Tire Pressure - Fiberglass RV
Old 06-30-2010, 02:54 PM   #1
Pat C's Avatar
Trailer: 1981 Boler 13 ft / 2005 Dodge Caravan
We have installed new tires on our 13' Boler.The recomended tire pressure for the trailer is 30#.The garage that installed the tires inflated them to 40#.They said this higher inflation gives better tire wear.Is it OK to leave this pressure or should we reduce it to what is recommended by the trailer mfg.Thanks.Pat.
Pat C is offline   Reply With Quote
Old 06-30-2010, 02:57 PM   #2
Bud Kennedy's Avatar
Trailer: 1984 U-Haul / 02 Mazda pick up
I don't know about Bolers, but U-haul reccomends 40 lbs.
Bud Kennedy is offline   Reply With Quote
Old 06-30-2010, 03:22 PM   #3
I would go by what is on the sidewall of the tire.
Bill K
Old 06-30-2010, 04:00 PM   #4
Radar1's Avatar
Goodyear provides a guide for what weights are supported by various tire pressures. As long as you're using the same tires recommended by Boler, and the pressure they recommend you should be fine. If you carry heavier loads, the chart might come in handy for raising the pressure. Many manufacturers recommend the maximum rating listed on the sidewall, which might make for a bouncier ride and increased center tread wear, but gives the maximum load capacity.
http://www.goodyear.com/rv/pdf/rv_inflation.pdf
John
Sharpsburg, GA
radar1-scamping.blogspot.com
Old 06-30-2010, 05:57 PM   #5
TonyB's Avatar
Trailer: Bigfoot 19 ft (B19)
The tire pressure label on our Bigfoot says 32PSI, but the tires have been upgraded to load range "C". 50PSI is now correct, they would run hot at 32PSI.
TonyB is offline   Reply With Quote
Old 06-30-2010, 07:22 PM   #6
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Who knows what type of tire the Boler folks had in mind? You're not running those exact tires. Best to go with the tire manufacturer's recommendation. Your tires' weight carrying capacity is proportional to the tire inflation. If you run them at 30 psi you are running them at a fraction of their designed weight carrying capacity. I see no logical reason to do that. That would be like buying a chain to hold up a 1 ton weight, then sawing halfway through a link before hooking it up your weight.
Looking at it another way: there is no possibility that the extra psi could harm your trailer.
Old 06-30-2010, 07:30 PM   #7
Roy in TO's Avatar
Some good info from Carlisle here:
http://www.carlisletire.com/product_care/t...rvice_guide.pdf
"Carlisle Tire & Wheel only recommends and only warrants tires maintained [at] the max air pressure while in service."
Old 06-30-2010, 10:46 PM   #8
BruceG's Avatar
Trailer: Scamp 13 ft
I called the Scamp factory a while back to ask about my Scamp 13 tire pressure. They said to go with the recommended pressure on the side of the tires (50#) and to ignore any stickers on the camper or info in the Manual.
BruceG is offline   Reply With Quote
Old 07-01-2010, 01:35 PM   #9
Pat C's Avatar
Thanks Roy this was very informative.
Old 07-01-2010, 01:38 PM   #10
Pat C's Avatar
Thanks to everyone who responded.I will use the inflation rate on the tire sidewall.All your answers were most helpful.Pat.
13' Scamp tire pressure Jeff Larsen Towing, Hitching, Axles and Running Gear 4 08-02-2009 02:58 PM
Need Help with the Right Tire Pressure for a New-to-Me Burro DENNIS GOULD Problem Solving | Owners Helping Owners 4 02-28-2008 03:24 PM
Tire Pressure Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 6 07-13-2007 05:37 PM
Tire Pressure Ron and Alma Care and Feeding of Molded Fiberglass Trailers 7 04-22-2006 04:01 PM
Gas mileage vs. tire pressure General Chat 0 01-01-1970 12:00 AM
