Tire pressure on Scamp - Fiberglass RV
Old 07-03-2013, 10:48 PM   #1
beardrum's Avatar
Trailer: Scamp 16 Deluxe
never mind, now I see lots of discussion on this topic
beardrum is offline   Reply With Quote
Old 07-03-2013, 10:58 PM   #2
Brian B-P's Avatar
Whatever other people do, I strongly suggest that you do not inflate any tire 15 psi above the tire's maximum.
I also suggest reading the load capacity information on the tire sidewall to determine if the tire is sufficient for the trailer.
Old 07-03-2013, 11:00 PM   #3
Brian B-P's Avatar
And now, the great FiberglassRV Tire Debate, part 537...
Tire pressure Forester Bobbie Mayer Towing, Hitching, Axles and Running Gear 19 03-27-2011 10:37 AM
Tire Pressure Pat C Towing, Hitching, Axles and Running Gear 9 07-01-2010 01:38 PM
13' Scamp tire pressure Jeff Larsen Towing, Hitching, Axles and Running Gear 4 08-02-2009 02:58 PM
Tire Pressure Pete Dumbleton Care and Feeding of Molded Fiberglass Trailers 6 07-13-2007 05:37 PM
Tire Pressure Ron and Alma Care and Feeding of Molded Fiberglass Trailers 7 04-22-2006 04:01 PM
