Originally Posted by Darral T.
What brand?
Hercules, Power STR, Steel Belted Radials ST205/75 R14 load range c
load range b would have done the job just the c did as much as the
axle.
The Earlton sticker has the max recommended loaded
weight with original bias ply
tires as only 3000 lbs and we would not load it that heavy so b rating would have done the job. We also do not inflate to max on tire but use the amount on the closet door sticker recommended by Earlton
boler works
p.s I repack the bearings, new cotter pins each time, check the breaks and
lights before every long trip, just want no surprises.
We custom ordered our tv with extras Dealer wanted.
We have items like a full size spare "great as unable to tow with a regular temp spare and we would not like to leave the trailer at the side of the road" upgradeded hitch to a class 3 hitch later needed for the wd system recommended on
boler sticker, the class 2 would have done the job, trans-axle cooler. electric
brakes and more.
We wanted no warranty problems and checked with the local MTO on requirements as well for our trailer with our tv.
Hope this helps
