Subaru Outback pulling 13' Trillium - Fiberglass RV
Old 09-13-2008, 09:44 AM   #1
Marv Watson's Avatar
Trailer: 1978 Trillium 13 ft
Great Lakes area-US
My wife and I just happened on a 1978 13' Trillium at a fair price and couldn't pass it up. So, we're really newbies (though I have lots of miles experience pulling a utility trailer). Now, we have to get serious about what we'll need to do so we can safely pull it with our '06 Subaru Outback wagon - standard 4cyl engine. My wife quickly found your forum and we've been studying it like mad since. I'm convinced I need to add electric brakes and controller, and have a place near by that I know and trust to do the work. Not sure if I need the trans cooler. We would like to hear from any Outback owners (or similar engine size vehicle owners) that have pulled this size Trillium or similar about their experiences - with or without trailer brakes.
marvonw
Marv Watson is offline   Reply With Quote
Old 09-13-2008, 10:34 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
If its a automatic you need the trans cooler or your transmission will be shot after no time. Change the fluid and put a cooler on.
Old 09-13-2008, 12:16 PM   #3
Great Lakes area-US
Thanks, Keven...Pretty much what I figured; so, I'll add that to the list of necessaries.
re
marvonw
Old 09-13-2008, 01:00 PM   #4
Manitoba
I have aprox. 8,000 towing Km. on my Forester/Surfside. Subaru's like brakes for anything over 1,000 pounds. I don't have a transmission cooler, and have 325,000 on the transmission and it still pulls fine. Depending on where you live (how cold it gets), if you install a transmission cooler, try to find one with a pressure bypass, so that cold fluid doesn't result in your cooler starving your transmission of fluid. Enjoy; your Subaru/Trillium is an ideal combination.
Old 09-13-2008, 08:13 PM   #5
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Hi Marv,
Like Cam I have electric brakes but no transmission cooler on our 2005 Subaru Forester, 1976 Trillium Combo. We did a return trip through the Rockies with a loaded trailer and 2 adults/2kids with no issues.... and like Cam I think the Subaru/Trillium combination is perfect. Our Subaru dealer has never installed a trans cooler but has installed a ton of hitches and brake controllers. I would HIGHLY recommend getting brakes and a good controller - I purchased a Tekonsha Prodigy and find it works excellent. We got a class II hitch and I would recommend getting one if you can. We are actually replacing our truck with an aluminum trailer for doing yardwork and the class II allows us to use the trailer fully loaded.
Trilliums Rock =)
Old 09-14-2008, 10:02 PM   #6
Roy in TO's Avatar
Cam,
Can you explain how the pressure bypass system works? Is it something like the coolant overflow and reserve using the rad cap as a valve on the cooling system?
Old 09-15-2008, 01:11 PM   #7
Manitoba
Cam,
Disclaimer - I am no mechanic. My understanding is that over-cooling results in late or harsh shifting; or worse, trans fluid starvation when it gels in the cooler and does not circulate back to the transmission. Some coolers have a valve that bypasses the cooler and returns the fluid to the transmission until it reaches operating temperature. Perhaps some mechanical type could clarify for our behalf.
Old 09-15-2008, 10:49 PM   #8
Pete Dumbleton's Avatar
I've never heard of the bypass valve, but that doesn't mean it doesn't exist in some systems, esp in extremely cold climates.
However, most aux tranny coolers are recommended to be installed between the hot side of the tranny and the entry to the main radiator trans cooler. In cold weather, the radiator, warmed by the engine, will bring the trans oil up to temperature.
If the aux cooler is installed *after* the radiator, it might cool the trans oil down too much in very cold weather.
Some installers want to bypass the in-radiator cooler, but that would not be a good thing in very cold climates.
Old 09-19-2008, 05:12 PM   #9
Great Lakes area-US
Hi Marv,
Trilliums Rock =)
Hi, Booker....Thanks for the info. I have talked to my hitch guy and he quoted me a price on brake and controller work that included a Draw-Tite 5100 controller. He said it is made by Tekonsha and virtually the same as the Prodigy. Anyone have any experience with the Draw-Tite? He said he would sell me the Prodigy (more $$), if that's what I wanted.
marvonw
Old 09-19-2008, 08:53 PM   #10
Daniel V.'s Avatar
Trailer: '74 Trillium 1300
Based on info from the draw-tite site, the 5100 model is a time-based unit, and not an inertia-based model which probably explains the price difference.
But it looks like Draw-Tite does make the Pinnacle models that are inertia-based.
Daniel V. is offline   Reply With Quote
Old 09-20-2008, 08:23 AM   #11
Great Lakes area-US
Aha! So my hitch guy didn't quite tell me all. I'm assuming the preponderance of Prodigy recommendations is because it is an inertia type. Thanks for pointing out the difference. I'll be better prepared to the make the best choice for my situation.
marvonw
Old 09-20-2008, 09:37 PM   #12
Check EBay for realistic prices for Prodigy -- The lifetime warranty is good regardless of where you buy it.
Old 09-20-2008, 11:39 PM   #13
Trailer: Burro 13 ft 1983
Marv - I haven't been on for a few days and just read your question about trans. cooler. We pull a 13' Burro with a 97 Legacy wagon with a 2.2 engine. When we started, I contacted Subaru and they said that they'd long realized what Subaru's were used for and that they already had a trans. cooler installed. Haven't checked on later models but will be doing so as I'll be switching to a 2005 Subaru legacy sedan.
There is one operating anomaly that I've wondered whether others have experienced. We have some long straightaways here that prompt driving on cruse control. As I think most auto trans. now have a variable stater - when running at 55-60 on cruse in its top gear, 4th, the car runs at a stater adjusted higher RPM. When canceling the cruse, the engine drops back to its lower RPM. (This is not a situation where the engine is running too slow with a load.) Wondered whether anyone else has experienced this.
James Bar. is offline   Reply With Quote
Old 09-21-2008, 07:58 AM   #14
Manitoba
My 98 Forester automatic doesn't do that; it is quite happy to pull in fourth gear on the flat - with low rpms.
trillium
Subaru Outback Towing a 16' Scamp? Parker Buckley Towing, Hitching, Axles and Running Gear 51 11-04-2011 10:04 AM
Subaru Outback and Scamp 16SD Radar1 General Chat 4 08-02-2010 03:46 PM
Towing with a Subaru Outback james cronn Towing, Hitching, Axles and Running Gear 0 04-16-2009 03:13 PM
2008 Subaru Outback Trailer Wiring Byron Kinnaman Problem Solving | Owners Helping Owners 5 06-27-2007 02:55 PM
Subaru Forrester with Team Trillium Outback Brian T Towing, Hitching, Axles and Running Gear 12 05-13-2007 11:27 AM
