Tongue Jack base fell off - Fiberglass RV
Old 05-21-2016, 05:18 PM   #1
Ohio
We picked up our new Scamp 13 on Thursday and stayed in Backus MN for two days to do a shake down. We left for Porcupine Mountains State Park and just arrived and set up. We noticed the bottom plate for the tongue jack is gone.we checked the manual and video and are trying to figure out if it should have stayed on with a pin?
Input would be appreciated and luckily we had ordered a wheel as well!
Besides this we are having a blast and met with really nice folks last night with a 2005 16 foot scamp!
Scott L
sal6342 is offline   Reply With Quote
Old 05-21-2016, 05:48 PM   #2
IllAnnoy
Scott L
The foot is normally held in place with a pin which has a wire clip retainer. If the main shaft of the jack is not damaged or bent then the odds are that the clip was not secured and it just vibrated out and the foot just fell off.
The good news is that the parts are easily gotten at any local RV dealer such as camping world. They also sell a wheel which will fit on the same spot so that you can wheel your camper around on the driveway at home with ease.
If you think Scamp is at fault for leaving the clip loose, give them a call and I am sure they will either send you one or pay you to pick the parts up locally.
Enjoy your new Scamp!!
Here the foot is sold for $4.55....
http://www.redtrailers.com/ShowItem....FUI9gQoddcUCHQ
Old 05-21-2016, 05:58 PM   #3
IllAnnoy
OBTW! You could use a piece of 2X4 or something similar as a foot until you get the new foot. I use the lego style pads for leveling and setup even with the foot in place....
Old 05-21-2016, 09:24 PM   #4
The Minimalist's Avatar
Louisiana
You don't necessarily need to go to an RV dealer for the foot. It is a common part that should be available at any trailer supply place.
You can also get a dolly foot that will allow you to move a 13 footer around with ease.
You might call Scamp and tell them you are sending the receipt for reimbursement on the foot. No guarantees, but worth a shot.
Clif
Old 05-22-2016, 06:50 AM   #5
I believe they already have the wheel, which they are using in the interim.
But I agree- the flat foot is neither hard nor expensive to replace, and you can decide whether to hold Scamp responsible for the cost. I'd try Walmart, Home Depot, Tractor Supply, U-Haul, auto parts store,... , or go online after you get home.
Old 05-22-2016, 07:46 AM   #6
You might.. but removing the foot (or wheel), or at least checking that the pin is in place, is part of the process of hooking up and preparing to tow, and the responsibility of the driver. I would eat the very minor cost and forget about it (well, actually I would remember it when hooking up).
Many people remove the foot for the added clearance when towing, and it is even possible to set up the trailer without the foot, as long as long as you have a way to cushion the jack shaft (wood block). But you should take care not to damage the shaft end so that you can continue to use the foot / wheel. In other words, don't put it down right on the pavement where movement of the parked trailer might damage it. Of course the foot also holds water and will rust out faster if it is not removed when it is not needed. Those are a few of the reasons why it is removable.
On my pop-up I always removed the foot when towing and rarely used it when setting up for camp, but on the Scamp I put on the Ultimate Jack which can be raised and so have left the foot in place (so far).
Old 05-22-2016, 08:06 AM   #7
I leave the foot on. Two days ago I had a minor tongue strike exiting a gas station. With the foot on, it slid on the pavement without damage. Without it, the sharp edge of the jack shaft might well have caught and bent. I hadn't thought about it trapping water, though. Seems like a hole in the center of the foot would solve that.
I like your Ultimate Jack, Gordon. What is your impression of the quality of the materials and the internal mechanism? I was thinking about it after the tongue strike, but had forgotten the name. This time I'll bookmark it…
Old 05-22-2016, 09:32 AM   #8
I like your Ultimate Jack, Gordon. What is your impression of the quality of the materials and the internal mechanism? …
I guess I would give it a 7.5 out of 10 for quality of build.
You surly need to make sure the locking pin is in place. If not, I could see it vibrating loose and dropping the jack (at 65 MPH) But after I lock the pin in place it seems very secure. There are a few internal components that might be subject to wear. There is a hard plastic piece that might be damaged if you repeatedly let the jack drop by itself instead of lowering by hand. And if you let it drop it can get stuck too, so you need to lower it by hand.
I got it so I could open my tailgate / back door while the trailer was on the hitch, something I could not do with the original jack (which I would rate a 5-6 for quality). It works very well for that and there have been many times that I forgot something in the rear of the van and the jack saved me from either unhitching or crawling over the rear seats to the back to get to what I needed.
In the lowered position the handle can hit the single propane tank but if I am careful its not a problem. If you have dual tanks it might be worse (or better).
I'm happy with it and would buy it again. It should be available for about $55 or less.
Another option is the Jack-E-Up which is completely removable.
Old 05-22-2016, 02:25 PM   #9
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Scott L
I tried a wheel on our 16 ft, but found I could not lower the hitch far enough to engage the ball on the TV. My flat plate foot is secured with a bolt and self locking nut, which takes wrenches. Less likely to come loose.
Old 05-22-2016, 03:12 PM   #10
Trailer: Casita 17 ft DLX SD
I removed the wheel from my Casita and replaced it with a plate
Drilled a couple of drainage holes in the plate and secured the attachment clip with a heavy duty tyrap so it could not vibrate loose. We have a gravel driveway and the wheel was useless plus the plate is more stable and has better ground clearance.
Old 05-22-2016, 05:25 PM   #11
IllAnnoy
I have the wheel which I keep at home. It makes it SOOO easy to wheel the trailer around in the shop and on the driveway. I bring it out with the wheel when ready to hook up for a trip, then switch to the foot and leave the wheel at home. When I get home I just pull straight into the driveway and switch to the wheel and put the trailer away.No backing around the house to the shop. I used to use a trailer dolly but the wheel is so much better.
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 11:39 AM
Door handle fell off in my Boler Emilie W. Problem Solving | Owners Helping Owners 4 01-20-2015 07:56 PM
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
Broken axle help in Lafayette, LA? (was: whee l fell off (mostly)) CeliaL Problem Solving | Owners Helping Owners 27 03-23-2011 08:31 AM
Potable fresh water tank spigot fell off brendaross Problem Solving | Owners Helping Owners 1 09-18-2007 05:13 PM
