Swaying Scamp 16' - HELP - Page 2 - Fiberglass RV
Old 08-11-2013, 02:36 PM   #15
Trailer: 2015 Scamp 16' deluxe 2008 FJ Cruiser
I have the same problem. Our 16 is the same model. Ours starts to sway around corners when there is a dip in the road. Hitch is correct and weights are right. I ordered a Andersen wd sway control even though I do not need the wd it will help with sway and bounce
Ken
Ken in Pa is offline   Reply With Quote
Old 08-11-2013, 03:17 PM   #16
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Ken
You would be better off with just a sway control like this:
Curt Friction Style Sway Control System Curt Weight Distribution 17200
Old 08-11-2013, 04:25 PM   #17
Brian B-P's Avatar
I don't see any reason for a properly loaded Scamp 176' to sway under these conditions. Our 17' Boler doesn't... without any sway control device.
Even if the fraction of weight carried by the hitch is suitable, weight distribution can still be bad for stability if the mass is out at the ends of the trailer - a bunch of stuff on the rear bumper or under the back of the dinette playing teeter-totter with a bunch of stuff stacked on the tongue is balanced, but not well distributed. I'm not saying this is your rig, Ken, just that what many people think is properly loaded is not.
Another factor, of course, is the tug. If the tug allows the ball to move side-to-side to easily, the trailer could sway in conditions which a more stable tug would not have a problem with. The FJ Cruiser is strong, more than heavy enough (2 tons) to handle this size of trailer, and has a good chassis; however, it's not very long in wheelbase, and typically has tall mushy tires.
Old 08-11-2013, 04:55 PM   #18
Mike Magee's Avatar
Trailer: Li'l Hauley
Wow, I don't recall hearing a peep about any sway issues with Scamps until this month. But someone from MN posted a thread on rv.net about their brand new Scamp 16 swaying. Now this thread comes up, and several people with 16s are talking about experiencing sway. This is weird!!!
How to prepare Tofu
Step 2: grill some meat
Old 08-11-2013, 05:03 PM   #19
Thomas G.'s Avatar
It is like UFO sightings. They come in waves.
Old 08-11-2013, 05:12 PM   #20
We have tried packing differently some ways worst than others. We can not carry any water at all. The bed is made up all the time with bins under but all light stuff. The FJ squats about an inch when the trailer is hooked up and handles and ride like no trailer on the back. The trailer rocks and sways mostly on turns and uneven roads. All air psi are correct. I had a 1976 Scotty 15 ft with original suspension that just floated like a dream. I miss that. I will get this worked out. We only picked the Scamp up in Backus 7/5/13 but already put a lot of miles on her.
Ken
Old 08-11-2013, 05:20 PM   #21
Mike Magee's Avatar
If most of the swaying 16s are relatively new builds, is it possible that a design change has been made by Scamp that is causing this? Ken's is a 2013, the OP's is a new 2013, and the one on rv.net was a 2013 just picked up from Backus. I wonder.
A sway control unit will cover up the symptoms (and you may have to get one), but it sounds like there is a problem that should be isolated and fixed. A 2200-2500 lb trailer with a positive tongue weight of 200 lbs or more really should NOT sway. If your tongue weight is 200+, IMO Scamp should be notified.
How to prepare Tofu
Old 08-11-2013, 06:02 PM   #22
Brian B-P's Avatar
I think Tom is on the right track - when someone mentions a problem, people who had been keeping silent speak up with their similar problems... or start looking for the same problem and find it.
It's pretty rare for Scamp to change even trivial details - a change which would affect sway seems pretty surprising. Did they get jacked up in suspension height?
Old 08-11-2013, 06:04 PM   #23
Brian B-P's Avatar
Rocks? Is it rolling from side to side, like it is leaning through a rapid series of alternate direction turns? That can indicate uneven loading side-to-side, and the reaction of the trailer and tug to this rolling can cause sway.
Old 08-11-2013, 06:35 PM   #24
honda03842's Avatar
Name: Norm and Ginny
Ken and David, Like other Scamp owners I know, we've never experienced sway with ours or with the Casita 16 we towed for a year.
One thing you could do is to cut down the number of potential variables. It might be interesting if you towed a friend's Scamp to eliminate you're tow vehicle's setup as the source of the problem cutting the problem in half.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 08-11-2013, 08:36 PM   #25
Every instance of sway with our 16' Scamp has been corrected in a few minutes of weight shifting. It has always responded favorably to forward weight shifting. One instance that seems to amplify sway is when we carry a half full fresh water tank which is in the far aft location. There are times when you just need to import water to your dry campsite and carrying water is unavoidable. The half full tank sloshes amplifying the sway. I also have a rear rack that carries a small fire pit and plastic tub filled with hoses and sewer fittings. That weight located so far back is also a recipe for sway, and has to be counter-balanced by adding weight up front. If you can't get the trailer to stop swaying by weight shifting you next need to verify tire pressure on trailer and tug. Don't be afraid to air up the tug tires a little higher than the door jamb sticker calls for, as you are carrying more weight. Just don't exceed maximum pressure listed on the tire sidewall. Also, make sure you are not overloading the trailer. 7 people with luggage in a highlander is using up a lot of the GVW capacity. A trip to the scales is a good idea to give you an idea of the correct limit. Keep us posted on how you make out.
This problem is not a Scamp specific issue, as all these trailers have similar torsion sprung axles solidly mounted to the chassis. Any trailer that is improperly loaded will sway.
Russ
Old 08-11-2013, 08:53 PM   #26
honda03842's Avatar
Russ
We always carry a half tank of water and a rear bumper box.
We do substantially increase tire pressure. Tow vehicles rears at 39 compared to Honda's suggested 26, fronts at 36 lbs. Trailer tires at 49-50.
Tongue 190-200 lbs.
Most of the trailers heavy weight except water is near the axle. No roof air or awning.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 08-11-2013, 09:26 PM   #27
deryk's Avatar
New Jersey
The former owner of my ParkLiner used an anti sway bar and I did as well as a weight distribution hitch because of my Rav4's soft rear end.
Im sure the 60-70lbs on the rack on my backside doesnt help stop the sway but I do have a 90 some pound generator inside the doorway, and 7 gallons of water in the front bathroom and moving my 18lb rocket stove to the forward closet has to be adding some weight back onto the tongue to counter the rear rack. I also travel with full water tank because I boondock and not always is water availible so I take my parents good tasteing well water with me...about 28 gallons(15 tank, 6 gallons water heater, 7 gallon portable tank)
Since adding the anti sway bar and weight distribution hitch only once have I felt the trailer swinging behind me and that was while driving over 72mph passing someone while a bit windy out. I felt it pushing me to the left almost off the shoulder but takeing my foot off the gas, whit kuckling it I was just reaching for the break controller when my speed decreased enough and she slid back behind me nicely and just kept my speed around 60 was fine the rest of the ride... funny when it happened, I was coming home with a mostly empty water tank and totally empty grey tank so not much weight behind the axle... probably was the speed. Ive learned a lesson and will keep the speed down as much as i can.
I have thought of adding a small water tank on either side of the water heater to help balance the load a bit (left to right)and to increase my water capacity since I dont use paper plates for environmental reasons so I am washing some dishes and do drink at least a gallon of water or more a day from the water tank. I do daily short military ish showers to conserve, but adding an extra 10-14 gallons would make me happy for longer excursions....especially when friends ask me to do their dishes too, or to take a shower lol.
deryk
Old 08-11-2013, 10:04 PM   #28
I think it's because new to towing and increased towing speed. All trailers will go into sway at a high enough speed.
Swaying with a 13 foot trailer? Mouse General Chat 16 06-29-2012 10:05 AM
swaying compact jr. Heath G. Towing, Hitching, Axles and Running Gear 10 05-30-2009 07:58 PM
towing a 17foot ... swaying and rocking .... Herb P Towing, Hitching, Axles and Running Gear 36 09-04-2007 11:50 AM
» Trailer Showcase
MyBoler
artx
Cuddles
Penny1
