03-19-2018, 07:10 PM
Trailer: Boler 13ft 1972
Tire pressure for 13ft boler
Hi. I am struggling to find proper inflation pressure for my boiler. Assume 1400 lbs or 1500 lbs spread over 2 185-80R-13 tires (maxxis). According to their website, inflating them to just 25psi would allow load of 990 lbs each. The table doesn't go lower. And this pressure seems really low. Could this be? We plan on driving cross country. Trailer has brakes, not that it makes a difference I think. Tires are new. Any input on your inflation pressure would be welcome.
03-19-2018, 07:30 PM
I run my Scamp 13, which is probably a little heavier than yours, at 40psi. I like having plenty of margin.
Running at the minimum required to support the weight is just asking for trouble. For one thing, trailers tend to gain weight over time as you add one more tool or gadget into the storage compartments. For another, a slow leak can more quickly turn into a blowout if you're running at minimum pressure.
There's actually nothing wrong with running at the full sidewall pressure. Some tire manufacturers advocate that, but I suspect they're thinking of utility trailers, where the weight can vary dramatically from one day to the next.
Some make the mistake of trying to compensate for a harsh ride by decreasing tire pressure. A good axle, appropriately rated for the weight of the trailer, should not need any help from the tires.
03-19-2018, 07:34 PM
Given that the OP is rejecting advice about towing with a Mazda 5, I have no plans to respond to any other queries about trailering.
03-19-2018, 08:16 PM
25PSI is the MINIMUM TIRE PRESSURE to prevent tire damage with a 990pound load.
It is really low and it can't be true because it isn't!
You don't say, but assuming they are "C" rated tires, run them at 50PSI cold inflation pressure.
03-19-2018, 08:21 PM
Nice one Glenn. Could you have made your point better by just not replying
Now, lets be nice again. Lets say I will be towing with an F150. Does that help?
03-19-2018, 09:11 PM
BC
We always run our tires at max, they roll easier......... less fuel to tow, and handle potholes better less sidewall damage. When you pull over, at tea time, just walk around the rig, and put a hand on each tire, if a tire is getting hot it is either overloaded or under inflated.
We're lost but we're making good time.
Thanks Floyd. They are c rated.
03-19-2018, 09:15 PM
Im getting a sense to run them at max which is 50. But wont cold 50 + driving = higher warm pressure. Beyond max? Yhey probably factor that in...
03-19-2018, 09:18 PM
Ahhhh, tire manufacturers know more about their tires than what the tire is being mounted on... what does the side wall say? Do you really think a boler trailer that is loooong out of production can tell you what a new technology tire should be for tire pressure?
03-19-2018, 10:09 PM
Donna, my tires say "max 50 psi at 1650 lbs" or something like that (I'm not there now), so I wanted to know that if 50 psi was for 1650 lbs (or whatever), what would it be for half that which is more like my Boler would weigh. And then give it a margin of error.
03-20-2018, 12:22 AM
My tires say "max 50 psi at 1650 lbs" or something like that (I'm not there now), so I wanted to know that if 50 psi was for 1650 lbs (or whatever), what would it be for half that which is more like my Boler would weigh. And then give it a margin of error.
Interesting thread but I think you may be "splitting hairs" Nolan. No idea of why you want to run lower pressures because trailers are rolling earth quakes for their ride. Running your tires at half or so of the rated max pressure isn't going to give you any real advantage that I can see. If anything the temps may end up being higher because of sidewall flexing more. Personally, I wouldn't air down more that 5 psi from max stated pressure. There are many Boler owners here that can tell you what they run also. We do have a member here that comes from the tire manufacturing world, hopefully he will chime in for info on your question.
03-20-2018, 07:02 AM
air in tires
we had been running 50lbs for our 13f scamper around 1,000lbl stuff would be scattered all over the trailer when we stopped. I reduced the pressure to 40lb now things are normal and I think the trailer tows better.
bob
03-20-2018, 08:59 AM
jon my 95 scamp has a new axle under it. at 50lbs the ride for the trailer is really rough by going to 40 like you did everything much better!
bob
03-20-2018, 09:29 AM
Trailer: Perris pacer
I have a 13 ft Perris Pacer ! No bathroom ! I run my tires at 40lbs ! Happy medium ! Runs smoothly ! Not to hard !
03-20-2018, 11:11 AM
Scientifically (Newton-ally ?!?) speaking...
I have yet to find the size of the contact patch of 185 x 13 tires, but I'm guessing around 50 square inches over the 2 tires. If the trailer weights 1400 lbs, and 200 of that is on the tongue, then 1200 is on the trailer tires. To balance the downward force of 1200 lbs over an area of 50 inches, each inch of the contact patch needs to exert an opposite force of about 24 psi. so thats where we get our minimum pressure in the tire. Add the inertial difference from the suspension and uneven roads, and one wants to add more pressure.
I don't have all the numbers, but 40 sounds like a good compromise between a soft ride and cool tires. But with all things, trial and error esp with an educated starting point, will win the day.
Any tire experts out there to debunk my theory?
03-20-2018, 11:22 AM
Contrary to those who advocate maximum pressure per the side wall,
And those who think that the tires are not part of the suspension system: They are!
You only need enough air to carry the load, to where you can just see a slight bulge in the sidewalls. That way you have full width tread contact on the road, and the ability to deflect when rolling over rocks, curbs, etc.
An over inflated tire is susceptible to breaking the cords inside if it hits a sharp object.
With 900 lb per tire maybe 30 psi would be a good compromise.
03-20-2018, 02:02 PM
Here's a little clarity. At 50 PSI, the tire can carry a 1650 lb load. Or less. But 1650 is the max. You don't need to lower the tire pressure if your load is less.
I normally run my trailer tires at max unless a big bump would launch it. I once had a mobile home axle under a utility trailer, a gross mismatch. I drove over a railroad track one day and saw about a foot of sky under the trailer tires! Those tires were spece'd at 95 PSI. I took them down to 50 and the trailer rode a lot better.
But in a designed trailer like a Boler, Max that Tire Pressure Out, Baby!
03-20-2018, 02:04 PM
And as Wayne says, a large mismatch between tire pressure and trailer weight can lead to issues. They will puncture easier at full pressure. But we are not talking a large mismatch here.
03-20-2018, 02:11 PM
I seem to remember the Ford Explorer where lower than tire manufacturer pressures were recommended by Ford. I also remember roll over and deaths as a result.
03-20-2018, 08:16 PM
South Dakota
The BEST way to figure the inflation pressure is to load your trailer like you do to go camping and have it weighed, each tire and total and go from there. My 16' Scamp has a factory decal above the wheels that not to inflate the tires beyond 35#. Too high of pressure will cause the tires to bounce and like a previous poster stated tires are part of the suspension.
