Tires - Page 10 - Fiberglass RV
Old 06-09-2013, 06:21 PM   #127
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by gmw photos View Post
There. Tired of arguing with you guys and gals. Ha ! ....put that on your little fiberglass trailers....see if you can hurt this one......
225 mph ...... ........ Yea, that will do.
Old 06-09-2013, 06:26 PM   #128
carlkeigley's Avatar
NE Oklahoma
I've done 95 in semis and been passed by other semis like I was sitting still.
Very late at night of course.
I prefer to stay at 75 or below in a semi.
Otherwise you need at least a quarter to stop.
Old 06-09-2013, 06:34 PM   #129
Trailer: FunFinder
...yes sir. And 46,700 pounds capacity per tire ought to hold it up too.....
gmw photos is offline   Reply With Quote
Old 06-09-2013, 07:12 PM   #130
IllAnnoy
But I 'm saving my quarter to get a cart at Aldi...
Could I stop on a dime if I just go double nickel?
Makes cents to me!
Old 06-09-2013, 09:11 PM   #131
Awesome find George!!! You sure made my next tire purchase easy!
Old 06-18-2013, 09:09 AM   #132
Trailer: FunFinder
Very interesting discussion going on regarding tire failures. The photos and discussion are informative:
RV.Net Open Roads Forum: Towing: Unsafe at any speed....
Old 06-18-2013, 09:32 AM   #133
Thomas G.'s Avatar
From this link:
Yesterday I was outside, and I heard a loud "bang", and I walked over to the trailer and the spare tire had exploded. See photos below. The spare tire had only been used the one time when the Hercules tire blew out in California, and had a total of 50 miles on the tread. The Towmax spare tire has always been covered and was inflated to 65 pounds. It was not hot, it was about 75 degrees.
Boy, what a nit picker.
Old 06-18-2013, 10:22 AM   #134
Trailer: FunFinder
From this link:
Yeah, imagine if that would have happened as he was getting ready for bed in the evening ! That would get your attention.
Old 06-18-2013, 10:48 AM   #135
Thomas G.'s Avatar
Or in the middle of the night.
Old 06-18-2013, 11:52 AM   #136
Brian B-P's Avatar
Great link. As with all such discussions, all information is a little bit suspect. One responder posted that
I had about 10 LT Michelins that did the exact same thing.
... but he later posted a photo of one of these "LT" tires, which is actually a P tire (P235/75R15). I wonder if he also forgot to mention overloading them?
Although the original poster seems very diligent in providing information, and even reports actual total axle load, I didn't see an indication of individual axle loads, so we don't know if there was a problem with unequal loading. Some information is only implicit: the original tires were presumably Load Range D (based on the reported 65 psi inflation pressure limit). Despite these detail issues, it certainly does seem like he got some Super Trashy tires.
I would be concerned by a tire exploding while not even in use, too!
Old 06-18-2013, 12:39 PM   #137
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Another thing about dual axle trailers is that if one tire fails (perhaps a puncture) that usually means the other tire on that side is instantly overloaded and when/if the companion tire fails, some pretty severe side loads occur on the other end of the axle making those tires suspect as well. Tires don’t heal. Heat and stress that reduce tire life is tire life that is gone forever. Getting the trailer safely stopped promptly is key to not overstressing the other tires.
Steve L. is online now   Reply With Quote
Old 07-26-2014, 09:06 AM   #138
Trailer: Escape Trailers
Massachusetts
Preference between 50psi max and 65psi max tires
Has anyone had a comparative experience between running radial tires with 50psi max rating versus 65psi max? The 65s seem to offer a higher load rating. Are there any downsides to the 65s? We're about to purchase a pair of ST175/80R13D tires. Where will I find the max pressure rating on our wheels? If I can't find it and decide to go with the 65s, we'll probably buy pre-mounted wheel and tire from etrailer. The tires Scamp installed are 50psi max, so I'm guessing our wheels are as well. We haven't found any 'D' rated tires locally.
Thanks,
David
Stretcher is offline   Reply With Quote
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 19 12-30-2014 02:14 PM
Trailer tires or car tires? serious sam Problem Solving | Owners Helping Owners 4 05-15-2011 10:13 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
New Tires Sonny Care and Feeding of Molded Fiberglass Trailers 20 06-27-2007 07:08 PM
