tongue jack for 17wb Burro - Fiberglass RV
Old 08-13-2018, 09:01 AM   #1
Trailer: BURRO
Massachusetts
Need to replace my Atwood Tongue Jack. It attaches to a welded plate with a snap ring. It also swings up while towing. It has a U pin so it spring locks it with 2 pins. This thing only had a 500 lb capacity. Anyone know where I can get a replacement. I need to use that same welded on plate. I took it apart and replaced a broken spring pin at the gear, only to find the pin broke because the wheel lowering mechanism was jammed.
Anyone know a solution
Greg in Mass is offline   Reply With Quote
Old 08-13-2018, 09:40 AM   #2
Same style jack as on our Uhaul. We have a replacement from Tractor Supply that is mounted on the original stub that is welded to the tongue. Harbor Freight, Northern Tool, and etrailer.com would be other sources. If you buy locally, measure the stub on the tongue before you go.
Old 08-13-2018, 10:56 AM   #3
Trailer: BURRO
Massachusetts
tongue jack
Thanks there is a harbor freight nearby I will check them
Old 08-19-2018, 07:40 AM   #4
Trailer: BURRO
Massachusetts
tongue jack follow up
The Harbor Freight looked great so I bought it. A couple days later put it on and it only would go to the groove for the snap ring, ugh! Bought one at Lowe's. It was a Reese about 12 dollars more fit perfect on the stub BUT, The pin was bigger and it had this weird slant that place the wheel under the A. Had the bright idea of using the double pin from HF jack on the Reese jack. That plan didn't work out ideally as the Reese jack had a larger hole. Had to go to the brother who welds. He found the time to help me. We cut off the original bracket and welded it on the Reese jack. Painting it up now so the welds don't rust. Now I feel safe when I am cranking it up. Thanks Bob for putting me on the path to local buying. Some things are best in your hands.
burro
New cargo doors for my Burro 17wb george w Modifications, Alterations and Updates 9 08-09-2018 05:08 PM
Jack-E-Up jack Victor Benz Modifications, Alterations and Updates 12 07-20-2017 04:12 PM
Split from 1993 Burro 17WB -SOLD- Donna D. Problem Solving | Owners Helping Owners 14 06-20-2009 07:02 AM
SOLD - 1993 Burro 17WB For Sale floyd Classified Archives 9 09-27-2008 08:41 PM
