Tire Options - Fiberglass RV
Old 05-27-2009, 09:16 PM   #1
Just bought a 1972 Boler 1300 and need to put different tires on it so my Jeep can tow it.
Now I am installing a 15" rim but need to know about tire rating, do i need a light truck tire for this trailer or will a car tire suffice?
I want to make sure this is proper because the wife and I are taking our first vacation in it and we will be traveling from BC to Ontario.
Peter Bond is offline   Reply With Quote
Old 05-27-2009, 09:46 PM   #2
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
I may be misunderstanding your question but most Bolers will only accept a 13 inch tire without major modifications. I had smaller 13" car tires on my Boler and they served me well but I upgraded to a larger 13" last year to get a bit more height.
I am using Maxxis trailer tires available from KalTire
Model M8008
ST175/80R13
kevin61 is offline   Reply With Quote
Old 05-27-2009, 09:56 PM   #3
Model M8008
ST175/80R13
Looks like someone may have cut part of the fiberglass away but yes I can put a 15" rim with rubber on it with no issus.
Cant upload pic because of size but all I need to know is can I use a car or suv rubber.
Old 05-27-2009, 10:02 PM   #4
kevin61's Avatar
When I had my smaller 13 inch tires they were motomaster car tires and I had no problems with them even with a 2200 lb load. Trailer tires are preferable as they have stiffer sidewalls but I think you would be OK with truck or SUV tires.
Old 05-27-2009, 10:54 PM   #5
Booker B.'s Avatar
ST (Special Trailer) Tires are designed with less sidewall flex then car or truck tires. Car/Truck tires are designed to flex more to hug the road during curves. ST tires have stiffer sidewalls as they just need to track the vehicle.
Old 05-27-2009, 10:55 PM   #6
Booker B.'s Avatar
Whoops, duplicate post. Carry on ...
Old 05-28-2009, 12:57 PM   #7
Roger C H's Avatar
Talking
Here is a good discussion on trailer tires:
http://www.carlisletire.com/product_care/t...r_tires_101.pdf
Probably duplicated, but what the heck.
Old 05-28-2009, 01:52 PM   #8
BobB's Avatar
Hi Peter,
Question: "but all I need to know is can I use a car or suv rubber."
I've seen Special Trailer ST tires recommended most often and also Light Truck LT tires recommended for trailers. Most experts do not recommend Passenger P tires for trailers. Not sure what you mean by SUV tires, as some have P and some have LT. Look carefully at how much weight you will carry on each tire and buy a weight rating 25-50% greater for a margin of safety. Stay away from cheap tires!
Old 05-28-2009, 08:16 PM   #9
Hi Peter,
Figure I will just buy the proper tires, no sense being cheap about it.
Curtain Options Graeme Problem Solving | Owners Helping Owners 8 07-13-2008 07:42 AM
Tire Options? (in Canada) David Swinnard Towing, Hitching, Axles and Running Gear 15 05-23-2008 04:01 PM
New furnace options? Kurt in BC Modifications, Alterations and Updates 10 10-29-2006 11:37 PM
Search Options Brian B-P Forum Admin, News & Announcements 2 11-23-2005 02:04 PM
» Trailer Showcase
Coming Soon
Denece
Burro
JMS
