tires? - Fiberglass RV
Old 07-11-2010, 02:17 PM   #1
Wally P.'s Avatar
Trailer: U-Haul CT13
The previous owner on my Uhaul CT13 used Wanli S-1015 155/80R13 tires. The tires are basically new. They are radial tires however. Is that ok? I was under the impression that the CT13 should have bias ply tires.
Wally P. is offline   Reply With Quote
Old 07-11-2010, 02:41 PM   #2
Trailer: U-Haul
This site should answer your question fully:
http://blog.easternmarine.com/trailer-tire...-ply-vs-radial/
IMHO if you wish to be presenting your CT in as close to original as possible then I would go with bias ply tires. And if I were doing alot of back road/off road trailering then I would chose bias ply (if for nothing else but sidewall protection).
If one simply is trailering on paved highway or on gravel roads and wanted to have the trailer go down the road with the least tracking problems and with with better fuel economy, then I would go radial. On our light weight trailers weigh carrying capacity is of less concern, no need for class D tires.
Hope this helps,
David A.L.
David A. L. is offline   Reply With Quote
Old 07-11-2010, 08:47 PM   #3
Wally P.'s Avatar
Thanks for the info Dave. Radials it is then. I will not be doing any off road stuff.
Old 07-20-2010, 10:32 AM   #4
The 15" Goodyear Marathon trailer tires that are on my Scamp ARE radials. I was under the impression most trailer tires are too
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 28 09-01-2023 12:35 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
ST Tires Pete Dumbleton Towing, Hitching, Axles and Running Gear 7 04-13-2008 09:37 PM
Need new tires Don Davis Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
