Tires for RVs - Fiberglass RV
Old 06-19-2018, 04:32 PM   #1
Trailer: Newmar
Nevada
Tires for RVs
Just curious, can mud tires like Mickey Thompson Tires' Baja MTZ P3 used in RV's?
Arc75 is offline   Reply With Quote
Old 06-20-2018, 09:38 AM   #2
Trailer: 2013 Casita 17' LD
If it's an LT tire, which it appears to be, then yes, it may be used, subject to having the appropriate weight rating for the trailer. Trailer tires have stiffer sidewalls than passenger car tires (P); not sure of the difference between ST (Special Trailer) and LT (Light Truck) sidewalls.
Spongelander is offline   Reply With Quote
Old 06-20-2018, 10:16 AM   #3
I note that the OP's profile indicates he has a Newmar. That doesn't sound like an all-molded fiberglass trailer. I'd hesitate to make any recommendation without knowing what we're talking about.
Old 06-20-2018, 11:51 AM   #4
J.F.Y.'s Avatar
Folks......
Aside from the possible differences in casing structure, perhaps we should be amused by all the "mud" or deep-cleated tires being shown on trailers intended for boondocking, or "off-road" use.
Just how helpful are those cleats on an undriven axle? LOL !
Frank
J.F.Y. is offline   Reply With Quote
Old 06-20-2018, 12:51 PM   #5
Raspy's Avatar
Trailer: 2015 Oliver 23, Ram Cummins
Smith Valley, Nevada
Originally Posted by J.F.Y. View Post
Folks......
Frank
Yep. Just because it's a "mud" tire doesn't mean it has any extra value on a trailer in the mud.
A good solid load range and an easy to get size of LT tire are better considerations than mud vs highway tread, for a tire that is just being towed along. The down side of "mud" tires are that they tend to pick up rocks and throw them, will wear faster than highway tread, have more rolling resistance and are much noisier. But, of course, they look cool.
Old 06-20-2018, 12:53 PM   #6
Raspy's Avatar
Isn't that a recommendation?
Old 06-20-2018, 01:09 PM   #7
John in Santa Cruz's Avatar
Trailer: 2014 Escape 21, 2002 Ford F250 7.3 Diesel 4x4
well, presumably a LT M/T tire on a trailer would have better braking in mud/sand, but I would stick with ST trailer tires.
I do note that my son's all terrain military trailers have heavily lugged tires, one of these is a M989A1 HEMAT, which has 2 axles with 15-22.5 load range H tires.. that trailer has 22000 lb payload, 11000 lb empty, he tows it behind a M925A1 5 ton 6x6.
tires
Flippin' RVs Is Back as Beachin' RVs Dgregg General Chat 0 03-01-2017 06:28 PM
Extreme RVs and Flippin' RVs Dgregg General Chat 6 06-11-2016 09:59 PM
Are Stick Built Small RVs going to kill fiberglass RVs? Dextersp1 General Chat 95 02-22-2016 05:21 PM
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 19 12-30-2014 02:14 PM
