Tongue Lengthening - Page 2 - Fiberglass RV
Old 08-09-2009, 03:50 PM   #15
Trailer: 2011 KZ Sportsmen 242SB / 2004 Ram-Cummins 2500 2wd
It's not the 1/3-2/3 length ratio that makes the difference, it's the ratio of track width to axle-to-Hitch distance. A lot of cheaper tent trailers were less than 1:1.5 ratio to get width without length, and swayed unmercifully even if loaded very nose-heavy. My homebuilt M/C tent trailer, built on this ratio, tows dead straight at 90mph with my two-wheeler. My old Layton is not quite 2/3-1/3 length ratio, but is just shy of 1:2 track to draw length ratio. It's almost impossible to cause to wander unless the black water tank (at rear)is full, and the fresh (at front) is empty. But we're talking about 45 gals of slop, hung right at the back end. That would screw up any trailer's handling. There was a post on this thread that stated that the frame would need to be strengthened most of the way from the hitch to the axle if it was lengthened. I agree that the greatest 'moment of bending' would be at the front of the body, as the section under the body is re-enforced by it. But, placing a piece of square tube (1/8" wall thickness) and same width as original frame, extending 1.5ft behind the front body line to 1.5ft in front of the extension, under the original and welded full length, should certainly add enough strength. Most of us, when modifying tongues, tend to 'Overbuild', where manufacturers tend to push to the limit.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
Old 08-11-2009, 11:28 AM   #16
Heath G.'s Avatar
Trailer: Compact Jr
Ohio
Boy am I glad I read this. I have a 72 compact jr and it seam s to have the sway problem yuo are talking about, I also want to add a box but have to room. My problame is the compact frame is original and looks and feel weak. Most of them I have seen on this site look like almost all have some sort of mod done to the tunge of them. is this a comon problame with the compact's?
Heath G. is offline   Reply With Quote
Tongue & 12V changes Rudy_Z24 Modifications, Alterations and Updates 4 05-21-2008 10:46 AM
Another Tongue Job Greg A Care and Feeding of Molded Fiberglass Trailers 6 07-30-2007 05:55 PM
Tongue Job Gerry Modifications, Alterations and Updates 0 05-28-2007 03:54 AM
Tongue Box Barbara Gardin Care and Feeding of Molded Fiberglass Trailers 1 07-03-2006 08:03 PM
Tongue Weight Legacy Posts Problem Solving | Owners Helping Owners 1 06-09-2003 12:58 PM
