tire wear - Fiberglass RV
Old 08-03-2007, 10:02 PM   #1
gregshannon's Avatar
decided to repack the bearings this weekend, getting ready for the big trip in a couple of weeks. When I took the wheels off I noticed that the tires seem to be wearing only on the outside. Not being to familiar with the axle system on Bolers, I'm wondering if this is common, is something out of alignment or is the suspension shot.
Any thoughts
gregshannon is offline   Reply With Quote
Old 08-03-2007, 10:40 PM   #2
Chuck-H's Avatar
Trailer: 17 ft Oliver Legacy Elite
Send a message via Yahoo to Chuck-H
If the tire is wearing on both sides and the center is not, then you are most likely underinflated air pressure. If the center of the tire is wearing out, it is over inflated.
What tire pressure are you running COLD vs the max psi on the sidewall of the tire?
chuck h.
Chuck-H is offline   Reply With Quote
Old 08-03-2007, 10:55 PM   #3
Trailer: 13 ft Perris Pacer
Make sure your axle isn't bent. Laying on the ground looking at the axle - if it's bowed upward (towards the bottom of the camper) in the middle (usually from running over a rock or stump,) there's your problem.
Angelo F. is offline   Reply With Quote
Old 08-03-2007, 11:11 PM   #4
The tires are only wearing on the outside, so I guess I better check the axle
Old 08-04-2007, 06:12 AM   #5
Roy in TO's Avatar
Angelo F. Posted Today, 12:55 AM
Not in all cases. I've got a leading edge torsion axle. The axle was tucked in behind the cross frame where the floor raises under the dining table/bed. My axle has an upward bend in the exact center which would be almost impossible to get without bending the cross frame at the same time or somehow at least marking it to show damage has occured.
If you check the Henschen Axle Plant Tour, you will see the axles are actually bent for alignment purposes.
It is possible something could be out of alignment, or if the rubber torsion has weakend (very likely), the trailer would be setting lower altering the alignment. So an axle check is in order. Some of the early model trailers had lighter duty axles, which in some cases were too light for the fully loaded trailer. If you check the Scamp history, you will find that the weights keep going up on the trailers and the axle load specs increased over the years.
Old 08-04-2007, 12:24 PM   #6
Trailer: 1972 13 ft Boler
Manitoba
I had the same problem.
Had new tires installed and after one trip to Kelowna and back,,,the outsides were about 50% worn while the insides were like new !
I returned to the Tire Shop and was advised that the axle/suspension was shot.I went to a couple of frame/suspension shops and was advised they didn't align these units and considering the age of the rubber torsion suspension,,,replacement was required.
Approx $500.00 later a new axle was installed and that should cure the problem,I say should because we haven't used it since.
Andy H is offline   Reply With Quote
Old 08-04-2007, 11:06 PM   #7
The bent axle appearance is for the camber angle....this forces the tires to be closer together between the bottom of the tires and further apart at the top.....I suppose if the axle was extremely bent it could cause the unusal tire wear.....I think that if the rubber suspension was kaput you would get unusal wear on the inside of the tire because your wheels would be canted in at the top.......now if your toe in was too much, that could possibly cause outside tire wear as the tires would scuff on the outer tread area trying to track in a straight line.. ..Benny
Old 08-05-2007, 06:43 PM   #8
Brian B-P's Avatar
I believe that Roy is referring to a leading arm suspension: these rubber-sprung "torsion" axles (such as Dexter's Torflex) has an arm on each side and usually the unit is mounted so the arms lead back from the frame mounting to the wheels... that's trailing. Some trailers had the same suspension/axle unit mounted turned around, with leading arms so the wheels are ahead of the rest of the suspension.
The reason it matters is that the drag of the tires will tend to pull leading arms apart, putting them at an angle which increases the tendency to pull apart (causing toe-out alignment), so a bent assembly or weak rubber might allow too much toe out. It's just a possibility.
Which way is this Boler?
Old 08-05-2007, 06:49 PM   #9
The arms are leading forward, which I thought would encourage the wheels to splay, causing pre-mature wear on the inside.
Could be right, could be wrong. Anyhow, I think it's a problem for the RV shop (in the fall)
Old 08-05-2007, 06:53 PM   #10
My 74- 13' Boler has leading arms and the axle is original as far as I know and I have no unusual tire wear so doubt if that could be cause, but then you never know....Benny
Old 08-06-2007, 03:40 PM   #11
Okay, here's a thought...... I was wire brushing the rims, figuring I would throw some paint on while they were off the trailer and I noticed that there aren't any balancing weights. 100 km/hr for any length of time would cause the wheels and trailer so shake a little. Maybe that motion would be enough to push the trailer around.
Old 08-06-2007, 07:59 PM   #12
Pete Dumbleton's Avatar
Be sure that the tire shop understands that trailer wheels are usually lug-centered or lug-centric and require an adapter on the balancing machine, not just the usual cone in the center...
Old 08-07-2007, 11:18 AM   #13
Brian B-P's Avatar
...The arms are leading forward, which I thought would encourage the wheels to splay, causing pre-mature wear on the inside....
I agree, but if the wheels are positively cambered (tilting out at the top) due to deliberate or accidental arch in the axle's cross-tube, they could be riding on the outer shoulders. The toe-out would accelerate the wear, on whichever edge is loaded most heavily is the camber is great enough.
Static (while not moving) camber can be checked with a level (held vertically against the tire; measure from the edge of the level to the rim at top and bottom); however, it will change while moving due to distortion of the suspension's rubber.
Similarly, toe can be measured by measuring the distance between reference points on each tire when those points are at the front, and when they are at the back (use a level, square, plumb bob, or whatever to drop from the reference point to the ground). Again, it will change with the drag of towing.
Old 08-13-2007, 11:28 AM   #14
Shawn Englehart's Avatar
Just wondering what the tire milage should be average for a set of trailer tires. My utility trailer has 15in tires, I just use old used tires and change them every 5 years due to cracking. I figured I should have to do the same for the Scamp, considering I spent $50/tire on the utility trailer and its $150/tire for the Scamp. I bought a set of 3 Goodyear Marathon(sp) 75/80/13 tires in 2005, pulled the trailer anywhere from 7500km to 10000km and have one with the same complaint here, the right side tire worn on the outside and the left tire worn even. I have never replaced a trailer tire from wear, always age or other (puncture of somesort). I figured I would get 40 to 50k out of a set of rotated tires, not 7k (this is also Kilometers, in miles I am well under 6000 miles if not under 5000 miles total on this set of tires). Both trailers have averaged the same milage except the utility trailer has half of those empty, the tires I have on the utility trailer shows no wear and a year older (3 years compaired to 2 years old for the Scamp tires).
Shawn Englehart is offline   Reply With Quote
Uneven tire wear Tamid Towing, Hitching, Axles and Running Gear 6 03-29-2010 11:13 AM
Tire Wear Alan P. Towing, Hitching, Axles and Running Gear 5 08-23-2008 10:14 PM
tire wear Chris Z Towing, Hitching, Axles and Running Gear 6 06-27-2006 02:21 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 27 04-16-2003 10:02 PM
Tire Wear Legacy Posts Towing, Hitching, Axles and Running Gear 1 04-14-2003 11:32 PM
Copyright ©2000 - 2018, vBulletin Solutions Inc.
