire safety - Page 4 - Fiberglass RV
Old 03-10-2012, 06:20 PM   #43
Bill MacDermod's Avatar
Trailer: 1999 17 ft Casita Spirit Deluxe ('Inn EggsIsle')
Originally Posted by john warren View Post
god bless you for saying that.....from a fellow with a 23 y.o. brain that writes checks his 61 y.o. butt can't cash.
61 years huh???, like I said a young fella, when I turned 70 I still didn't mind a flat tire now and then, but at 75 I have to depend on reliability
Bill MacDermod is offline   Reply With Quote
Old 03-13-2012, 12:58 AM   #44
My newly aquired 16' 2003 Scamp's tires look new with no wear. I figured the previous owners didn't use the trailer much. The tires could be 10 years old though. The rubber is soft and semi-glossy, which means not much sun has shone on the tires. More than the age I am more concerned with the weight carried by the tires. My trailer weighs about 2750 loaded for camping. The tires if I remember right are rated for 1300-1400 lbs. This allows for no safety factor, or increased loading from cornering forces etc. I would feel better with a more robust tire for my rig. Rather than replacing the Marathons with like tires, I think I'll research some alternatives. Meanwhile I will be very careful checking the inflation, as soft tires build heat, and heat will fail a tire.
Russ
Old 03-13-2012, 08:38 AM   #45
honda03842's Avatar
Name: Norm and Ginny
Heavy Scamp
Russ, here's our experience. I do realize tires are a touchy area on the site.
That's definitely a heavy Scamp. Ours weighs 2400 pounds loaded for 11 months of travel. We also have 13" Marathons. Though our Scamp is not as heavy as your Scamp my plan is to go to 14" tires when the tires are a little older to provide extra margin.
I keep the tire pressure around 46 psi. I also have tire pressure sensors and temperature sensors on my Scamp's tires. Tire temperature increase is a measure of how hard the tires are working.
I will say our trailer tire's temperature's do not go up as much as the tow vehicle's tires. Our tow vehicle's tires go up about 10 degrees higher than the trailer's tires.
Though our trailer weighs 2400 pounds, 200 of those pounds is not on the trailer's tires but rather the 200 pounds is on the ball.
We previously towed a Casita that weighed about what your Scamp weighs with 13" Marathons and had no problems.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 03-13-2012, 11:01 AM   #46
Norm & Ginny,
My trailer has most all factory options, plus a few added options by me. I am interested in 14" wheels and better tires if they will fit into the wheel wells. Your pressure sensors are a great way to keep tabs on tire conditions, as a low tire will fail at high speed. I inflate the trailer Marathons to the maximum cold pressure as I am interested in max load carrying and don't care about plush ride.
Russ
Old 03-16-2012, 06:56 PM   #47
Trailer: Casita 16 ft
I've had 4 flats in 13 years of towing a Casita and every time I didn't know it was going flat until I saw bits of rubber flying off of it. Last one, I went 5 miles on the rim before I stopped and saw the tire was gone. With a full size p/u, aren't too scary unless it was in the middle of a sharp turn, etc.
Come to think about it, they were all on the passenger side. Too close to the curb? Running thru the debris on a right turn?
Went to 14" tires from 13", that helped a lot.
Friz is offline   Reply With Quote
axle
tandem axle vs single axle trailer Wayne Hill Towing, Hitching, Axles and Running Gear 26 07-17-2012 10:39 PM
2 or 4 wheel chocks for a single axle trailer? JohnF Towing, Hitching, Axles and Running Gear 36 11-05-2011 12:12 PM
SAFETY Recall of Metal Tire Valve Stems bobinyelm General Chat 2 09-11-2009 06:53 PM
Tandem or Single Axle? Dana T Towing, Hitching, Axles and Running Gear 19 03-27-2009 04:54 PM
trailer weight , tire pressure , sagging axle Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 05-17-2003 11:40 AM
» Trailer Showcase
Midlife Crisis
Tezha
TBD
Andi
