Size of wheel bearing seals - Bigfoot - Fiberglass RV
Old 06-14-2010, 12:04 PM   #1
Trailer: 1991 17 ft Bigfoot / 2005 GMC Sierra
Hi,
I have a 91 17' Bigfoot trailer with a single axle - does anyone out there know what size wheel bearing seals it needs? Everyone tells me to take a measurement from the old seal but I have a friend coming in to help me and I would like to get the part before the store closes. Yes, I know it has to be the exact right size and if I have to go back to get other seals thats fine - just don't want to waste my friends time if possible.
Thank you!
Carol Crawley is offline   Reply With Quote
Old 06-14-2010, 01:22 PM   #2
You might try looking for a tag on the axle for a make and model, then go to there web site.
Just a thought.
Bill K
Hi,
Thank you!
Old 06-14-2010, 02:48 PM   #3
IllAnnoy
Hi,
Thank you!
Clean the seal with solvent and take a close look, most of them have a number stamped in the face in <sub>tiny print......
</sub>
Old 06-14-2010, 02:53 PM   #4
IllAnnoy
The inboard bearing should dictate the seal size since axle spindles and brake drums are pretty much standardized.
Old 06-14-2010, 05:48 PM   #5
Trailer: 1993 Bigfoot 17 ftCB / 2011 Toyota Sienna
Carol;
My 1993 Bigfoot 17CB using the ST205/75R14 tires has the following bearings:
Grease cap 1.986" Dia.
Inner Bearing L68149 (Race (if needed) L68111)
Outer Bearing L44649 (Race (if needed) L44610
Grease seal ID 1.72" OD 2.565"
I hope this helps!
Mike .....>
Hi,
Thank you!
Michael Pupeza is offline   Reply With Quote
Old 06-14-2010, 06:34 PM   #6
TonyB's Avatar
Trailer: Bigfoot 19 ft (B19)
Hi,
Thank you!
Hi Carol the seals in my 1989 19' Bigfoot are SE-22EZ, I got them from Princess auto. My axle is a Standens 3500 Lb 10x2 1/4" (Duel axle on mine).
TonyB is offline   Reply With Quote
Old 06-14-2010, 06:36 PM   #7
Carol;
I hope this helps!
Mike .....>
Thank you, Mike!
Exactly the info I was looking for
Carol
Old 06-14-2010, 06:56 PM   #8
TonyB's Avatar
Carol;
I hope this helps!
Mike .....>
I just posted this word of caution in another thread. The inner races on my 1989 19' Bigfoot are L68110. I have in the past confirmed this with Standens (The axle supplier). I don't know what years this was the case.
Old 06-14-2010, 11:03 PM   #9
Hi everyone,
All your information helped me, it turns out that the part store could only give me a part if I knew the part number. So after getting home and watching many youtube videos on regreasing bearings, we took the wheel off and popped the cap off - and behold it looked like the bearings had just been done - so when my friend came down he checked it over and said it was fine. We bought the trailer two years ago and have only used it about six times but I didn't know what the previous owner had done, I figure better be safe than sorry. We plan to go on a long trip with it and so I feel better that I know. It would have been out a few dollars if I had taken it to a garage.
Thanks so much!
bigfoot
Interior height and bed size in Bigfoot 5th wheel? Lizbeth General Chat 6 09-17-2008 11:41 PM
Wheel seals for 1974 trillium 4500 Jet Rosas Towing, Hitching, Axles and Running Gear 8 04-29-2008 04:00 PM
Wheel Bearing Check Anders Laurits General Chat 7 12-16-2007 08:05 PM
Wheel seals for 1974 trillium 4500 Jet Rosas Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
