Take Off Shell for Axle Replace't ? - Fiberglass RV
Old 02-28-2007, 07:59 PM   #1
Trailer: 1989 17 ft Bigfoot Deluxe / 2004 Ford Ranger
Our '73 Trillium is up for an axle replacement this Spring. Apparently, the axle was welded to the frame at the factory.Is it common practice to remove the shell from the frame, to prevent damaging it from cutting off/welding- back -on operations?
I'm looking at a #9 Torflex axle from Dexter, with NO Brakes, but with flanges installed, for potential future brake installation.
Does a new Torflex axle give adequate damping of bouncing, without shocks?
Joe/Peterborough/Ontario
Joseph Olajos is offline   Reply With Quote
Old 02-28-2007, 08:12 PM   #2
Pete Dumbleton's Avatar
Joe, the axles can be welded onto the frame without removing the body, although the axle shop that did mine wanted access to the inside so they could check it just in case -- The frame should dissipate the welding heat enough.
Dexter makes a bracket that can be welded to the frame, to which the axle brackets can then be bolted if you want to be able to do that yourself at a later date -- Redneck Trailer Supply carries the bracket (and is an excellent place $$ to buy an axle if there is one near you).
I suggest you look at the price of an axle equipped with brakes versus the cost of a brakeless axle plus the separate brake hardware at a later date -- Least expensive way to add brakes is to buy an equipped axle!
Old 02-28-2007, 09:40 PM   #3
Trailer: Trillium 4500
Hey Joe,
I'm pulling my body off the frame, it would be near impossible to cut off the old axle and reattach the new with the body in place. My OEM axle on my Trillium is a Henschen, not a Dexter. The mounting brackets are different on the 2 axles. My new Henschen brackets are identical to the old mounts making fitting much easier. I'm on board with Pete, brakes are cheap on a new axle. Good luck, Dave
Henchen Link
David Schroeder is offline   Reply With Quote
Old 03-01-2007, 01:02 AM   #4
jrnutpaul's Avatar
Trailer: 1994 20 ft Bigfoot 5th Wheel / Toyota Tacoma SR5
Hey Joe, I'm with Pete also....getting an axle with breakes at the same time would make more sense...however...why do you need brakes on this trailer and why would you ever not need them???
Paul
jrnutpaul is offline   Reply With Quote
Old 03-01-2007, 05:49 AM   #5
Even if you don't think you need brakes on the new axle, remember...brakes on the trailer will help reduce the need to replace the brakes on the tug as frequently.
Old 03-01-2007, 06:58 AM   #6
Trailer: Love Bug / Chevy Astro
When I ordered my Dexter axle for the Love Bug it would have only been about $70 more to order it with the brakes vs without brakes. To add them later would cost well over twice that much. I was told by the shop that all Dexter axles come with the flanges attached.
I could not have removed the old axle from the frame with the shell attached. I needed to grind off the old axle and would not have had enough room to get at some of the welds. I made my own mounting brackets whcih are welded to the frame and bolted to the axle so next time it will be much easier.
Bob Cupp is offline   Reply With Quote
Old 03-01-2007, 09:13 AM   #7
Trailer: 1982 13 ft Burro
Just FYI - I thought that was true, but it's not. I got a new Dexter axle last summer and when they asked "brakes or freehub," I said freehub, thinking it would come with the flanges and I could add brakes later if I wanted to. But it showed up bare.
Not a big deal, but ask for the flanges if you think you might want brakes later. I don't think they cost much if anything extra, and even if it's cheaper to order brakes with the axle, it's still cheaper to add them later than to get a whole 'nother axle.
AndyW is offline   Reply With Quote
Old 03-01-2007, 01:18 PM   #8
Brian B-P's Avatar
Airsteam says no - they all come with shocks.
Many Europeans say no - shocks are an available option on this type of suspension when sold in Europe.
Personally, I doubt it - I added shocks to my leaf-spring axle.
On the other hand, the vast majority of trailers do not have shocks, and the U.S. makers of rubber torsion axles do not generally offer shocks even as an option.
So what does "adequate" mean to you ?
Old 03-01-2007, 05:46 PM   #9
"I was told by the shop that all Dexter axles come with the flanges attached. "
The brake flanges are about a $3 option, but aren't required in tandem axle arrangements where only one axle may be braked, hence the choice between 'braked' or 'idler' axle. AFAIK, most if not all FGRV manfs supply the flanges, likely to make subsequent upgrades possible and also to standardize.
BTW, that's the problem sometimes with shops; perhaps they have never had occasion to see an axle without flanges -- I know I had an axle replaced and they screwed up a number of things, including not ordering the brake flanges... I finally had them replace the replacement.
Old 03-01-2007, 06:17 PM   #10
Brian B-P's Avatar
The brake flanges are about a $3 option, but aren't required in tandem axle arrangements where only one axle may be braked...
I wouldn't count on that one. In British Columbia, according to Division 5 of the Motor Vehicle Act Regulations, brakes are required on both axles of a tandem-axled trailer, if the trailer is heavy enough to require brakes. I have heard of people here in Alberta being warned that if they planned to tow into B.C, they should get brakes on both axles, so apparently it has been enforced.
But yes, the same regulation allows one non-braking axle on "house trailers" with more than two axles, and with various other exceptions it's not surprising that "idler" axles are offered. So when someone builds a triple-axle egg, they can save a couple bucks for brake hardware on that third axle... which would presumably have 10-inch wheels.
Old 03-01-2007, 07:49 PM   #11
All:
Thanx for all the input and ideas...that HENSCHEN website was interesting...I'm going to compare prices between them and DEXTER, however, there is a DEXTER supplier right here in Ontario, whereas HENSCHEN is located in Ohio; but then,perhaps they too, have a supplier here. Will have to check into that. Shipping costs could be a factor, when prices are compared.
I guess going with brakes on the new axle seems to be the wiser choice, if for no other reason than the cost factor, ie. now vs later.
Opinion still seems divided on shell removal...final decision may be left up to the shop that will be doing the installation, I guess.
As for shocks,I noted even Henschen's website stated somewhere,that torsion axles have a natural damping quality, suggesting that shocks were not necessary. Oh well, one less expense !
Joe
Old 03-01-2007, 11:48 PM   #12
Trailer: Fiber Stream
Thumbs up
That could keep me out of Brittish Columbia. Fiber Stream only put brakes on the leading axle. The trailing axle is brakeless. Would there be an exception for older units?
Old 03-02-2007, 11:53 AM   #13
Brian B-P's Avatar
That could keep me out of British Columbia. Fiber Stream only put brakes on the leading axle. The trailing axle is brakeless. Would there be an exception for older units?
Oh, come up here anyway, Frederick, and don't pass up seeing BC! I am not aware of any reason why older units would be exempted, but my guess is that the concern is about heavier trailers, anyway.
Originally posted by BC MVA Regs
[b]A trailer shall be equipped with brakes at each end of each axle, but brakes are not required
( a ) on one axle of a house trailer that is equipped with more than 2 axles,
( b ) on any axle of a trailer other than a towing dolly if the licensed vehicle weight of the trailer
(i) is 1 400 kg or less, and
(ii) is less than 50% of the licensed vehicle weight of the vehicle by which it is being towed,
If the Fiber Stream is under 1400 kg (I think it is...) and the GVWR (which is what I think "licensed vehicle weight" means) of the Odyssey is more than twice the Fiber Stream weight (must be close), then it seems you'd be legal without brakes at all. I'm not suggesting that the Fiber Stream is not a reasonable setup (although I would certainly prefer brakes on both axles), just that the practice they followed (brakes only on leading axle) is not universally acceptable. Just another reason to always include the brakes on a replacement axle.
Old 03-02-2007, 12:00 PM   #14
Brian B-P's Avatar
Yes, rubber has a characteristic called hysteresis, which means that it absorbs energy and is thus self-damping. Multi-leaf springs have friction between the leaves, which also provides damping... but you'll notice that every car and pickup truck with leaf springs still has shocks.
The damping provided by the rubber, or by interleaf friction, is not good enough for cars and trucks (or Airstreams, or many other travel trailer); however, it is generally considered to be adequate for trailers. Again, is it good enough for you?
axle
Empty Shell Stoney General Chat 9 10-07-2009 05:37 AM
Empty Shell Help Heather V. Care and Feeding of Molded Fiberglass Trailers 8 09-07-2007 05:57 AM
What would you put in a 13 ft. shell? Kent I Care and Feeding of Molded Fiberglass Trailers 8 09-02-2007 01:38 AM
Soft Shell Jason L. Problem Solving | Owners Helping Owners 18 01-20-2006 09:09 AM
Shell Speck General Chat 0 12-31-1969 07:00 PM
