Sway Bar Noise - Fiberglass RV
Old 09-24-2016, 09:40 PM   #1
Trailer: Escape 19
Sway Bar Noise
We picked up our new Scamp 4 days ago. We had Scamp install a sway bar.
Since then we've driven about 800 miles with no sway at all, even at speeds as high as 75 mph
But the sounds that come from the sway bar, especially when turning, sound like a torture chamber. Is that normal?
Larry
llinderman is offline   Reply With Quote
Old 09-24-2016, 09:46 PM   #2
tractors1's Avatar
Trailer: Escape 21 - Felicity
The sway bar depends of friction to work; you might have it a bit too tight. Do NOT lubricate it!
I'd back off a bit and see how it goes. Still no wiggles when big trucks pass, you should be good.
Charlie Y
Old 09-24-2016, 09:53 PM   #3
I'd slow down too.
Old 09-24-2016, 10:09 PM   #4
The tires are rated for 65mph maximum. Exceeding that for any length of time is asking for a blow out.
I tow my 13' without an anti-sway bar. No problems. Anti-sway bars, at least in my opinion, will mask a problem that should be corrected.
Old 09-25-2016, 05:52 AM   #5
I don't see a problem with using a sway bar... as long as you first establish that the trailer is stable without it under all normal towing conditions. It's meant to be an auxiliary safety device in an emergency situation.
I agree that 75 is way too fast!
Old 09-25-2016, 09:19 AM   #6
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
I really hope the 75 mph is a mistype
If not please let everyone know where youre heading so we can get off the road
75mph towing a trailer ... You have to be kidding
alan H is online now   Reply With Quote
Old 09-25-2016, 10:22 AM   #7
The problem I see is that many people put on an anti-sway bar to correct a problem, not as an added safety device. In my opinion an anti-sway bar is dangerous in some conditions. I've never used one and travel a lot. 10K miles so far this year.
Old 09-25-2016, 10:36 AM   #8
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
You all might have to stay home a lot, as I regularly see trailers being pulled at speeds near 75mph. I have done it too, as my tires (and most ST tires) are rated at 65 at the minimum rated pressure for the weight of the trailer, but if you can increase the pressure by 10 lbs without exceeding the maximum, they are rated for 75. Still, the fastest I usually travel is 110 kph (or 68 mph), the speed limit on many highways here, and only exceed that on rare occasion.
https://docs.google.com/viewer?url=h...plications.pdf
I am of the same mind as Jon, that there is no problem using sway control, but just so long as it is an assist, and not covering for a loading problem.
There really should be no excess noise though, I too would back off a bit on the friction.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-25-2016, 11:01 AM   #9
IllAnnoy
I see a friction sway bar as a luxury improvement.
It hides nothing. In fact I think it shows a dedication to excellence and improvement after all else has been done.
Besides , a "MASK" can sometimes really improve your game!!...
Old 09-25-2016, 12:07 PM   #10
need a pic....
quite a few people around here confuse sway bars with weight distribution bars....or at least say one for the other....
I have a standard WDH that came with the trailer (no anti-sway bar or bars)...I used to hear a lot of noise back there making turns (clanging/banging) then I greased the ends of the weight distribution bars that fit inside the hitch and the noises dissapeared
made sense once I'd done it...during a turn the ends of the bars would have to rotate a little...metal on dry metal with a whole lot of torque involved...they would bind up....with a little bit of grease they don't anymore
Old 09-25-2016, 02:14 PM   #11
I tow my 13' without an anti-sway bar. No problems. .
I agree but I suspect neither of us would ever tow at 75 mph either
Old 09-25-2016, 02:16 PM   #12
The key words in the above are "after all else has been done"
Old 09-25-2016, 03:40 PM   #13
IllAnnoy
Actually If "key" words must be taken out of context they might be "it shows a dedication to excellence and improvement".
It was never I who suggested that friction sway control was a band-aid. It is an effective supplement to good system.
Old 09-25-2016, 04:04 PM   #14
Totally agree assuming of course that ALL has in fact been done to set up the trailer to make sure it is a good system!
Strange noise from the Sway Bar Keith Williams Towing, Hitching, Axles and Running Gear 14 09-05-2009 10:49 AM
Thinking of a sway bar this year Chris Z Towing, Hitching, Axles and Running Gear 11 12-30-2005 06:43 PM
Sway Bar Legacy Posts Problem Solving | Owners Helping Owners 6 07-17-2003 07:24 PM
Sway Bar recommendations Legacy Posts Towing, Hitching, Axles and Running Gear 20 05-19-2003 01:51 PM
