Tire Rotation Question - Fiberglass RV
Old 06-04-2008, 11:58 AM   #1
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Can you rotate the tires on a 13' Scamp from left to right? Or is this not a good idea. Thinking about doing this ever fall after camping season is done.
Old 06-04-2008, 12:26 PM   #2
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Assuming they're radial tires, it shouldn't hurt. But my first question would be how do the tires look now? Any irregular wear? I support buying new tires every 5-6 years regardless of tread life. In my case, not enough miles (about 13,000) to develop irregular wear before I replace them.
Quando omni flunkus, moritati
Steve L. is online now   Reply With Quote
Old 06-04-2008, 01:24 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Brand new tires April 2008. So radials would be OK to rotate.
Old 07-18-2008, 10:53 AM   #4
Trailer: 2008 19 ft Scamp Custom Deluxe 5th Wheel
Short answer is Generally yes.
The OLD rules for Radials was NOT to do it - could cause internal slippage of the belts. no longer an issue
The ONLY time you shouldn't do it now is if the tread itself is "directional".
Ask a tire shop.
Alan Weinel is offline   Reply With Quote
Old 07-18-2008, 02:02 PM   #5
Trailer: 1980 Dolphin 14 ft
Hi Kevin
The tire rotation is not as important as ensuring you have the right type of tire on your trailer. A regular passenger radial has a weak sidewall and you will find a lot of sidewall bounce and sway. A "ST" or special trailer tire will prevent most of this. Keep them inflated to manufacturer's recommendations and check your wheel bearings regularly.
Tire manufacturers recommend replacing RV tires every seven years regardless of mileage as the sun checking will weaken the rubber and cause a good looking tire to fail when you least need it to. Covering your wheels when parked to lessen sun damage to your tires also helps.
When you retire, everyday becomes Saturday!
Owen & Rosemary
Formerly - 14'Dolphin, Looking for another!
Owen Lindsay is offline   Reply With Quote
Old 07-19-2008, 11:50 PM   #6
Pete Dumbleton's Avatar
Generally speaking, trailer tires are going to get old or suffer damage long before they actually wear out, presuming there are no balance or alignment problems.
I don't see a need to rotate the tires except if one wants to spread the wear over three tires instead of just two.
Tire clearance question AndyW Towing, Hitching, Axles and Running Gear 3 07-08-2007 07:42 PM
another tired tire question... jaye580 Problem Solving | Owners Helping Owners 6 06-22-2007 04:49 AM
IMPORTANT tire question Legacy Posts Care and Feeding of Molded Fiberglass Trailers 18 06-23-2003 06:38 AM
Oil change, tire rotation, other maintenance General Chat 0 12-31-1969 07:00 PM
Tire Rotation Question Kevin K Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
