Timbren, Sumo or Supersprings - Page 2 - Fiberglass RV
Old 04-21-2019, 06:58 PM   #21
Trailer: 2020 25 RQ
Originally Posted by richardr View Post
I need to take pack some of what I said in this post. After receiving a PM from Russ, I went and looked at my truck brake lines. The driver's brake line runs between the super spring and the leaf springs. It looks OK. But the passenger side brake line runs over the super spring and the corner of the spring has started to cut into the line. Using a heavy duty tie wrap I pulled the brake line away from the spring.
Russ' PM saved me from a certain brake system rupture.
Its what makes these sites so valuable..and in this case preventing a pending disaster. So glad you took the time to observe your own vehicle.
Hopefully other Superspring owners will take note and make any necessary alterations.
I will forward to Supersprings and ask for their input.
Russ Foster is offline   Reply With Quote
Old 04-21-2019, 07:09 PM   #22
John in Santa Cruz's Avatar
Mid Left Coast
well, I'd peg that brake line exposure as an INSTALLER problem, not an inherent problem with the supersprings.
on my Tacoma, the brake lines went nowhere near the Ride Rite airbags I had installed...
(the brake lines you can see going under the leaf springs were in fact secured there with a clamp, and do NOT contact the U bolt nuts that hold the ride-rites in place)
Old 04-22-2019, 08:31 AM   #23
richardr's Avatar
Trailer: Escape 21
I did more research this morning. It turns out that the cut line is the parking brake cable casing and not the hydraulic brake line, as I originally feared. I put a clamp around the cut section. The parking brake cable slides smoothly, so I think I am good to go.
Rick and Vicky Reed
richardr is offline   Reply With Quote
Old 05-17-2019, 09:05 AM   #24
Trailer: 2020 25 RQ
Anyone considering an airbag system, consider PAC Brake. I just purchased their air suspension system ( HP 10128...for 2019 Tundra). $100 + cheaper than Firestone and material seemingly more commercial like.
bigfoot
Axle-Less AxleLess Suspension - TIMBREN franck2cv Towing, Hitching, Axles and Running Gear 134 05-29-2018 10:56 PM
Comments on Timbren rear suspension upgrade? Daryl and Wendy Towing, Hitching, Axles and Running Gear 4 02-23-2016 07:57 AM
Axle-less trailer suspension system from Timbren UtahPete Towing, Hitching, Axles and Running Gear 15 08-06-2015 09:07 PM
Timbren Axle-Less jerry28 Forum Admin, News & Announcements 2 06-26-2015 03:28 PM
Timbren Axle-less Suspension on Acorn ??? NancyS Towing, Hitching, Axles and Running Gear 7 08-05-2013 05:06 PM
» Trailer Showcase
Baguette
Ryaine
Birki2
LauraW
