tire size for 1972 Boler - Fiberglass RV
Old 11-10-2010, 03:07 PM   #1
Trailer: '73 Boler
Good day all.
ok, gonna get new tires for my '72 boler. 5 bolt 13" tires. The ones that are on it now are "car tires". I will be moving to a trailer tire, that seems to be the consensus in the trailer towing community. The size, 155 is something my tire guy is saying might be too small. He recommended going to a more standard size like 175. Not a big deal for size difference, only an inch or so I think. Any experience out there on clearance? I will measure tomorrow during the day, but there must be a host of sizes on trailers out there. Thanks all.
Regards,
Kyle
astroboy is offline   Reply With Quote
Old 11-10-2010, 04:05 PM   #2
Dave Bese's Avatar
Trailer: 1973 Hunter Compact Jr; 1972 Astro (Havasu?)
Having bought new tires a few months ago; the tire on the trailer were B78-13 which converted to 165-80R13ST. Got them in stock at Big-O
Dave Bese is offline   Reply With Quote
Old 11-10-2010, 11:38 PM   #3
Roy in TO's Avatar
Kyle, the clearance may depend on the condition of your axle. Have a look at my post below to see what I'm talking about.
Restoring Our 1972 Boler American
and here
And read posts 2 and 3 here
Replacing an Axle - leading arm to trailing arm
Old 11-11-2010, 10:23 AM   #4
Trailer: '73 Boler
and here
Roy,
Thank you for the links. That is great help. I think since I am taking the frame off the body, why not add two square pieces under the axle and raise it up. I will be doing some other small welding changes before I coat it. Not sure about the axle condition, but it ran fine and if I can avoid the expense I will. So, you used 145? That seems small? I guess the question is what is the maximum size one can put on the unit. I thought the bigger the better for wear and running (with obvious reasonable restriction).
Old 12-07-2010, 07:46 PM   #5
Borden's Avatar
Name: Borden and Carole
Trailer Name Boler Year 1973 Make Earlton Model 1300 Yours is the first Ealton made trailer I have seen since our purchase.
We have a 1978 1700 boler from Earlton Ontario
Old 12-18-2010, 10:26 PM   #6
Borden's Avatar
Nice of you to give the original size to astroboy
Old 12-26-2010, 09:56 AM   #7
Trailer: '73 Boler
thanks
Dave,
thank you for the translation to the new tires. great help, much appreciated.
Old 12-26-2010, 10:00 AM   #8
Trailer: '73 Boler
brother or sister
nice to see another. I don't know how many they made at the factory. hope to see you on the road. What type of renovations have you done? any pics for me to see. i have started at ground zero with mine. i will be dropping posts come spring. have a great day.
Old 02-01-2011, 12:55 PM   #9
Trailer: '73 Boler
and here
Roy,
looking through your posts above, would you think I could get away with the following listed:
NEW - 13" CHROME TRAILER WHEELS, W/ OR W/O TIRES - 400 AVAILABLE - London Parts, Accessories For Sale - Kijiji London Canada.
Seems like a good price from what I've been shopping for. New rims and a spare for $ 180.00? Should I try to get smaller, or raise the frame? Chrome would be fine?
Old 02-01-2011, 01:18 PM   #10
Borden's Avatar
Dave Bese was helpful and gave size conversion above of "165-80R13ST" for the 13’ boler.
original listed as 600x13-2 ply / B78-13 with recommended with pressure 28 psi 1010 lbs. capacity per tire.
The 165-80R13ST seems like lots of tire to me and on 13" Chrome rims they will look great!
Do not know the load capacity of the rims but doubt that will be a problem.
1978 Ontario made Boler
Old 02-02-2011, 09:55 AM   #11
Borden's Avatar
All I am doing to the trailer this year is:
1 breakaway switch for trailer brakes as it is law for my size trailer
2 Have Michelin 205r14 tires on trailer with have a load limit of 1532 lbs each or 3064 lbs. total; close to what it maybe loaded but would work on our 17' unit.
New tires c rated tires would have a load limit of
Max. Capacity: 1,820 lbs. each C rated 3640 total and the axle is 3500 lbs * Goodyear St205r14 C the extra 438 lbs could be good to have at a scales.
3 New hot water tank and shower retro fit to the bathroom project is started but need the winter weather to let up for completion
4 RV Shock retro fit for better ride on the northern washboard
In general the trailer is in great shape
boler
Tire Size Pat C Problem Solving | Owners Helping Owners 2 04-08-2010 09:46 PM
Scamp 19' tire size? Randya General Chat 15 06-11-2009 04:54 PM
scamp 13 tire size jmacchi Problem Solving | Owners Helping Owners 2 04-12-2009 06:21 PM
Tire Size for Trillium Barry Konkin Problem Solving | Owners Helping Owners 11 03-10-2009 11:22 AM
Boler tire size? Cory K Problem Solving | Owners Helping Owners 5 05-13-2007 11:49 AM
