solo hitch alignment system - Page 2 - Fiberglass RV
Old 03-19-2014, 08:43 AM   #15
Trailer: 2014 Escape 21
Virginia
I use the Harbor Fright set up for my 5er. Set one magnet on top of the hitch/ball. Put the other magnet on the lower front lip of the coupler. The key is to look at the yellow balls through the rear view mirror (Centerline view). When close get out and check for proper height. Then back up the coupler will knock off the magnet/ball on top of the hitch/ball and all you have to do is lower the trailer/coupler onto the ball.
Old 03-19-2014, 09:01 AM   #16
Trailer: Previously owned a Scamp 13'
New Hampshire
Hi Sharon, I use the Solo Hitch Yellow ball thingy and it's good although they are flimsy and I've had two of them stop telescoping shortly after purchase. But I bet your backup camera will be even better once you get used to doing it!
Doghaus is offline   Reply With Quote
Old 03-19-2014, 09:07 AM   #17
New Hampshire
The Couple Mate Francesca posted looks really good and I wanted it too when I first got my camper, but I know I would be banging my knees on it too much the way I work out of the back of my vehicle, and i don't want to take the drawbar out every time I unhitch. Do you walk into it a lot Francesca?
Old 03-19-2014, 10:34 AM   #18
blodn1's Avatar
Trailer: Prius camping - want an Oliver
Virginia
I saw a great inexpensive idea one time. Put a bright pool noodle on the trailer hitch so you can see it in the rear view mirror.
I don't get lost, I go on interesting side trips.
blodn1 is offline   Reply With Quote
Old 03-19-2014, 12:19 PM   #19
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I noticed in that video that there's a way of stowing the "wings" on the coupler after they've done their job. I keep that piece in the bag that holds my blocks/chocks/ballcover. I'm not sure that wing-stow method would even work with my older model, but even if it did I'd continue to stow it elsewhere for just the reason you stated.
Old 03-19-2014, 12:27 PM   #20
ColoRockiesFan's Avatar
Trailer: Former Escape 19 owner
Virginia
I used something similar:
Hitchin Rod
Hitchin Rod : Amazon.com : Automotive
I also have a cap on the back of my truck so its even harder to see. But, I can still line up the rods just right and rarely have to make more than 1 attempt to get ball & hitch to line up correctly.
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off the bowlines, Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
ColoRockiesFan is offline   Reply With Quote
Old 03-19-2014, 01:04 PM   #21
Those don't appear to be telescopic.
I use EasyHitch. They collapse to about 12" so I keep them in my glove box. They have flashing LEDs on top for hitching at night. ( I recommend removing the batteries, or you'll lose them ). Also, EasyHitch is about $10 cheaper.
Go to: Easy Hitch | Trailer hitch alignment solution
Old 03-19-2014, 01:22 PM   #22
I got those telescoping ball things at Walmart, for something like $16 or so. Then I saw some at Harbor freight tools, that looked identical, for around $10. They're not perfect, still a lot of lining things up depend on driver skill, but they do help a lot.
ThomasE is offline   Reply With Quote
Old 03-19-2014, 06:20 PM   #23
I'm not keen on the self aligner either. If you have a sliding foot your jack doesn't serve as a stability point when camping and, if you don't have a sliding foot or a wheel, it's not all that kind to your tongue jack or tongue area.
As the old nursery rhyme went
"When she was good she was very, very good
But when she was bad, she was horrid."
Personally I back up using the inside rear view mirror and learn what the view is supposed to look like when I am centered on the trailer.
Old 03-19-2014, 06:41 PM   #24
Trailer: UHaul
Massachusetts
Sigh. I showed them to the husband, and he rolled his eyes and said you have a backup camera, how much easier can it get?
I am going to practice with some traffic cones before I am willing to risk my beloved CT13 to my bad sense of distance.
Sharon D is offline   Reply With Quote
Old 03-19-2014, 06:51 PM   #25
Trailer: '77 Scamp
Hitchin Rod
I've heard these are good quality that will last. I will probably buy one of these. The Harbor Freight tennis ball type didn't last long--the telescoping function pulled apart and is no longer usable. Dang!
Otters is offline   Reply With Quote
Old 03-19-2014, 06:57 PM   #26
I've had these for four years.
Old 03-19-2014, 07:10 PM   #27
Trailer: '77 Scamp
Good to know Glenn. I like the price too. I don't know that I'd use the blinky light though. I actually do pretty well hitching up the trailer by myself. But it does take a few treks back to the hitch before I can complete the hitch. I'm taking it out in 2 wks so I think I'll go ahead and order it.
Old 03-19-2014, 07:20 PM   #28
I've never had call to use the blinky light.
The mechanism to turn it on and off is bad design. You unscrew the red lens a bit to shut it off. When you toss them in the glove box, somehow the lens either twists enough to turn on and kill the batteries, or it comes unscrewed and the batteries are floating around in the glove box.
I sent them an email about this and they offered to send me replacements for the whole unit for free, but I didn't take them up on the offer. Perhaps they have changed that part of the design.
I have the lens screw on tight, with no batteries in the unit.
Solo travelers? DavidSo General Chat 21 11-19-2011 10:13 AM
....speakin of Ron Smith [O Solo Mio] Doug Mager General Chat 0 01-06-2011 04:33 PM
First Solo Adventure starts tomorrow scott fraser General Chat 3 07-31-2007 01:36 PM
Hitching Solo Legacy Posts Modifications, Alterations and Updates 12 06-21-2003 04:07 PM
Solo camping for Women General Chat 0 12-31-1969 07:00 PM
