Subaru continuously variable transmission - Fiberglass RV
Old 06-11-2011, 11:52 AM   #1
Trailer: U-Haul
South Eastern Pennsylvania
(Standard disclosure: I did some searching in the forum but did not find this subject. If there are any such discussions please point me to them.)
I am starting to research for a new tow vehicle. At this point my favorite option is a Subaru Outback. I have a '98 Impreza that has been a very good car.
My first inclinations were to get the 6 cylinder to have plenty of power. The continuously variable transmission (CVT) is intriguing to me, available only with the 4 cylinder engine.
Has anyone on the forum used one and towed with one? Does it work well with a trailer? In theory, the CVT would use the power from the small engine more efficiently, making it fell like a more powerful engine. Does this seem to be true? when towing? Is the CVT rugged enough to last a long time while towing?
Any experiences and thoughts are most appreciated.
Craig D. Thompson is offline   Reply With Quote
Old 06-11-2011, 01:36 PM   #2
Mark J's Avatar
Trailer: 13 ft Scamp 1999
Here is a link to a good site for more information about the Outback on towing for starters:
Towing 3000 lbs with the Outback - Subaru Outback - Subaru Outback Forums
A small percentage of the newer generation Outback have had steering shake issues that you should be aware of. You can also read about it at the same website.
Mark
Mark J is offline   Reply With Quote
Old 06-11-2011, 04:02 PM   #3
That is a very special and unique transmission.
I would look in the owners manual to see what it states concerning the tow issue. You may have to go to a dealer to view the manual. You may also be able to look at a manual at CarMax for a used one.
Old 06-20-2011, 02:53 PM   #4
Herb Sutton's Avatar
Trailer: 2002 Casita 17 ft Spirit Deluxe
I have always been an advocate of being cautious of new technology. CVT works on the same principle as a golf cart transmission only larger. You might deduce that they are only being used on small cars with small engines for a reason.
Herb Sutton is offline   Reply With Quote
Old 06-20-2011, 03:51 PM   #5
Trailer: 1980 Burro
Originally Posted by Mike Magee View Post
If the advisor held himself out as an expert, or received pay for the advice, I could see that happening. Otherwise... pretty unlikely.
I see a difference between ignoring tow capacity rating vs ignoring tire rating. In the former, people are seeing that the same vehicle is rated very differently in various countries, apparently in an arbitrary manner. Also, not all tow ratings are based on safety limitations; sometimes the limitations are mechanical (transmission longevity concerns, for example). In the latter, the tire's rating is uniform in all locales and is accepted at face value as a legitimate limit for safe operation.
I recommend ignoring any arbitrary rules in life. And I'm not worried about getting sued for saying so.
Many people that view this site have little or no towing experience, someone without experience may think that those posting about exceeding limits are experts when they claim there is no difference between US and European cars.
Lots of people ignore tire or towing ratings and drive above 65 mph or tow more weight than the rating without having problems. They are taking the risk if they do that, however, it is entirely another story if they start recommending that others, who they do not even know, take the risk, and convince them by claiming that it is safe.
I do not believe that the towing limits are set "in various countries, apparently in an arbitrary manner".
Here is a link to a discussion of some differences in towing ability between US (2700 tow capacity) and European (4400 tow capacity) Subaru Outback that seem to be identical cars. Look at posts #9 and #12.
Unless someone checked very carefully they would not notice the difference in shocks or 0.8" lower spring mounts and who knows what else that could make a big difference in an emergency situation. Post 12 also points out that European trailers have suspension differences as well.
I don't think anyone would decide against buying a car because the tow capacity was higher than they needed, but many would decide not to buy it if the tow capacity was lower than needed, so it does not make sense to me that a manufacturer would assign an arbitrary tow capacity. The higher the tow capacity, the more cars they will sell.
Andy B is offline   Reply With Quote
Old 06-20-2011, 04:01 PM   #6
cpaharley2008's Avatar
I could not agree more Andy. That is why I did not buy a Subaru Outback. I loved the car and the CVT transmission, BUT, the 200 lb limitation on the 4 cyl as well as V-6 requirement for 3000 lbs plus no one could figure out how to install a brake controller at the dealer. This tells me, Subaru is not trying to capture the rv towing customer. I got no response from Subaru on this issue. So, I bought a vehicle with factory tow, 500 lb t/w and 5000 lbs capacity. I'm not as pleased as I would be driving a Subie but I'm safer in my Jeep.
Old 06-20-2011, 05:37 PM   #7
Herb, You are exactly right.
The belt has metal spacers embedded in it and just like a golf cart, should you put to much strain on it, it could ruin either the belt or the pulley assembly.
If I said to definitely NOT DO IT, we would have someone then post a picture of one pulling a freight train. Read the owners manual and ye shall find the answer.
Old 06-20-2011, 05:41 PM   #8
I tow with an 07 Outback 4 cyl. (it does not have the new CVT) and I would suggest that if I had not already owned the car prior to purchasing the trailer I would go for the 6 cyl. :-) Not that I am really unhappy with the 4 cyl as it has been doing a fine job of towing for 4 years now over thousands of miles. Its just that there are times that I do notice the lack of power and think more would be nice. Mostly when in serious mountain ranges.
The only real draw back (having a 4 cyl. really isnt what I would call a draw back) to the Outback is the limited tongue cap. I have an older scamp so being carefull about my stow I am able to keep my tongue weight down to or pretty close (within 20lbs) to where Subaru wants it to be. You may have a hard time doing that with a number of other fiberglass trailers. I would make sure I know the real tongue weight of my trailer with a battery, full propane tank on the tongue and all my gear in the trailer before I made the purchase. As far as wheel shake issue goes can't comment as I have never had the problem on this Outback. Actually have had no problems what so ever with this Outback or the one I had prior.
Old 06-20-2011, 05:51 PM   #9
If I said to definitely NOT DO IT, we would have someone then post a picture of one pulling a freight train..
Oh how true! Although it will not be me that does it! Know all to well we have folks that suggest I am already pushing the cars safe tow limit by towing 300lbs under its tow cap.
Old 06-20-2011, 06:49 PM   #10
Radar1's Avatar
Name: Dave (and/or John)
Do you mean a picture like this?
Just had to do it. No, this isn't my Outback, and it's too old a model to have the CVT, and it wasn't really hitched to the 5th wheel, but I thought it looked like an interesting photo op since I tow my Scamp 16 with a regular automatic on my Outback.
Old 06-30-2011, 09:56 AM   #11
Trailer: 2001 13 ft Casita Patriot Deluxe modified 1969 25' Airstream Trade Wind
What NOT to Tow with .....
How about this ...
A 2000 Metro and a 17' Casita .... NO !
A 2002 PT Cruiser & 17' Casita .... Uh, NO
A 1984 Datsun 4 cylinder P/U and 17' Casita ....only to move it in the driveway.
Glen G is offline   Reply With Quote
Old 06-30-2011, 10:13 AM   #12
These tow just fine ....
Our Tahoe & 17' Casita and Joy's Jeep & 13' Scamp
Our Tahoe & 17' Casita and Phil's Dodge Dakota & 13' Casita
Our Avalanche & 17' Casita
Our SSR & 13' Casita
Old 06-30-2011, 11:06 AM   #13
Trailer: 1973 13 ft Compact II
Carol, You probably are pushing the LIFE of your Outback's...
...transmission and engine. My Subaru dealers, who've been great friends and mentors to me over the 15 years I've owned Outbacks, have been very frank in cautioning me to sell a 16' Scamp that I initially purchased (it was advertised as a 13' Scamp AND what did I know?!!!). Even though it was within the tow capacity (Barely) of my 4 cyl Outback, they said I would burn up the engine and wreck the transmission EARLIER than by towing a 13'er. There is no reason to put more wear and tear on your TOW VEHICLE, it's ahell of a lot more expensive than your trailer and YOU want it to last 'orever' (aka: at least 300,000 miles!).
Time always tells...as well as whether you're going up mountains or are always in Texas on the straight-away!
See you in two weeks...let's both drive safe...keep those Subaru's going as long as possible!
bbuehler is offline   Reply With Quote
Old 06-30-2011, 10:01 PM   #14
Trailer: Trillium 4500
Can't comment on the Subi. CVT, but our secondary tug is a 07 Nissan Murano with CVT. Tows like a dream; better than our 02 Taco, just not as much room for toys.
Scott H is offline   Reply With Quote
Transmission Oil Cooler Clark Martin Towing, Hitching, Axles and Running Gear 24 05-19-2010 05:53 AM
transmission cooler necessary? William L. Towing, Hitching, Axles and Running Gear 10 03-23-2009 07:39 PM
Transmission temps Kevin K General Chat 9 01-25-2009 11:51 AM
Braking, Transmission for towing Paul Kaplan Towing, Hitching, Axles and Running Gear 5 06-30-2008 06:14 PM
Automatic Transmission Stuf Pete Dumbleton General Chat 0 05-01-2008 09:11 PM
