Originally Posted by msethsmile
Paul O.--
Saw thread. I envisioned the old(?) method of two angle iron attached at wheel wells. New method is a Reese and better. Old way looks sketchy on composite bed.
That's correct. The old
Scamp hitch was also harder to remove, the Reese one just lifts out and the bed is clear (pretty much). I still have to use a wrench, because I replaced the simple pins with 1/2 inch bolts and large washers that I bent in order to eliminate play and resulting rattle when drving around with the hitch without 600 pounds
weight on it. I could take pictures and post them, if you are interested.
