Sway bar again! - Fiberglass RV
Old 02-01-2006, 04:06 PM   #1
Chris Z's Avatar
Trailer: 16 Scamp, 17 Casita, 21Bigfoot now
Thumbs up
Wife kept complaining that the trailer kept moving around when I swerved or a truck passed or similar. One we looked at before we bought had a sway bar. Doesn't sway much at all but I got to looking at where I could get a sway bar and not spend an arm and leg. I found this:
http://www.campingworld.com/browse/skus/in...=26649&src=SRQB
I don't need too much I don't think and the price is right ($53.99) but wondered if I was just wasting my money on this.
Chris Z is offline   Reply With Quote
Old 02-01-2006, 04:29 PM   #2
I will sell you a new one in the box, Valley Friction, that looks just like the one in the add for $35 Plus shipping.
http://www.valleyorders.com/Public/A...ns/Default.htm
Darwin Maring
Mineral, VA
Old 02-01-2006, 05:27 PM   #3
Rob S.'s Avatar
Trailer: 1980 Bolar 1700
Massachusetts
I have one of these on my 17' Boler and it does make a difference. You'll need to tinker with how tight you need it before you can feel it working. Are there better products out there...most likely yes. Is it better than nothing at all...yes.
Rob S. is offline   Reply With Quote
Old 02-01-2006, 05:30 PM   #4
You're liable to get 1000 different answers to this question. But each individual can only answer for their particular needs. Each tug and tow handle differently. I'd think it's inexpensive enough that if it provides a level of comfort and reduces the sway to less than you're currently experiencing, then it's worth it.
Old 02-01-2006, 05:34 PM   #5
I went to this site and couldn't find a sway bar. Need help!
CD and Joyce Smith - Lily, Violet, and Rose
1999 Casita 17' SD - "The Little Egg"
2007 Escalade - 6.2L V8 - 6L80E Trans - 3.42 Diff
CD Smith is offline   Reply With Quote
Old 02-01-2006, 05:37 PM   #6
Look under equalizing hitch accessories.
Old 02-01-2006, 05:39 PM   #7
Maybe this will help, screenshot from the website:
Old 02-01-2006, 05:57 PM   #8
Thanks, I found it.
Old 02-01-2006, 06:50 PM   #9
Trailer: Casita Spirit Deluxe 17 ft
ChrisZ, my experience with friction type sway bars is - they are basically all the same except for the label on the side. The one illustrated in Camping World should accomplish what you want to do and the price is right. I use an identical bar and would not tow without some type of sway control and I have towed many different type of rv's over 80,000 miles . It is too late to purchase when you really need it and even under moderate towing conditions sway control devices provide additional stability and straight line tracking. Martin
Martin D is offline   Reply With Quote
Old 02-01-2006, 11:21 PM   #10
CarolnJim's Avatar
Trailer: 2002 17 ft Casita Liberty Deluxe
Hi Chris
Just wondering what tow vehicle you have. We tow with a 2004 Odyssey and use a WDH (Weight Distribution Hitch) .. No sway bar and No problem with swaying ... We feel the mini van definitely needs the WDH.
CarolnJim is offline   Reply With Quote
Old 02-02-2006, 07:18 AM   #11
Chris Z's Avatar
Hi Chris
Carol.......... I have a 2005 Chevy Tahoe so there's no problem with the capacities. Thanks
Darwin......... does yours have everything including the ball and ball plate and all mounting? I think the one from CW does and they have a store about 15 miles from me so no shipping cost.
Old 02-02-2006, 07:33 AM   #12
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 2004 Airstream Interstate 22' B-van
Iowa
Chris, I have an '02 Scamp 16' CD side dinette that I tow with a Tundra. Mine doesn't move behind the truck at all. Have you tried to isolate the cause of why yours is wiggling? There may be correctable causes that will only be masked by a friction bar sway control. After you've figured out why it wiggles, a friction sway control may yet be in order, but then you have it for an additional measure of control, not to try to control something that may be permanently correctable using other methods.
Roger
Old 02-02-2006, 09:51 AM   #13
The box had never been opened. I opened it and it has the Ball and Ball plate, friction unit and bolts and instructions. It is a Valley Industries, dual friction, model number is 07519 RH and I assume the RH stands for Right Hand meaning it connects to the right side of the vehicles.
DR
Old 02-02-2006, 09:59 AM   #14
Be Careful:
The front of the friction hitches have a ball receptacle that connects to the Ball installed on the vehicle hitch assembly. Normally, the extra ball assembly is attached to an equalizing hitch.
The equalizing hitch has the 2 inch ball for the trailer and a place to mount the small friction sway ball to the right of it. If you do not have a place to mount the friction ball then you will need to purchase an additional hitch that slides into your receiver so it will work.
You will not need the additional equalizing bars, etc, just the hitch with the 2 (Two) ball mounts.
DR
Sway Bar Parker Buckley Towing, Hitching, Axles and Running Gear 17 07-24-2010 12:36 PM
What is sway? Ron Davis General Chat 43 07-09-2007 02:13 PM
Sway Bar Legacy Posts Problem Solving | Owners Helping Owners 6 07-17-2003 07:24 PM
