So you think you don't need trailer brakes? - Page 3 - Fiberglass RV
Closed Thread
Old 12-18-2011, 03:22 PM   #41
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Originally Posted by Bruce Thomas View Post
usually you'll see those long marks just before an exit...lotta "tractor" owners pulling freight decide its easier to apply the trailer brake(they have a lever) than put wear and tear on their own stuff.....so they drag the trailer, lotta times causing those long stripes you see. Thats alot more common than anything breaking and applying the brakes
After 23 years of driving semi trucks and two of those leasing my own truck I never drug the trailer tires like that, the valve we call a trolley valve does only apply the trailer brakes and a lot of drivers do use it to save there brakes but if they are dragging those 8 trailer tires all the time they are pretty stupid.
Greg H is offline
Old 12-18-2011, 04:19 PM   #42
Here it is......
Federal Motor Carrier Safety Regulations 393.43 paragraph (d)
NOTE: There is no reference to heavy trucking.
Here's a link to brochure put out by the Missouri Highway Patrol. Link
I think there is,reread my comment #33, when was the last time you slept in your Scamp?
You are right , it is not hard to google since that is the exact script which I quoted in the first place. It must be just hard to read, or interpret.
Still, we digress since I said originally..."So, according to the link..."
It is an interesting question with different conclusions, but as you say you are covered.
Revisit...
I just checked what I could find on Illinois breakaway switch requirements...
"RV Safety Requirements: Safety chains and flares required on all trailers. Trailers over 3,000 lbs.: trailer brakes. Over 5,000 lbs.: brakes on all axles and breakaway switch."
Recreational Trailers under 5000# require no breakaway switch.
floyd is offline
Old 12-18-2011, 04:24 PM   #43
Bruce Thomas's Avatar
Trailer: U-Haul CT13
thing is...thats usually what lays down the patches near exits, I drive trucks too and have seen lots do it. It's stupid but they do.
Bruce Thomas is offline
Old 12-18-2011, 06:54 PM   #44
Trailer: U Hall VT
http://www.fiberglassrv.com/forums/f...rld-43010.html
These are the weights they will go by for the breaks
Roger Kimble is offline
Old 12-18-2011, 07:44 PM   #45
Actually I think they will go by the weight allowed by the registration, at least here in Illannoy.
floyd is offline
Old 12-18-2011, 07:55 PM   #46
Joy A's Avatar
Yeap, that's why I got away with no brakes when I registered my trailer. They just looked at the paperwork from the factory. Had they weighed my trailer I would have had to put brakes on before registering it, rather than some 6 years later by my choice. Big difference between shipping weight 950 lbs. and actual weight 1700 lbs.
My Dad said trailer manufacturers were notorious for weighing trailers virtually empty. He thought the 950 might be simply the frame and shell with axle & tires. Probably no interior cabinets, appliances or other options.
Joy A. & Olive
and "Puff", too
Fulltime
2019 Ram Longhorn
Joy A is offline
Old 12-18-2011, 08:17 PM   #47
Borden's Avatar
Name: Borden and Carole
As floyd stated chains, breakaway switch and brakes. A lot of smaller bolers and others are under the 3000 lb requirement but then we still have the 50% rule and was it manufactured with brakes rule.
In Ontario Canada the brake rule is;
(Trailer Brakes
HTA 64, Reg. 587
Every trailer that weighs, whether loaded or empty 1,360 kg (3,000 lbs.) or more, when attached to the towing vehicle, must have brakes adequate to stop and hold the vehicle.)
Also from other sections;
If the trailer weighs, whether loaded or empty 50% or more of the towing vehicle weight the trailer must have brakes adequate to stop and hold the vehicle.
If the trailer came from the factory with brakes, they are then required.
Still I do personally believe if the load is 500 lbs or more it is a great idea for safety reasons to have brakes.
P.S.
Hard as it is at this time of year Donna, personally believe you did the right thing by fixing the brakes.
Our postage stamp in heaven.
Borden is offline
Old 12-18-2011, 09:19 PM   #48
(Trailer Brakes
HTA 64, Reg. 587
P.S.
I'm not opposed to any of these but what does this refer to...
"As Floyd stated chains, breakaway switch and brakes."
I don't have a breakaway switch, but I do have brakes and chains on my 13 Scamp. In fact I have modified the stock chain arrangement to make it two separate chains of a larger size, which could be crossed to form a catch basket in case of hitch hop.
As for the switch... they are cheap, so if you want one, get one.
floyd is offline
Old 12-18-2011, 10:22 PM   #49
Revisit...
Many laws that are in the sections for commercial carriers are applied by enforcement to all trailers.
If your trailer breaks away and no breakaway system, you could be in trouble.
Byron Kinnaman is offline
Old 12-19-2011, 10:42 AM   #50
Trailer: U Hall VT
Breakaway, I'll use it hookin and unhooking, it's handy
Closed Thread
brakes
Trailer brakes... Jan Adams Towing, Hitching, Axles and Running Gear 4 12-04-2011 03:02 PM
Do you have brakes on your 13' trailer? Cam A Towing, Hitching, Axles and Running Gear 64 02-11-2008 10:40 PM
Trailer Brakes Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 4 01-02-2008 01:36 AM
Trailer Brakes Jen'nBarb General Chat 9 08-20-2006 11:53 PM
Trailer Brakes Pete Dumbleton Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
